November 25, 2024, 05:00:45 05:00
Author Topic: GTP-Lite and Win Vista Working ?  (Read 4673 times)
GreenGiant
« on: August 12, 2007, 01:54:51 01:54 »
Anyone figured out how to use the GTP-Lite on windows vista ?
That is, found a working driver?
Seems the Microchip Generic USB driver (mchpusb) is not Vista compatible.
softjad
-Given: 12
-Receive: 95
« Reply #1 on: August 21, 2007, 08:41:13 20:41 »
Hello
GTP-Lite NO Work correctly on windows vista, but the mchpusb working fine!
I tryed the USB driver and aplications (in C#) on W.Vista and I never had problems.
 Wink
GreenGiant
« Reply #2 on: August 23, 2007, 08:11:44 08:11 »
Mind sharing the link/files for mchpusb and vista that you are using ?
Specifically the .inf and .dll/sys
If the mchpusb driver works properly on Vista (or a derivative) then GTP-Lite will also work as it uses standard functions in the mchpusb drivers (just requires some minor edits of the genric .inf) . I simply cant find a set of mchpusb drivers that donot give an error 10 code on vista.
softjad
-Given: 12
-Receive: 95
« Reply #3 on: August 23, 2007, 08:49:54 20:49 »
For WindowsXP and Windows Vista:
Try it
http://blogs.msdn.com/peterwie/archive/2007/01/10/fixing-the-umdf-usb-samples-to-install-both-on-xp-vista.aspx
softjad
-Given: 12
-Receive: 95
« Reply #4 on: August 30, 2007, 10:36:19 22:36 »
add this file to the window XP driver and try in windows Vista....
WAYNE25
« Reply #5 on: January 15, 2008, 08:26:59 08:26 »
The gtp work on win vista check the next link http://www.hobbypic.com this page is spanish
