tebachi
-Given: 22
« Reply #150 on: November 26, 2018, 06:35:10 18:35 » |
Attached is JLink V6.32g [2018-06-15] I only remove checks on cloned programmers!
thehelpdeskguy
-Given: 8
« Reply #151 on: January 06, 2019, 06:45:17 18:45 » |
I appreciate your efforts. Thank you. (No 'Thank you' button)
HULK69
-Receive: 25
« Reply #152 on: April 02, 2019, 11:43:47 11:43 » |
For all who are using the Jlink edu there is a keygen that works for that: http://www.sonsivri.to/forum/index.php?topic=53313.0
« Last Edit: July 02, 2019, 06:09:27 06:09 by HULK69 »
ChristosSDR
« Reply #153 on: May 11, 2019, 04:17:51 16:17 » |
For all who are using the Jlink edu there is a keygen that works for that: http://www.sonsivri.to/forum/index.php?topic=53313.0 Does this work for the JLink v9 clones?
h0nk
-Given: 247
« Reply #154 on: May 11, 2019, 09:44:53 21:44 » |
> Does this work for the JLink v9 clones? The keygen only creates additional licenses on the computer, not the J-Link. So this should work with v9 clones also.
Best Regards
ChristosSDR
« Reply #155 on: May 12, 2019, 12:29:26 00:29 » |
Best Regards
Ok thank you!, got it now.
wild
-Given: 642
-Receive: 452
« Reply #156 on: June 22, 2019, 01:49:16 01:49 » |
Attached you will find the latest release of Segger J-link utilities (v6.46g) with patched DLLs to: - remove checks on cloned programmers - remove nag screen when using EDU/ST/NXP/... J-Link programmers
Please take care that I was not able to test the patches: now I own only original Segger programmers!
Password as usual!
P.S.: let me know if something is wrong/not working
zulea
« Reply #157 on: March 03, 2020, 04:57:21 16:57 » |
Because I had many troubles with my home used J-Link boxes, I made this. Here is attached latest firmwares for V8 hardware in .BIN format Also correct licenses embedded. All are without any SN, so after flash with Sam-Ba, just run jlink.exe and make "exec SetSN=xxxxxxxx" Some very interested think is that I find inside JlinkARM.dll one newer firmware for Jlink V8 hardware, is identified with: "J-Link ARM V8 compiled Aug 26 2015 15:08:21" Inside archive can find this too (Jlink not make auto update to this, so need use method with jumper erase and upload with Sam-Ba). I tested this newer firmware on some Cortex-M0 and M3 and work well. I really not know why Segger not put in official update (maybe have some bugs or maybe support something that is supported by newer V9/V10 and they not want this on V8 ...)
Tested and work well with latest original Segger utilities (v6.63d) I also dissasembled JlinkARM.dll and find some nice infos: - on both V8 and V9 hardwraee there is not any "cryptography" embedded licenses, just the texts like "GDB", "RDI", ... - on V10 seems that could be something, will come with more info after I will receive my V10 clone - this is the lis with blacklisetd SN from latest DLL version (v6.63d): 11111117 20100214 20090626 20080696 20064001 20101001 24446459 805306163 377001345 270676280 17892859 99999994 286370559
So, please not use any of this when do exec SetSN
Password as usual.
Best regards, Zulea
bobcat1
-Given: 4378
-Receive: 96
« Reply #158 on: March 08, 2020, 10:27:30 10:27 » |
Hi zulea
Where did you buy V10 clone?
Bobi
mars01
-Given: 700
-Receive: 1775
« Reply #159 on: March 08, 2020, 06:07:58 18:07 » |
wild
-Given: 642
-Receive: 452
« Reply #160 on: March 08, 2020, 09:23:00 21:23 » |
For about 15$ more you can buy an original device (J-Link EDU) which HW is v11...
zulea
« Reply #161 on: March 13, 2020, 06:11:08 18:11 » |
I don't think there is any Hardware V11. Here is list of all supported Segger hardware versions extracted fro latest JlinkARM.dll: J-Link OB-STM32F072-128KB-CortexM J-Link OB-STM32F072-CortexM J-Link OB-STM32F072-CortexAR J-Link OB-STM32F103 V1 J-Link OB-SAM3U128 V3 J-Link OB-SAM3U128-V2-NordicSemi J-Link OB-K22-SiFive J-Link OB-K22-NordicSemi J-Link OB-K22-Cortex-M J-Link OB-K22-Cortex-A J-Link Pro V4 J-Link ARM-Pro V3.x J-Link ARM-Pro V1.x J-Link PRO / Flasher PRO V4 J-Link PPC / Flasher PPC V4 J-Link PPC / Flasher PPC V1 J-Link RX / Flasher RX V4 J-Link RX / Flasher RX V1 J-Link / Flasher Portable Plus V1 J-Link / Flasher Portable V1 J-Link ARM / Flasher ARM V4 J-Link ARM / Flasher ARM V3 J-Link ARM / Flasher ARM V2 J-Link / Flasher ATE Module V1 J-Link / Flasher ATE Mainboard V1 J-Link Lite-FSL V1 J-Link Lite-STM32 Rev.1 J-Link ARM-OB STM32 J-Link ARM-STR711 J-Link Lite-LPC Rev.1 J-Link Lite-ADI Rev.1 J-Link ARM-LPC Rev.1 J-Link Lite Synergy J-Link LITE-Cortex-M-5V J-Link Lite-Cortex-M V9 J-Link Lite-Cortex-M V8 J-Link Lite V9 J-Link ARM Lite V8 J-Link ARM-OB SAM7 J-Link ARM V8 J-Link ARM V7 J-Link ARM V6 Rev.5 J-Link WiFi V1 J-Link V10 J-Link V9 J-Link Ultra V4 J-Link Ultra Rev.1 J-Trace PRO V2 Cortex-M J-Trace PRO V2 Cortex J-Trace PRO V1 Cortex-M J-Trace Cortex-M Rev.3 J-Trace ARM CS Rev.1 J-Trace ARM Rev.1 J-Link ARM-LPC2146 Rev.2 Also, here is statement from Segger that currently (at least in 2018) no V11 was planned: https://forum.segger.com/index.php/Thread/5523-SOLVED-Roadmap-hardware-J-Link-EDU/So, do you have an EDU v11? Can post photo from inside of this claimed v11? Thanks, Zulea Posted on: March 13, 2020, 11:52:52 11:52 - Automerged
Hi zulea
Bobi
I cannot give an exact link, ordered via some friends from China. But there is plenty of this on Aliexpress and Ebay, prices are somwhere at 35-45$. If have friends in China, maybe can get cheaper from Taobao. Regards, Zulea Posted on: March 13, 2020, 11:55:46 11:55 - Automerged
Regarding J-Link V11, seems there is some kind of "scam" started by russians, maybe they just changed the ID string inside V10 firmware. Hers some links: https://www.avito.ru/irkutsk/tovary_dlya_kompyutera/otladchik_j-link_v11_segger_novaya_versiya_1835419321https://www.avito.ru/irkutsk/tovary_dlya_kompyutera/segger_j-link_v10_v11_original_1770961504https://www.codetd.com/en/article/6945472So, my statement still is: THERE IS NOT ANY OFFICIAL V11 DIFFERENT HARDWARE Also, from my knowledge, if order EDU version you will receive an V9 hardware (STM32 based, just Full USB, no High speed). Can anybody confirm this info? Thanks, Zulea
wild
-Given: 642
-Receive: 452
« Reply #162 on: March 13, 2020, 08:29:45 20:29 » |
Your statement is rather incorrect: instead of checking old (2018) DLLs, you should take a look at the OFFICIAL documentation by Segger: https://www.segger.com/downloads/jlink/ReleaseNotes_JLink.htmland read at least the release notes to 6.62 version. I do not think V11 is a scam made by Segger! It is "into the wild" at least from November 2019! So it's with a sense of pity and compassion that I feel compelled to attach the proof that the OFFICIAL J-Link V11.0 exists....
« Last Edit: March 13, 2020, 08:36:05 20:36 by wild »
zulea
« Reply #163 on: March 15, 2020, 12:00:20 12:00 » |
I am really sorry, was my mistake and you are completely right. I usually search for compiled ID strings inside JlinkARM.dll, but starting with V10 firmwares Segger store this (not all versions) compressed inside DLL. Now after more research, I even have get one V10 boot + firmware hex file. Maybe you know if I order one Jlink EDU if receive V11 hardware or is not sure?
Thanks and sorry again.
wild
-Given: 642
-Receive: 452
« Reply #164 on: March 15, 2020, 12:08:55 12:08 » |
Ii do not know where are you from: if you live in Europe you can order J-Link EDU from RS* (as I did): http://www.rs-online.com/ they surely have the V11 version in stock. *) they sell also to private persons, not only companies
prnleon
« Reply #165 on: April 19, 2020, 11:19:01 11:19 » |
Sorry guys, I have been reading the whole thread searching for the keygen for EDU probes but the links in the reference post are dead. Has anyone access to it? Thanks in advance!
wild
-Given: 642
-Receive: 452
« Reply #166 on: April 19, 2020, 05:13:44 17:13 » |
Here it is....
(reuploaded: original file was corrupted!)
« Last Edit: April 19, 2020, 11:42:48 23:42 by wild »
prnleon
« Reply #167 on: April 19, 2020, 06:18:19 18:18 » |
Here it is....
No idea why cannot give thanks in this thread (I don't see any thanks button). Thanks!
wild
-Given: 642
-Receive: 452
« Reply #168 on: April 19, 2020, 11:43:53 23:43 » |
Sorry: previous file was corrupted! I have reuploaded link to correct archive
Mr. Spock
-Given: 475
-Receive: 827
« Reply #169 on: April 20, 2020, 03:12:50 15:12 » |
Thanks button not available. Thank you anyway
h0nk
-Given: 247
« Reply #170 on: April 22, 2020, 06:14:29 18:14 » |
Hello madmax80,
you should also try Samba. This is the programming software for the ARM-family by Atmel/Microchip.
Best Regards
-Given: 841
-Receive: 4364
« Reply #171 on: April 22, 2020, 09:52:38 21:52 » |
Thanks for reply but I should need a jtag drive or there is a another way to send uboot to this? Is Unc90 module. Thanks
Samba can flash via USB
perithess
-Given: 11
« Reply #172 on: April 29, 2020, 03:11:19 15:11 » |
Regarding J-Link V11, seems there is some kind of "scam" started by russians, maybe they just changed the ID string inside V10 firmware. Hers some links: https://www.avito.ru/irkutsk/tovary_dlya_kompyutera/otladchik_j-link_v11_segger_novaya_versiya_1835419321https://www.avito.ru/irkutsk/tovary_dlya_kompyutera/segger_j-link_v10_v11_original_1770961504https://www.codetd.com/en/article/6945472So, my statement still is: THERE IS NOT ANY OFFICIAL V11 DIFFERENT HARDWARE Also, from my knowledge, if order EDU version you will receive an V9 hardware (STM32 based, just Full USB, no High speed). Can anybody confirm this info? Thanks, Zulea I have just received a Jlink v10.2 (according to the pcb) same as this one without the screen. https://www.aliexpress.com/item/32974951095.html?spm=a2g0o.productlist.0.0.46714a71NKbaae&algo_pvid=0c5a8884-4b0c-425e-a0e6-c25d8cba7a62&algo_expid=0c5a8884-4b0c-425e-a0e6-c25d8cba7a62-16&btsid=0ab6f82215836870954146051e7bc7&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_&fbclid=IwAR3WcYYq6BkDPHaGMo8uX8k9h_p0Pg6haRoqBtNj6KKlHSnmB4fiedBuVn4It is recognized as V10.10 on configurator. I tried to use it but it displays a message during debug that is faulty...contact with segger and the debug stops. On the other hand the firmware was updated without any issues directly from the configurator.
rajhlinux
« Reply #173 on: April 29, 2020, 11:41:39 23:41 » |
Can anyone recommend which J-Link V9 or V10 clone would be the best choice to get, newer models, so that I can use it as long as possible in the near future?
I see threes so many different kinds of J-Link clones and I have no idea which one to get.
J-Link EDU is around $70 after shipping where a clone is $35.
J-Link Mini EDU is $30 after shipping on amazon, this seems logical thing to buy. But heard it has restrictions, not sure how bad the restrictions are and if this will stop me from using it in the future. Is the EDU mini restricted only for the cortex M family?
Would it be better to get the EDU mini or a v9/v10 clone?
I'm just starting to learn about ARM processors and would like to buy a programmer only once and not have to buy another one in the future. From reading this entire thread the J-Link clones seems to be good in terms of reliability specially for educational use.
I live in the US and amazon links would be great since I can easily return them.
Any information would be appreciated, Thanks.
« Last Edit: April 30, 2020, 12:15:08 00:15 by rajhlinux »
rajhlinux
« Reply #174 on: May 08, 2020, 07:51:23 07:51 » |
anyone?
