November 21, 2024, 09:31:44 09:31
Author Topic: STM32F4DISCOVERY and ST-LINK/V2 (Problem and Solution)  (Read 35828 times)
omar2009
-Given: 51
-Receive: 181
« on: May 29, 2012, 09:37:21 21:37 »
Hi All,
I got STM32F4DISCOVERY board
http://www.st.com/internet/evalboard/product/252419.jsp
It is based on STM32F407VG Cortex-M4 ARM MCU
I tried to connect to it using ST-Link utility
http://www.st.com/internet/evalboard/product/251168.jsp
but i got:
Connected via SWD.
Cannot connect to the MCU device!
after some invistigations I recognized that the problem is in the
MCU revision which is: 'Z' Revision
           |     STM32F407     |
           |   VGT6          Z     |    <----  Here is Revision code
           |   HPAFD      VG    |
           |   KOR   HP   203  |
Later found this Errata:
http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/ERRATA_SHEET/DM00037591.pdf
on page 9 we can find:
2.1.2 MCU device ID is incorrect
So:
The Device ID of the STM32F4xx Rev.Z has been changed to 0x413 (instead of 0x411 for Rev.A).
Thus, ST-LINK Utility can't recognize the device ID of STM32F4 Rev.Z (Only Rev.A is supported).
Solution:
the attached patch adds the support of STM32 F4 rev.Z in the current version(v2.2).
Have fun
Omar
« Reply #1 on: May 30, 2012, 01:30:51 01:30 »
The original topic
bm.marwen says:
This issue will be fixed in the next version which will be released soon.
In the meanwhile, the attached patch adds the support of STM32 F4 rev.Z in the current version(v2.2).
Marwen
Here is the original file attachment
This is a well known issue on STM32 discovery board. I looked at the both applications, the original and the one from the patch, and it seems this was a simple case statement change in C code.
« Last Edit: May 30, 2012, 01:46:40 01:46 by metal » Logged
codekey
« Reply #2 on: May 07, 2018, 10:47:19 22:47 »
Hi All,
but i got:
Connected via SWD.
           |     STM32F407     |
           |   HPAFD      VG    |
           |   KOR   HP   203  |
So:
Solution:
Have fun
Omar
I have one of those Discovery boards. I accidentally damaged the STM32F407 so i ordered a replacement STM32F407.  After replacing the STM32407 the ST-Link2 didn't recognize the micro. I ended up ordering a brand new STM32F4 Discovery board.
Now that i've read this post, i looked at the Discovery board i could not get to work and the Revision after VGT6 shows "2". Could this be the problem why the ST-Link2 does not recognize this micro?
h0nk
-Given: 226
-Receive: 231
« Reply #3 on: May 08, 2018, 12:27:51 00:27 »
Hello
Have You tried the "ST-Link Utility"?
At least it should be able to read the Device ID/Revision ID.
The size of the flash is also stored in a predefined register and
should be readable.
I have two F407 Discovery Boards. One is rather old with VGT6 - A.
The Chip is recognized as: Device ID: 0x411/Revision ID B and
a newer one with a VGT6 - Z. This shows Device ID: 0x413 and
Revision ID Z.
If the Chip is unknown to the software i would assume, that the utility shows
"Unknown Device" but with correct values for Device ID, Revision ID
and Flash size.
I would suggest to write a small test for the SWD-Pins in GPIO-Mode
and test the connection. You can use the boot loader to flash this test.
Dont forget a sufficient delay loop at the begin if you want to erase and
reprogram via SWD/JTAG later.
And you should update the ST-Link on the Board to the latest available version
together with the communication libraries for Your favorite IDE/Compiler.
I remember that i had similar problems with a brand new STM32L053 some time ago.
Good luck, and
Best Regards
Mr. Spock
-Given: 474
-Receive: 827
« Reply #4 on: May 08, 2018, 09:38:16 21:38 »
Segger has an utility that transforms an ST-link into a Jlink. This may solve your problem
mEErEck
« Reply #5 on: August 21, 2020, 09:56:55 09:56 »
Mr. Spock is right. You can follow this article: https://www.segger.com/products/debug-probes/j-link/models/other-j-links/st-link-on-board/
I have convertered cloned STLINKs_v2 purchased from China into the JLink. The programmer became much faster in terms of flashing and stepping through the code at breakpoints.
simma
-Given: 24
« Reply #6 on: August 22, 2020, 03:11:32 15:11 »
I agree with Mr Spock and mEErEck. You may find STLinkReflash.exe refuse to upgrade the clones. I used the info from the link in the attachment. It worked for me.
