Thanks ipek. but mm5369 is no longer available....
70 currently available here.
Seller ships worldwide.
http://cgi.ebay.com/MM5369-Precision-60-Cycle-Square-Wave-Generator-5369_W0QQitemZ150143960727QQcmdZViewItemThe PIC-based 60 Hz generator uses a 16F84 which currently sell for $6.13 US in quantity 1.
What is wrong with you maxpayne? You asked for help and someone was nice enough to supply
two workable solutions. He even provided a direct link to the source code but they were not good enough.
Is this what you're looking for: "
maxpain, go outside and find two little twigs and tie them together with a bit of string. There, you have a 60 Hz generator accurate to +/- 10 ppm over the industrial temperature range."
