wild
-Given: 641
-Receive: 452
« Reply #175 on: May 08, 2020, 09:46:23 09:46 » |
buy the J-Link EDU ORIGINAL one! The difference of price is not so high compared to the clones (no warranties at all). Latest HW version of the original is v11. I do not suggest to buy the EDU mini because is much slower.
rajhlinux
« Reply #176 on: May 18, 2020, 11:33:36 23:33 » |
Thanks for replying, would you happen to know where I could buy V11 original edu?
All edu original starts around $63 before shipping and tax.
Also, I could take the EDU original and convert it to the regular J-Link version, right? By flashing the firmware?
« Last Edit: May 19, 2020, 12:04:16 00:04 by rajhlinux »
wild
-Given: 641
-Receive: 452
« Reply #177 on: May 20, 2020, 06:22:57 18:22 » |
I do not know where you live, but you can find J-Link EDU at least at Digikey, RS, Mouser, Adafruit, ... From what I know, there are NO differences between EDU and regular one. Just you have to get rid of the once a day nag screen. On RS the total price is 70 Euros, Shipping and taxes included (22% VAT here in Italy) On Digikey is 71.55 Euros (shipping and taxes to Italy included)
« Last Edit: May 20, 2020, 06:29:51 18:29 by wild »
millegps
-Given: 38
« Reply #178 on: May 20, 2020, 06:48:17 18:48 » |
Attached you can find a link for model comparison. edu and base is pretty much the same. On edu version you have also unlimited breakpoints. You don't have J-Flash license, which is included in jflash plus, so you can't use jflash utility, but you can do debug and program internal flash of MCU the official Jlink looks as if the price has increased. but my understanding of the regular version and the edu, was they are the same. to buy and use the edu version was on trust. they issue a note saying not for commercial use.
eng.elec
« Reply #179 on: July 23, 2020, 10:55:59 10:55 » |
J-link V10 Firmware,
nik80
« Reply #180 on: November 07, 2020, 02:59:41 14:59 » |
any idea how to remove "features" added with "exec addfeature flashbp" for example? its a genuine j-link v8 ARM where I added some "features" and now the latest commander say its defective probe it seems "addfeature" add any string there, and I did type it all lower case, may be that is the reason
edit: just tried "exec clearfeatures" which still doesnt work but show different error, it write only "ERR" edit2: downgrading the firmware with j-link ARM 4.20 made "exec clearfeatures" work, now that field is empty, but cant add features anymore, it says "ERROR - Too many features" any ideas?
« Last Edit: November 07, 2020, 07:19:42 19:19 by nik80 »
nik80
« Reply #181 on: November 08, 2020, 01:25:31 13:25 » |
thanks for your suggeston what you mean reflash? firmware update through segger (already did it, still same error) or the same instructions for unbrick with RST and TST pins? what is the chance if I fully reflash with firmware for clone to be recognised as clone some day later?
nik80
« Reply #182 on: November 08, 2020, 02:01:12 14:01 » |
Im really sorry for my stupid question, and thanks for your time, but could you please tell me which way is that "flash to default" ? may be a link to instructions? I know only 2 ways - through segger configurator there is 2 options - firmware update/firmware replace (both doesnt fix the problem) and the other way is with RST and TST pins to fully erase the device and then flash with sam-ba and firmware downloaded from internet, which definitely erase SN and many other things
token0
-Given: 55
-Receive: 97
« Reply #183 on: November 10, 2020, 03:06:14 15:06 » |
iirc, the second way is valid, in the end you need to connect "default" j-link to your pc and set your serial via j-link commander, like that: choose your usb > usb 0 and set desired serial (if it's genuine, then it's real sn is written on the bottom) > exec SetSN=58012345
nik80
« Reply #184 on: November 12, 2020, 10:56:09 10:56 » |
I can see that this is the procedure for clones, flash and replace SN, but some people say that after a while they are bricked by segger software, and need to repeat again what is the possibility that genuine device with genuine SN later to be recognised as clone if I flash it with different firmware downloaded from internet? its the yellow IAR j-link arm v8, Im not using it regularly, from once a month to once a year, and I really dont want next time when I plug it to be bricked
-Given: 841
-Receive: 4364
« Reply #185 on: November 13, 2020, 12:13:46 00:13 » |
clones are not as far as I have heard being bricked, for a few years, even when they were it was a easy fix. as It;s been said 'if you have a genuine unit, it has the serial number on the label' or read if from the software when you connect.
or rise a ticket with segger support.
nik80
« Reply #186 on: November 14, 2020, 01:44:35 01:44 » |
I had some spare time today, and tried after few attempts and no success with 2 different firmwares downloaded from different places (one cant make connection, the other still show defective) I had to edit the bin file to remove all licenses, one that definitely trigger "defective" is RDDI wich was included in one of the bin files, it should be removed, and the other is GDBFULL, it should be only GDB I think so to be safe I did remove them all and then added manually later in commander, now it seems to connect properly with no errors or warnings, in the next few days I will try to connect to real device, to check if still work as programmer/debugger
Ahmad_k
SCG Moderator
-Given: 176
-Receive: 1298
« Reply #187 on: February 07, 2022, 04:47:02 04:47 » |
Does anybody know if I have the J-Link EDU and I used the keygen to add a license for JFlash, will this work ?
h0nk
-Given: 247
« Reply #188 on: February 07, 2022, 01:04:06 13:04 » |
Hello Ahmad_k,
> will this work ?
Yes. You can check Your licenses with "JLinkLicenseManager.exe". But the software will still ask their daily question.
Best Regards
Ahmad_k
SCG Moderator
-Given: 176
-Receive: 1298
« Reply #189 on: February 07, 2022, 01:52:11 13:52 » |
I was searching for those chinese clone J-Link v9 or above, can't find any store other than Aliexpress (blocked in my country). All source found have prices near the genuine EDU version, so I think it is better if I choose the genuine if the keygen is working.
If Anyone have have a source to buy clone v11 I will appreciate it.
CortexM0Inside
-Receive: 36
« Reply #190 on: February 07, 2022, 02:42:56 14:42 » |
Try my JLink BluePill R0 http://www.sonsivri.to/forum/index.php?topic=69113.0
Ahmad_k
SCG Moderator
-Given: 176
-Receive: 1298
« Reply #191 on: February 07, 2022, 05:29:13 17:29 » |
I was using it for a couple of years. I want to upgrade to a better one
vico
« Reply #192 on: July 29, 2022, 07:44:10 19:44 » |
Hello, I got JLINK V8 from Aliexpress in picture below.  Is it possible to upgrade to V9? How I can do that?
baybay
-Given: 15
-Receive: 34
« Reply #193 on: July 30, 2022, 10:42:07 10:42 » |
v8 and v9 hardware completely different, so it is not possible
yahoo
-Given: 56
-Receive: 111
« Reply #194 on: August 08, 2022, 06:19:35 18:19 » |
Simple fix for the latest JLink 7.70
JLink_x64.dll file offset 0xCC238: 90 90 90 90 90 (the original here is E8 53 87 FF FF)
This is for 64bit only and it should remove the procedure for clones. Tested to work fine with a JLink V8 clone.
If I have time, I will see what needs to be done also for JLinkARM.dll to be used for 32bit
mouse5312
« Reply #195 on: November 17, 2022, 10:53:03 10:53 » |
Did you have to time to do the 32 bit version? Or the latest 7.82C?
yahoo
-Given: 56
-Receive: 111
« Reply #196 on: November 17, 2022, 03:16:08 15:16 » |
Did'n have time but checked now for a few seconds I see that on file offset 0xB3D6D (original e8 7e 85 ff ff) must have 90 90 90 90 90. Talking about the latest version 7.82c file JLinkARM.dll for the 32bit support. Not tested but it must work. Let me know if not.
yahoo
-Given: 56
-Receive: 111
« Reply #197 on: May 04, 2023, 12:22:50 12:22 » |
For the latest JLink_Windows_V788a_x86_64.exe the file JLink_x64.dll fix is at offset 0xC81D4: 90 90 90 90 90. I just ordered V9 clone from aliexpress to replace my old JLINK and it will arrive by the end of the month. Is there somebody using V9 and can confirm this patch is good for V9?
tomywong
-Given: 103
-Receive: 213
« Reply #198 on: May 07, 2023, 12:58:36 12:58 » |
Yes, it work on my Jlink v9 clone. Thx.
fonak
-Given: 76
-Receive: 207
« Reply #199 on: May 08, 2023, 03:25:02 15:25 » |
Patch works ok with jlink v9.46 and v11.
The only problem is constantly reporting the need to update the Jlink clone firmware in the Keil environment.
Does anyone know how to disable it, or update the firmware to such a version so that the message does not appear anymore?
« Last Edit: May 08, 2023, 03:29:36 15:29 by fonak »
