February 22, 2025, 10:06:12 10:06
Author Topic: Assembler interrupts in Proton+  (Read 5913 times)
FranzW
-Given: 589
-Receive: 81
« on: January 31, 2012, 10:51:08 22:51 »
I need to count fast incoming encoder pulses by means of interrupts on PORTB.7. Does somebody know what must I do in order to place my interrupt routine at ORG 4, the interrupt vector address? If I use ORG 04 in the program below, Proton issues the error message: “Overwriting previous address contents (0004)”
Part of the program can be seen below.
Device = 16F877A
Declare Xtal = 4
All_Digital = true
Dim Pulses As Word 'To store RB7 interrupts
TRISB = %11111001
' OTHER VARIABLES, TRIS, etc. WILL BE DECLARED HERE.
'Making place to save the required registers during the interrupt.
'Since I didn’t find anything about this in the Proton manual,
'I created room to save the registers, as stated in the PBP V 2.46 manual.
Asm
     W0 equ 0x0020 'bank 0 place For W
     S0 equ 0x0021 'bank 0 place for STATUS
     P0 equ 0x0022 'bank 0 place for PCLATH
     W1 equ 0x00A0 'bank 1 place for W
     W2 equ 0x0120 'bank 2 place For W
     W3 equ 0x01A0 'bank 3 place For W
EndAsm
GoTo Program 'Jump over the interrupt routine
'*************Interrupt routine
Asm
   'Save registers
   Movwf W0
   Swapf STATUS, w
   Clrf STATUS
   Movwf S0
   Movf PCLATH, w
   Movwf P0
   'The interrupt code will be placed here.
   'Restore registers
   Movf P0, w
   Movwf PCLATH
   Swapf S0, w
   Movwf STATUS
   Swapf W0, f
   Swapf W0, w
   Retfie
EndAsm
Program:
'Program code is placed here.
-Given: 839
-Receive: 4336
« Reply #1 on: January 31, 2012, 10:55:16 22:55 »
see if this helps you.  see post #14
http://www.protonbasic.co.uk/showthread.php/61133-TMR0-question/page2?highlight=interupts+16F877A
FranzW
-Given: 589
-Receive: 81
« Reply #2 on: January 31, 2012, 11:37:27 23:37 »
Dear pickit2,
Thanks for your help.
On_Interrupt is used in post #14. The manual says that when On_interrupt is used, the incoming interruption just sets a flag, and the interruption routine will be executed after the current basic instruction has ended (and not immediately).
The PIC is also driving five multiplexed seven-segment displays. Each display is on for 3 ms, so if I used On_Interrupt, I would have to break the delayms 3 into hundreds of delayus in a for-next loop.
That is why I wanted to use an assembler interrupt routine. But there seems to be no way of telling Proton that the assembler routine should be placed at Org 4.
I will try using the for-next loop, and see what happens.
FranzW
« Last Edit: February 01, 2012, 09:50:03 09:50 by FranzW » Logged
zuisti
-Given: 242
-Receive: 780
« Reply #3 on: February 01, 2012, 09:54:53 09:54 »
Hi FranzW;
There is a method to what you want:
(the register's save-restore is also automatic, see the help file)
    Declare FSR_CONTEXT_SAVE = OFF ' If it is not used in the IT routine
    On_Hardware_Interrupt GoTo IT_Routine
    Goto Start
IT_Routine:
  .... may be also asm
    Context Restore ' restore regs and return from interrupt
Start:
-Given: 496
« Reply #4 on: February 01, 2012, 09:56:26 21:56 »
I believe you do not have to tell Proton to place the interrupt handler on Org 4.
Simply point it to a label and Proton will sort the interrupt addressing out.
