April 22, 2025, 03:47:19 15:47
Author Topic: i2C MULTI_MASTER  (Read 8096 times)
o_cientista
« on: June 07, 2012, 12:03:24 00:03 »
Good day.      Two months ago I'm trying to do two PIC act as master and as slave in another time and work as a slave and master, but so far failed. Disistindo I therefore do not know what else to do. Someone could help me. Here is the code of the master and slave.
// MASTER
#include <16F877A.h>
#device adc=10
#FUSES NOWDT                     //No Watch Dog Timer
#FUSES HS                        //High speed Osc (> 4mhz)
#FUSES PUT                       //Power Up Timer
#FUSES PROTECT                   //Code protected from reads
#FUSES NODEBUG                   //No Debug mode for ICD
#FUSES BROWNOUT                  //Brownout reset
#FUSES NOLVP                     //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOCPD                     //No EE protection
#FUSES NOWRT                     //Program memory not write protected
#use delay(clock=20M)
//NOTE: Must declare MASTER before SLAVE, i2c_isr_state() returns 0
//      when MASTER is the most recent #use i2c
#use i2c(MASTER, sda=PIN_C1, scl=PIN_C0, stream=I2CM)
#use i2c(SLAVE, sda=PIN_C4, scl=PIN_C3, address=0xA0, force_hw, stream=I2CS)
#use rs232(baud=57600, parity=N, xmit=PIN_C6, rcv=PIN_C7, bits=8, stream=COM1)
#use fast_io(D)
int rcv_buf[0x10];
int wrt_buf[0x10];
int address;
#int_SSP // interrupt on i2c activity
void  i2c_isr(void)
    int state, incoming;
    state = i2c_isr_state(I2CS);
    if(state < 0x80)
        incoming = i2c_read(I2CS);
        if (state == 1)
            address = incoming;
        else if (state >= 2)
            rcv_buf[address] = incoming;
    else if(state == 0x80)
        i2c_write(I2CS,wrt_buf[address]);
void main()
    enable_interrupts(INT_SSP);
    enable_interrupts(GLOBAL);
    printf("\n\rbegin");
    while (TRUE)
        if (!input(PIN_B4))
        i2c_start(I2CM);
        i2c_write(I2CM,0xB0);      //i2c address of a slave device
        delay_ms(10);
        i2c_write(I2CM,0x00);      //1st byte to slave
        delay_ms(10);
        i2c_write(I2CM,0x22);      //2nd byte to slave
        delay_ms(10);
        i2c_stop(I2CM);
//SLAVE
#device adc=10
#use i2c(SLAVE, sda=PIN_C4, scl=PIN_C3, address=0xB0, force_hw, stream=I2CS)
#use fast_io(D)
int rcv_buf[0x10];
int wrt_buf[0x10];
int address;
void  i2c_isr(void)
    if(state < 0x80)
        if (state == 1)
            address = incoming;
void main()
    while (TRUE)
        if (!input(PIN_B4))
        i2c_start(I2CM);
        i2c_write(I2CM,0xa0);      //i2c address of a slave device
        delay_ms(10);
        delay_ms(10);
        delay_ms(10);
        i2c_stop(I2CM);
