November 28, 2024, 08:53:57 08:53
Author Topic: Need data sheet of JQX-30F(T91)  (Read 6362 times)
MAXPAYNE
-Given: 499
-Receive: 364
It's a little funny......
« on: May 05, 2012, 05:48:46 05:48 »
Does anybody have this power relay datasheet ?
http://www.lampfind.com/lampby_1716620_PCB-Relay-JQX-30F.htm
flyback
-Given: 73
-Receive: 39
« Reply #1 on: May 05, 2012, 07:16:44 07:16 »
Takes a l@@k at
http://www.china-relay.com/PCB-relay/index.html
there is a pdf for your model
Bests
MAXPAYNE
-Given: 499
-Receive: 364
« Reply #2 on: May 05, 2012, 08:11:39 08:11 »
Takes a l@@k at
Bests
I chked the page already and didn't find any pdf related to this model there. Sad
flyback
-Given: 73
-Receive: 39
« Reply #3 on: May 05, 2012, 10:12:55 10:12 »
Hi Maxpayne
Should be a standard type. Here a spec from a very similar model
Good luck.
PaulC
-Given: 3935
« Reply #4 on: May 05, 2012, 11:08:53 23:08 »
Hi MAXPAYNE
Power Relay (JQX-30F),automation relay, pcb relay
Model:JQX-30F
Dimension(mm):L31×W52×H48
Contact Form:2Z 2H 2D
Contact Material:Ag Alloy
Contact Capacity:30A 30VDC 30A 250VAC
Coil Nominal Power:DC2W AC4.5VA
Coil Nominal Voltage:6110VDC 6200VAC
Pick-up Voltage:DC≤75% AC≤80%
Drop-out Voltage:DC≥10% AC≥30% Max. Voltage:110%
Contact Resistance(at 6VDC 1A):≤100mΩ
Dielectric Strength Between Open Contacts:≥1000VAC 50Hz/1min
Dielectric Strength Between Contacts Pieces:≥1500VAC 50Hz/1min
Dielectric Strength Between Coil & Contacts:≥1500VAC 50Hz/1min
Insulation Resistance at 500VDC:≥1000Ω Ambient Temperature:-25°C+55°C
Terminal type:Welding Type Product Weight:85g
Features:
Model: JQX-30F(T93)
1) Outline dimensions: 32.1*26.9*20.0mm
2) Contact data:
a) Contact arrangement: 1A 1C 1B
b) Material: silver alloy
3) Max. switching current: 25A 30A
4) Max. switching voltage: 28V DC / 250V AC
Max. switching power: 840W/7.5KVA
Rated load(Resistive): 20 30A/250VAC
5) Coil data:
a) Nominal voltage: 3-110VDC/6-240VDC
b) Pick-up voltage:DC ≤75% AC ≤80%
c) Drop-out voltage: DC ≤10% AC ≤30%
d) Coil power: 0.9W
6) Specifications data:
a) Contact resistance: ≤50mΩ
b) Insulation resistance:≥5100MΩ
c) Dielectric strength Vr.m.s:
i) Between open contacts: ≥1500VAC
ii) Between coil and contacts: ≥2500VAC
iii) Between contacts form: ≥2000VAC
d) Ambient temperature: -55 - +100oC
e) Operation/release time: ≤15/10ms
Only getting the same info from everywhere i searched for
Hopes this helps
titi
-Given: 3807
-Receive: 834
« Reply #5 on: May 06, 2012, 09:06:52 09:06 »
This is a datasheet for JQX-30F
Best regards.
