December 14, 2025, 10:44:43 22:44
Author Topic: Anybody old enough to know what is FZH161 IC?  (Read 5514 times)
cerebronico
-Given: 265
-Receive: 27
« on: December 17, 2011, 02:26:45 14:26 »
I been googling it but I haven't found any datasheet, if somebody knows what is the function of this IC, please give some advice.
thanks
c
leptro
-Given: 639
-Receive: 26
« Reply #1 on: December 17, 2011, 03:43:36 15:43 »
please try this : http://www.seekic.com/pdf/pdf_down.asp?id=1134519
this is from my google  Wink
hopes this will hep even if we haven't a lot of information.
cerebronico
-Given: 265
-Receive: 27
« Reply #2 on: December 17, 2011, 04:21:59 16:21 »
I already have this datasheet, but it refers only to calculation of the load resistance been similar to that of the FZH161, not it's function
Thanks for your kindly help
c
TomJackson69
-Receive: 63
« Reply #3 on: December 17, 2011, 06:32:59 18:32 »
Try this link:
http://www.eca.de/html/FZH/FZH161.html
But you have to be a member to login. I am not a member and don't want to be one.
Con Rong Chau Tien
« Reply #4 on: December 17, 2011, 07:19:48 19:19 »
Please share what you find, here.
jzaghal
-Given: 507
-Receive: 55
« Reply #5 on: December 17, 2011, 07:21:28 19:21 »
Maybe this can help you;
FZH161 - 4x 2 input NAND, the transition from LSL at TTL levels
[1 - common in. layout. 1 and 2], [2 - in the second. ukł.1; 3-N1, 4-Q1], [5 - in the second. ukł.2; 6-N2, 7-Q2], 8 - "-" Tray., [9-Q3; 10-N3 in 11-second. ukł.3], [12-Q4; 13-N4, 14-second in. ukł.4], [15-joint in. ukł.3 and 4}, 16 - "U +" Tray ..
max. At 18V supply, the typical 350 ns delay.
