November 23, 2024, 01:01:44 13:01
Author Topic: cant communicate pc to pic  (Read 3638 times)
hsny
« on: August 11, 2007, 05:33:38 17:33 »
this serin doesnt work.I use max232 and get the characters on hyperterminal but cant on led.
please help.
T2400 con 0
serindata var byte
SerOut PORTB.0 , T2400 , ["1-PORTA.0 Yuksek Yap ",13,10]
SerOut PORTB.0 , T2400 , ["2-PORTA.0 Dusuk Yap",13,10]
SerOut PORTB.0 , T2400 , ["3-Program Sonu",13,10]
loop:
 SerIn PORTB.1 , T2400 , [serindata]
    select case serindata
       case "1"
       high PORTA.0
       case "2"
       low PORTA.0
       case "3"
       serout PORTB.0 , T2400 , ["Program sonlandi.",13,10]
       end
   end select
GoTo loop
3d_man
-Given: 22
« Reply #1 on: August 16, 2007, 09:56:42 09:56 »
first verify from your hardware connection and correct COM# then write simple code to show hardware good
TRISC = %00000000
serout portc.6 , T2400 , ["HELLO "]
 Wink
Ikaros
-Given: 422
-Receive: 48
« Reply #2 on: August 31, 2007, 10:27:36 10:27 »
The program just wait one character and then ends. May be is better to make a loop to continually read the Serial Input?
Also are you sure about your hardware connections?
Ret12_12
-Given: 104
-Receive: 32
« Reply #3 on: August 31, 2007, 07:43:59 19:43 »
If you try case 1 instead of "1" also proton you said  DEC serindata .....
You can have RS232 com. without have the MAX232
SerOut PORTB.0 , 16780 , ["1-PORTA.0 Yuksek Yap ",13,10]  ' transmite to 2400 with a serious res 1k to pin 2 in pc side (9 pin)
mcr
-Given: 217
-Receive: 23
« Reply #4 on: August 31, 2007, 09:34:22 21:34 »
please help.
T2400 con 0
serindata var byte
loop:
       case "1"
       high PORTA.0
       case "2"
       low PORTA.0
       case "3"
       end
   end select
GoTo loop
Remove the END there, that might help.
Rahos
-Given: 36
-Receive: 32
« Reply #5 on: September 01, 2007, 05:45:27 05:45 »
Use Serout2/Serin2 and direct connection to pic ( not with MAX232)
« Last Edit: September 01, 2007, 05:47:04 05:47 by Rahos » Logged
mcr
-Given: 217
-Receive: 23
« Reply #6 on: September 01, 2007, 05:08:06 17:08 »
Forgot about that  Embarrassed
But still, If you use a MAX232 the information should be displayed, does not matter if it's correct or not.
Rego
-Receive: 320
The power is back
« Reply #7 on: September 01, 2007, 05:12:02 17:12 »
yea ,i think the error is from that (end)
Smiley ....THE POWER IS BACK.... Smiley
....REGO....
hsny
« Reply #8 on: September 03, 2007, 03:52:14 15:52 »
Thank you for all.
I change
T2400 con 0 with include "modedefs.bas"
serin portb.1,T2400,[serindata] with serin portb.1,T2400,serindata
I use 16f84,max232
pic pin7 - max232 pin 9  -  max232 pin8 -  dbp pin 3
pic pin6 - max232 pin 10 - max232 pin7  - db9 pin 2
pic pin17-led
I coludnt high or low led on hyperterminal.I get characters on pc side however.So I used a program named terminal.
Then its ok.
