November 27, 2024, 03:31:52 03:31
Author Topic: Raspberry Pi  (Read 5897 times)
OlDrunk
« on: June 07, 2012, 05:18:38 05:18 »
Just wondering if there are many on here that are interested in the Raspberry Pi, waiting for it to ship or got one already? I just got my'n in the mail the other day ordered back in Feb when it launched.
aplank
-Given: 137
-Receive: 193
« Reply #1 on: June 07, 2012, 06:49:22 06:49 »
Yeup, got mine about six weeks ago. Seems to work well, but very fussy about the brand/type of SD card. Pressure at work means there's not yet been much of a chance to use. Last week a second one arrived.
kayvee
-Given: 98
-Receive: 101
« Reply #2 on: June 07, 2012, 09:00:59 09:00 »
Mine should be delivered any day now, they said 3 weeks ... about 3 weeks ago when I paid.  Can't wait.
And for those that have been living under a rock Wink
http://www.raspberrypi.org/
http://www.themagpi.com/
« Last Edit: June 07, 2012, 09:32:35 09:32 by kayvee » Logged
-Given: 834
-Receive: 4322
« Reply #3 on: June 07, 2012, 12:21:52 12:21 »
Got my 2nd last week, swopped the first one for a load of arm dev. boards, so well pleased.
pity they made a mess of laying out the pcb, very amateurish, they are not designed with any thought.
1. No mounting holes.. how hard to miss this?
2. Usb & Network sockets not in line, makes it hard to fit in a case. good design is all sockets on one edge of board.
3. Sd card mount as above, no thought of placement.
4. using a mini usb for power in, I can see problems not having a proper power jack & switch here.
aplank
-Given: 137
-Receive: 193
« Reply #4 on: June 07, 2012, 12:26:41 12:26 »
Seem to remember seeing a reason(/excuse) for that one on their website a while ago ... It was along the lines of "holes take up space".
-Given: 834
-Receive: 4322
« Reply #5 on: June 07, 2012, 01:14:51 13:14 »
True, but thier target customer is the school system, how long are they going to last there, blue-tacked to a workbench.
Also as the old saying goes, size is not everything!
« Reply #6 on: June 07, 2012, 02:42:39 14:42 »
Basically, if the board doesn't have power switch, then is a serious failure. I was going to own ARM discovery, but as long as it lacks the power switch, I am no longer interested, is it really difficult to add a switch when designing a PCB. What kind of budget crap is this?
I liked your comment about all plugs on one side, it gave me a good insight for one of my projects, thanks!
« Last Edit: June 07, 2012, 02:45:13 14:45 by metal » Logged
Old_but_Alive
-Given: 746
-Receive: 120
« Reply #7 on: June 07, 2012, 06:42:23 18:42 »
I dont have one, or one on order, but
Punnet cardboard cut-out case for the Raspberry Pi
http://dangerousprototypes.com/2012/06/06/the-punnet-a-cardboard-cut-out-case-for-the-raspberry-pi/
OlDrunk
« Reply #8 on: June 07, 2012, 06:56:09 18:56 »
I agree with the poor design comment, the polyfuses on the USB ports are a pain the ass I can't get some peripherals to work like a simple 100mA optical mouse with out splicing the USB cable to have independent 5V power supply connection. The polyfuse is suppose to be rated @ 140mA but getting crazy voltage drops well below 4.4V after 90mA. I know this just a Dev release of the RPi and the final for school use should be better, I hope.
« Last Edit: June 07, 2012, 07:03:03 19:03 by OlDrunk » Logged
CocaCola
-Given: 169
« Reply #9 on: June 08, 2012, 05:07:03 05:07 »
I was really looking to pick up one of these but held off, looks like it might have been a good choice as I'm not in hurry to jump in due to time constraints...
Hopefully they will address the smaller but annoying issues and streamline the production with a revision 2 version...
I agree, a few mounting holes to put a few standoffs in so it can be mounted to a base is almost a necessity in an educational environment...  It's way too easy to smoke bare boards with conductive debris or whatever it might inadvertently contact on a work surface...  And that is not even taking into consideration the components on the underside getting damaged...
h0nk
-Given: 226
-Receive: 231
« Reply #10 on: June 10, 2012, 05:17:00 17:17 »
Some notes for Raspberry Pi newbies:
www.raspberrypi.org - still no wiki, you have to do a heavy search if You run into problems.
www.elinux.org - much better
Hardware modifications:
On my Pi i shortened the fuses for the USB-ports.
Pro: Depending on the power supply, the Pi can now drive even external USB-drives.
Con: USB-hotplug may reset the Pi if the external device contains bigger capacitors.
Software:
The kernel (debian6-19-04-2012) misses all of the enhanced network features like:
iptables, bridging and vlan support
If You recompile Your kernel, get also the firmwarepackage:
https://nodeload.github.com/raspberrypi/firmware/tarball/master
and replace the files above /opt/vc
Do a depmod -a and a ldconfig. After a reboot the video core should happy again.
On my (overclocked 900 MHz CPU/500 MHz RAM) Pi the compilation took:
real    339m18.118s
user    317m13.270s
sys     13m18.870s
Attached my .config file.
Best Regards
Nazral
« Reply #11 on: June 24, 2012, 01:50:28 13:50 »
Picked up one of these a while ago as a hassle-free means of interfacing a screen and user I/O to some instrumentation I've been working on (Overkill, I know). It arrived with C6 knocked loose and an erratic joint on the SD socket. Few bodges with the soldering iron sorted it out in due time. The lack of mounting holes as mentioned by pickit2 is an amazing oversight; as an owner of many, many development kits, it's rare to see one lacking them.
Also, I'm sure most of us have seen this before, but if not, the following PDF contains all relevant memory addresses for the peripheral suite of the Broadcom chip.
 http://www.alliedelec.com/images/Products/mkt/lp/1203/resources/Broadcom_datasheet.pdf
element7k
« Reply #12 on: June 30, 2012, 11:10:39 11:10 »
is the raspberry pi able to stream video from its HDMI ports?  (say for example I want to watch something on netflix on my TV without having to boot up my laptop) Does it overheat? Has anyone tried it?
E7K
h0nk
-Given: 226
-Receive: 231
« Reply #13 on: June 30, 2012, 12:41:49 12:41 »
E7K
HDMI is output only on the Pi.
The CPU stays quiet cold, even at 900 MHz running at nominal voltage.
The USB-chip tends to heat up. Sorry no IR-equipment to measure.
Best Regards
CocaCola
-Given: 169
« Reply #14 on: June 30, 2012, 09:00:11 21:00 »
You can always get a dedicated box to do that, I have the Western Digital TV Live Plus, a complete home entertainment system in a small box...  You get several streaming services including Netflix, as well as external USB storage access and shared network or media server access, even between WD units...  I have one central networked computer in my house loaded with my entire media collection and a WD box on each TV that results in a complete wireless entertainment system...
h0nk
-Given: 226
-Receive: 231
« Reply #15 on: July 29, 2012, 02:35:05 02:35 »
The BCM2835 Peripheral Doc.
Bookmarks and Errata added.
Best Regards
