April 22, 2025, 01:57:52 13:57
Author Topic: Watch speaks the hours  (Read 5702 times)
o_cientista
« on: May 15, 2012, 01:09:13 01:09 »
Good morning, friends!
     I want to make a watch that speaks the hours with PIC and CCS C ISD25120 language, but one that is found in BASIC. I wanted to do in CCS C. because he wanted to adapt my usage. Can anyone turn this source code in CCS C? Thank you.
Agui is the link of the project and the source code below: http://www.freewebs.com/glafebre/relojparlante.htm
'PIC a utilizar
Device 16F871
'Frecuencia
XTAL 4
'declaracion del LCD
Declare LCD_TYPE 0
Declare LCD_DTPIN PORTC.4
Declare LCD_ENPIN PORTC.2
Declare LCD_RSPIN PORTC.3
Declare LCD_INTERFACE 4
Declare LCD_LINES 2
'teclado matricial
Declare KEYPAD_PORT PORTD
'---- DECLARACION DE LOS PINES DEL BUS I2C -------
SCL_PIN   = PORTB.7
SDA_PIN   = PORTB.6
'todos los puertos digitales
ALL_DIGITAL true
'variables
Dim tecla As Byte
Dim cont As Byte
Dim cont1 As Byte
Dim var1 As Byte
Dim segu As Byte
Dim minu As Byte
Dim hora As Byte
Dim minu1 As Byte
Dim minu2 As Byte
Dim diaS As Byte
Dim diaF As Byte
Dim mes  As Byte
Dim anio As Byte
Dim eeprom As Byte
Dim control As Byte
Dim aux As Byte
Dim STRING1[10] As Byte
Dim horario As Bit
Symbol CE = PORTE.0
Symbol PD = PORTE.1
Symbol PR = PORTE.2
Symbol EOM = PORTC.0
TRISA = 0
DelayMS 500
cont=0
cont1=0
Cls
PORTA = 0
High CE
GoSub grabar_RTC
'Programa principal
inicio:
    GoSub leer_RTC
    tecla = InKey
    Print At 1,12,DEC2 cont,"-"
    Print At 1,15,DEC2 cont1,
    Select Case tecla
        Case 0:  'para grabar
            GoSub antirebote 'antirebote de tecla
            GoSub grabar
        Case 1:  'para reproducir el msg seleccionado
            GoSub reproducir
        Case 2
            cont1=cont1+1
        Case 3
            cont1=cont1-1
            If cont1<0 Then
                cont1=0
            EndIf
        Case 5
            GoSub reproducir_HORA
        Case 6
            cont=cont+1
            GoSub antirebote
        Case 7
            cont=cont-1
            If cont<0 Then
                cont=0
            EndIf
            GoSub antirebote
        Case 8
            GoSub antirebote
    EndSelect
    GoTo inicio
'Subrutinas
grabar:
    PORTA=cont
    High PD: DelayMS 10
    Low PR:Low PD:High CE
    Print At 2,1, "LISTO     "
    DelayMS 2000
    Print At 2,1, "AHORA"
    Low CE
    DelayMS 1000
    Print At 2,1, "FINALIZADO"
    High CE
    Return
reproducir:
    PORTA=cont1
    Print At 2,1, "REPRODUCIR"
    High PR: Low PD: Low CE
    While EOM <> 0  'buble para esperar el bajo en EOM para saber
    Wend            'cuando ha finalizado el mensaje
    High CE
    Print At 2,1, "                "
    Return
antirebote:
    While tecla<>16   'antirebote
        tecla=InKey
    Wend
    Return
grabar_RTC:
    BusOut %11010000,0,[$00] 'segundos
    DelayMS 50
    BusOut %11010000,1,[$59]  'mitutos
    DelayMS 50
    BusOut %11010000,2,[$10] 'horas
    DelayMS 50
    BusOut %11010000,3,[$4]  'dia de la semana
    DelayMS 50
    BusOut %11010000,4,[$19] 'dia del mes
    DelayMS 50
    BusOut %11010000,5,[$07] 'mes
    DelayMS 50
    BusOut %11010000,6,[$06] 'año
    DelayMS 50
    BusOut %11010000,7,[$10] 'frec 1hz
    DelayMS 50
    Return
leer_RTC:
    BusIn %11010000,0,[segu]
    BusIn %11010000,1,[minu]
    BusIn %11010000,2,[hora]
    BusIn %11010000,3,[diaS]
    BusIn %11010000,4,[diaF]
    BusIn %11010000,5,[mes]
    BusIn %11010000,6,[anio]
    Print At 1,1, HEX2 hora,":",HEX2 minu,":",HEX2 segu," "
    If diaS=$1 Then Print At 2,1, "Dom."
    If diaS=$2 Then Print At 2,1, "Lun."
    If diaS=$3 Then Print At 2,1, "Mar."
    If diaS=$4 Then Print At 2,1, "Mie."
    If diaS=$5 Then Print At 2,1, "Jue."
    If diaS=$6 Then Print At 2,1, "Vie."
    If diaS=$7 Then Print At 2,1, "Sab."
    Print At 2,6,HEX2 diaF,"/"
    Print At 2,11," /20",HEX2 anio
    If mes=$1 Then Print At 2,9, "Ene"
    If mes=$2 Then Print At 2,9, "Feb"
    If mes=$3 Then Print At 2,9, "Mar"
    If mes=$4 Then Print At 2,9, "Abr"
    If mes=$5 Then Print At 2,9, "May"
    If mes=$6 Then Print At 2,9, "Jun"
    If mes=$7 Then Print At 2,9, "Jul"
    If mes=$8 Then Print At 2,9, "Ago"
    If mes=$9 Then Print At 2,9, "Sep"
    If mes=$10 Then Print At 2,9, "Oct"
    If mes=$11 Then Print At 2,9, "Nov"
    If mes=$12 Then Print At 2,9, "Dic"
    Return
reproducir_HORA:
    GoSub leer_RTC
    '--------------- son
    cont1=21
    GoSub reproducir
    DelayMS 100
    '--------------- las
    cont1=22
    GoSub reproducir
    DelayMS 100
    '--------------- HORAS
    If hora>=10 And hora<32 Then
        hora=hora-6
    EndIf
    If hora>=32 And hora<48 Then '20
        hora=hora-12
    EndIf
    If hora>12 Then
        hora=hora-12
        horario=1
    Else
        horario=0
    EndIf
    cont1=hora
    GoSub reproducir
    DelayMS 100
    '--------------- AM/PM
    If horario=1 Then
        cont1=24
    Else
        cont1=23
    EndIf
    GoSub reproducir
    DelayMS 100
    '--------------- Y
    cont1=20
    GoSub reproducir
    DelayMS 100
    '---------------  MINUTOS
    If minu>=10 And minu<32 Then '10
        minu=minu-6
    EndIf
    If minu>=32 And minu<48 Then '20
        minu=minu-12
    EndIf
    If minu>=48 And minu<64 Then '30
        minu=minu-18
    EndIf
    If minu>=64 And minu<80 Then '40
        minu=minu-24
    EndIf
    If minu>=80 And minu<96 Then '50
        minu=minu-30
    EndIf
    Select Case minu
        Case 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15
            cont1=minu
            GoSub reproducir
        Case Else
            minu2=Dig minu, 1
            minu2=minu2*10
            cont1=minu2
            Select Case cont1
                Case 20
                    cont1=16
                Case 30
                    cont1=17
                Case 40
                    cont1=18
                Case 50
                    cont1=19
            EndSelect
            GoSub reproducir
            DelayMS 100
            If minu<>20 And minu<>30 And minu<>40 And minu<>50 Then
                cont1=20
                GoSub reproducir
                DelayMS 100
                minu1=Dig minu, 0
                cont1=minu1
                GoSub reproducir
            EndIf
        EndSelect
        DelayMS 100
    '--------------- MINUTOS (PALABRA)
    cont1=25
    GoSub reproducir
    Return
End
« Reply #1 on: May 19, 2012, 11:22:02 23:22 »
google is your friend
