November 24, 2024, 01:03:29 13:03
Author Topic: Microcontroller Programmar  (Read 7872 times)
MAXPAYNE
-Given: 499
-Receive: 364
It's a little funny......
« on: August 02, 2007, 10:03:44 10:03 »
Can you say which programmer is best for pic16f88, 16f628a, 16f876a, 16f877a
JDM Programmer,RCD programmer, Multi pic prog 5.2, propic ,EPIC ? which also supports winpic800?
or any other progrmammer u r using ?? Huh Huh
zawmintun1
-Given: 2139
-Receive: 26
« Reply #1 on: August 02, 2007, 10:51:38 10:51 »
You can use David Tait's serial Programmer & WinPIC 800 Software
In Software you can set as ProPIC2 & Invert MCLR ,Invert Vcc Pins in LPT1 &h378
I used it very well & can be used also 18FxxxSeries
Best
OK
hate
-Given: 156
-Receive: 355
« Reply #2 on: August 02, 2007, 12:24:36 12:24 »
I use EPIC because of its external voltage support which helps a lot powering the target board while programming ICSP. It supports 18f series and also you can add your new devices to the config file if it is not currently supported! For 24f devices I think ICD2 is the best also with a debugger!
Regards...
Regards...
tango
-Given: 28
« Reply #3 on: August 02, 2007, 11:21:47 23:21 »
Hi to all,
I have many programmer's in colection also (ALL07 - fabricate programmer)...
Extra is PICkit2 also ICD2 but if you want low cost programmer use EPIC plus programmer
because it support almost all picmicro and if you little modificate it you will have extra
low cost and good programmer.
Use it with EPICWIN is good but with WINPIC800 is extra produse programmer !
In WINPIC800 you can edit .ini file and you will have support for almost all picmicro.
If you little modificate Vdd and Vpp voltage you can program low voltage device to.
Now any suggest for me anybody can tell me hove to wire ZIF 40 to support most picmicro
without jumpers and swich and to use only one Vpp.
I know to is very hard but i wait any suggest.
Many thank's to all on forum.
MAXPAYNE
-Given: 499
-Receive: 364
« Reply #4 on: August 05, 2007, 05:35:04 05:35 »
I am new to PIC and want to play with it. So I need to build a programmer. Please advice me which programmer should I build considering most supported device including PIC18F, which also supports WINPIC800, heard it is very handy than ic-prog. Found this PIC programmer based on JDM programmer and seems handy to me because it supports both LVP and HVP. Does anybody used this programmer ? Does it supports winpic800 ? If so how to configure ?
http://feng3.cool.ne.jp/en/pg5v2.html
Thanks in advance...... Cool Cool
rahulmr
« Reply #5 on: August 07, 2007, 02:20:34 02:20 »
yes i have used his pro in fen
feng
i am using it now.
no problem with the programmer and it also supports winpic800 winpic but i think winpic800 is preferabble
MAXPAYNE
-Given: 499
-Receive: 364
« Reply #6 on: August 08, 2007, 07:45:12 07:45 »
Thanks rahulmr,
   Can u give more details abt how to configure winpic800 with multipic prog ? Cool Cool
ennio
-Receive: 15
« Reply #7 on: August 09, 2007, 04:40:54 04:40 »
Hi MAX
I believe that multipic does not support LVP
Anyway I suggest PicPGM, is but slow but it works well
ennio
Sorry for my bad english
mehdi65
« Reply #8 on: August 09, 2007, 09:46:45 09:46 »
hi
best programmer's for pic (programmer's)
winpic800,epic,propicxp(with keygen),icprog,pic18fxxxx
downloads
http://www.parsaspace.com/kavirelectronic//PROGRAMMERS/PIC/
PASS:www.kavirelectronic.ir
pls run setup then see software for programmers
this is help farsi
exm my en
MAXPAYNE
-Given: 499
-Receive: 364
« Reply #9 on: August 13, 2007, 07:15:11 07:15 »
Thank u... Grin Grin Grin Grin
MAXPAYNE
-Given: 499
-Receive: 364
« Reply #10 on: August 13, 2007, 07:18:05 07:18 »
Thanks a lot.... Cool Cool Cool
cwiliam
« Reply #11 on: September 06, 2007, 02:35:48 02:35 »
checkout  www.mcumall.com
-Given: 405
-Receive: 545
« Reply #12 on: September 06, 2007, 03:48:40 15:48 »
here's a link for a really good and cheap adpter board for programmers,buy a PICKIT 2 and this adapter and you'll be all set to program one heck of alot of pic's
http://cgi.ebay.ca/High-quality-Universal-Programmer-Development-Board_W0QQitemZ330161492934QQihZ014QQcategoryZ4661QQcmdZViewItem
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en023805
NEOMAT
Translator
 Warned
-Given: 11
-Receive: 12
« Reply #13 on: September 06, 2007, 04:51:10 16:51 »
hi
downloads
this is help farsi
exm my en
Friend this link expired, you can post again?
mehdi65
« Reply #14 on: September 11, 2007, 09:45:37 09:45 »
hi
http://kavirelectronic.parsaspace.com/PROGRAMMERS/PIC/Setup.sfx.part1.exe
http://kavirelectronic.parsaspace.com/PROGRAMMERS/PIC/Setup.sfx.part2.rar
http://kavirelectronic.parsaspace.com/PROGRAMMERS/PIC/Setup.sfx.part3.rar
http://kavirelectronic.parsaspace.com/PROGRAMMERS/PIC/Setup.sfx.part4.rar
http://kavirelectronic.parsaspace.com/PROGRAMMERS/PIC/Setup.sfx.part5.rar
 Wink
zawmintun1
-Given: 2139
-Receive: 26
« Reply #15 on: September 15, 2007, 04:57:39 16:57 »
Where Password Bro
Pls
OK PASS:(www.kavirelectronic.ir )?
Thank a Lot
« Last Edit: September 15, 2007, 05:01:13 17:01 by zawmintun1 » Logged
techno
-Given: 809
-Receive: 132
« Reply #16 on: September 17, 2007, 03:53:30 15:53 »
the pass is only www.kavirelectronic.ir
Vague
-Given: 699
-Receive: 29
« Reply #17 on: September 18, 2007, 09:59:03 09:59 »
I can endorse the advice to buy a pickit2. Over the years I have made many DIY programmers, but they all had some limitations finally I bought a pickit 2. Microchip upgrade the software and firmware frequently and it can now program a large selection of pics. The amount of money I have spent over the years building DIY programmers would have paid for several pickit2s.
MAXPAYNE
-Given: 499
-Receive: 364
« Reply #18 on: September 19, 2007, 04:43:14 04:43 »
Use multipic programmer with Winpic800. I am using using it now and seems more than useful. Almost everypic is supported and no external supply required..... Grin Grin Grin
