You think I am funny guy huh?
April 26, 2026, 03:14:27 03:14
Author Topic: using p/button switch to count input (16F876A)  (Read 6836 times)
sebaloq
« on: July 10, 2007, 03:17:25 03:17 »
hello... i really need ur help and guidance.. i was trying to develop a program by using Proton Basic to count an input switch (push button). As an example if the same p/button (assume portd.0) been pressed 3 times an LED (assume portb.0) will be light on. Pls help me... thanks a lot Smiley
raraavis
-Receive: 12
Buenos Aires - Argentina
« Reply #1 on: July 10, 2007, 01:00:23 13:00 »
Check This:  Wink
COUNTER
Syntax
Variable = COUNTER Pin , Period
Overview
Count the number of pulses that appear on pin during period, and store the result in variable.
Operators
Variable - a user-defined variable.
Pin - a Port.Pin constant declaration i.e. PORTA.0.
Period - a constant, variable, or expression.
Example
 ' Count the pulses that occur on PORTA.0 within a 100ms period and displays the results.
 DIM WRD as WORD          ' Declare a word size variable
 SYMBOL Pin = PORTA.0     ' Assign the input pin to PORTA.0
 CLS
Loop:
 WRD = COUNTER Pin , 100  ' Variable WRD now contains the Count
 CURSOR 1 , 1
 PRINT DEC WRD , " "      ' Display the decimal result on the LCD
 GOTO Loop                ' Do it indefinitely
Notes
The resolution of period is in milliseconds (ms). It obtains its scaling from the oscillator declaration, Declare XTAL.  Counter checks the state of the pin in a concise loop, and counts the rising edge of a transition (low to high).
With a 4MHz oscillator, the pin is checked every 20us, and every 4us with a 20MHz oscillator. From this we can determine that the highest frequency of pulses that may be counted is: -
25KHz using a 4MHz oscillator.
125KHz using a 20MHz oscillator.
« Last Edit: July 10, 2007, 01:04:48 13:04 by raraavis » Logged
kalpakchiev
-Given: 34
-Receive: 68
« Reply #2 on: September 03, 2007, 09:41:37 21:41 »
It will look like this in PicBasic
Count VAR Byte
Buton VAR PortD.0
Tris PortD.0=1' make it an input
Led VAR PortB.0
Tris PortB.0=0' make it an output
Count=0
led=0
Start:
If buton=0 then
   pause 50
     if buton=0 then
        count=count+1
     endif
endif
if count=3 then
  led=1
endif
goto start
You have to add also some code to turn off the led. It depends on condition You want.
-Given: 582
« Reply #3 on: September 03, 2007, 09:57:19 21:57 »
Your lucky to get the replies like you haev your first post and you ask someone to write code for you, there are plenty of ways to do it
some advise:
1. Read up on what you want to do
2.seearch the PDS forums for code
3. WE will help all that come here for help if you show us your code you have already wrote that don't work we then can give you giudance in the right direction and get your code working. You should not expect ohters to write code for you that way you will never learn.
Please note it's not my intention to start a war these are my thoughts and opinion's
welcomne to our community
wizpic
iphone
-Given: 115
« Reply #4 on: September 04, 2007, 11:35:43 11:35 »
raraavis,
Thanks for the sample.
BTW, how you calculate max freq as you said ... Fmax = 25khz for 4Mhz Osc and Fmax = 125kHz for 20Mhx Osc ?
Actually this code what I'm looking for ... I need the PIC response when the push button being push ( maybe for rising edge transition) in very manner.
Thanks friend.
