December 23, 2024, 03:47:58 15:47
Pages: 1 [2]  All
Author Topic: REQ: CCS-C PCWH 4.056 update  (Read 16045 times)
godblessu
-Given: 133
-Receive: 297
« Reply #25 on: August 20, 2007, 11:57:22 11:57 »
Please put 4.049 on Rapidshare network
http://rapidshare.com/files/49965500/image_files.rar
Password: www.sonsivri.com
« Last Edit: August 20, 2007, 12:46:29 12:46 by godblessu » Logged
ducky2002
« Reply #26 on: August 20, 2007, 04:35:40 16:35 »
Thanks....seems to be the real 4.049...no virus detected.
Good job.
cyber_drifter
-Given: 167
-Receive: 32
« Reply #27 on: August 20, 2007, 06:05:59 18:05 »
Think I'll wait till version 100.001 comes out and all the bugs are fixed lol
cerebronico
-Given: 264
-Receive: 27
« Reply #28 on: August 20, 2007, 07:35:38 19:35 »
I can't keep this pace, current release as of today is 4.052!
I can't imagine what is going in CCS's people's minds, they fix some bugs and create new ones??
really this is a crap compiler
 Huh Huh Huh
GreenGiant
« Reply #29 on: August 20, 2007, 11:53:25 23:53 »
People ALWAYS request the newest version as it comes out.
Go check http://www.ccsinfo.com/devices.php?page=versioninfo
See if you REALLY need the update.
All the updates have been bug fixes, not new features, so most likely you DONT need the update unless it affects something your using already and see a problem with.
IE. the .51 just posted, has an ADC bug. So now will you be demanding that someone post .52 ?
mayli
-Given: 12
-Receive: 30
« Reply #30 on: August 21, 2007, 07:44:49 07:44 »
Now the most update version is 5.2.
Can anyone upload the update to here?
The Update can soft AD convert module bugs Cheesy
softjad
-Given: 12
-Receive: 95
« Reply #31 on: August 21, 2007, 08:29:49 20:29 »
It is always difficult to find the most recent versions...
ahmadexp
-Receive: 12
« Reply #32 on: August 22, 2007, 11:03:52 11:03 »
note : CCS449 is only PCWH and not PCWHD , is't mean that your complier is not ready for dsPIC or PIC24
also i think this version is not realy 4.049 and is 4.038 thatwas edited with resource tunner 0.95
take care Wink
mayli
-Given: 12
-Receive: 30
« Reply #33 on: August 23, 2007, 08:35:19 20:35 »
The most update version is 4.053. Can anybody provide download link?
 Cheesy
Thank you
venda
-Given: 556
-Receive: 89
« Reply #34 on: August 25, 2007, 05:45:53 05:45 »
thanks Smiley
tavioman
« Reply #35 on: August 29, 2007, 07:28:40 19:28 »
Hey, PUMA why don't you use HiTech C?
It's a much better compiler.
Recently I have made a really big project with CCS and I was really dissapointed. Many many bugs in CCS.
Even for some simple stuff. Myself I will switch to hitech or IAR. It does not matter if they are expensive anyway. You don't pay nothing for them as log as sonsivri will exist.
So, do something smart and start using HiTech. It's a better choice.
- Brain juice -
softjad
-Given: 12
-Receive: 95
« Reply #36 on: August 29, 2007, 08:22:42 20:22 »
the better choice... or not...
godblessu
-Given: 133
-Receive: 297
« Reply #37 on: August 29, 2007, 08:33:54 20:33 »
I tried to use CCS and really has many BUGS. I think MIKROC or HITECH is better.
softjad
-Given: 12
-Receive: 95
« Reply #38 on: August 30, 2007, 10:22:43 22:22 »
I prefer CCS... for me it is better, but each one chooses what wants to use. I never had problems with this.
 Undecided
ysy
« Reply #39 on: August 31, 2007, 03:26:48 03:26 »
ccs is a buggy software, its lib source code isnot open. iar hitech, even mcc18 are better than ccs.
 its extensive C keywords confuses me, code isn‘t portable.
tavioman
« Reply #40 on: August 31, 2007, 07:25:04 07:25 »
@PUMA
I never work with Mplab.
I'm using Visual Studio as an editor. It's much more easy.
VS2005 it's a very powerful editor.
I'm using VS2005 for CCS and for HiTech.
I don't like MPLAB.
- Brain juice -
Robi
-Given: 54
« Reply #41 on: September 01, 2007, 01:39:46 13:39 »
OK tavioman, we have understood that HiTech C is your preferred compiler and I cannot blame you for this as its really a better product compared to CCS. HOWEVER, are you aware that latest HT_PICC960_Crack won't work with latest PICC demo 9.60 ??
The latest picc (demo) version is here for others to use (or crack it hopefully).
http://rapidshare.com/files/52656220/picc-demo_960.zip.html
« Last Edit: September 01, 2007, 01:43:53 13:43 by Robi » Logged
iso
« Reply #42 on: September 01, 2007, 03:09:52 15:09 »
one more advantage of ccs picc is  abilty of produce coff file. this case you can simulate your project with proteus isis. you also can do this with hi-tech but cant with micro c.am i true?
tavioman
« Reply #43 on: September 02, 2007, 11:58:48 11:58 »
@ROBI
Why do you need the latest version?
We should make a new section(s) here for each PIC compiler.
We could colaborate and make functions(or macros) for HiTech that look's just like CCS ones.
eg: spi_write, spi_read, eeprom_write, etc...
It's not that hard. If you look at the MPLAB C18 files you will see functions for this things that are 100% ANSI. HiTech it's also 100% ANSI.
If people have trobles with the different data types they could use something like this:
#ifdef CCS_COMPILER
#ifdef CCS_COMPILER
typedef int8 UNSIGNED8
typedef signed int8 SIGNED8
typedef int16 UNSIGNED16
typedef signed int16 SIGNED16
#elif defined HI_TECH_COMPILER
typedef unsigned char UNSIGNED8
typedef signed char SIGNED8
#elif defined MPLAB_C18_COMPILER
#endif
And simply define the compiler at the beggining of the code.
After that use the new typedefs:
UNSIGNED8 foo = 234;
- Brain juice -
GreenGiant
« Reply #44 on: September 02, 2007, 04:31:43 16:31 »
While we veering oftopic, id be willing to help out with that noted by tavioman.
Robi
-Given: 54
« Reply #45 on: September 02, 2007, 11:28:11 23:28 »
Which latest version ? CCS ? I don't want latest CCS. Just asked if someone has a new crack for Hitech picc 9.60 because old one does not work anymore. I knew that C18 and Hitech are both full ANSII. I did not ask that.
etm503
« Reply #46 on: September 03, 2007, 11:56:05 11:56 »
@PUMA
I don't like MPLAB.
Hie,
Is it possible to do any simulation with VS2005 like Mplab does? Like proteus integration as a simulation tool?
tavioman
« Reply #47 on: September 03, 2007, 12:46:08 12:46 »
It's not possible to do this direct but you could make a command line for launching either Proteus or MPLAB and simply hit debug button on VS.
But I never do this. I simply load the hex or cof file into Proteus.
- Brain juice -
xzb
-Given: 16
« Reply #48 on: September 14, 2007, 04:11:44 16:11 »
who have CCS-C PCWH 4.053 ?
cyber_drifter
-Given: 167
-Receive: 32
« Reply #49 on: September 15, 2007, 02:00:41 02:00 »
Is it version 4.053 already? I just updated to 4.049. I can't keep up with all the updates  Grin
Pages: 1 [2]  All
