bobcat1
-Given: 4378
-Receive: 96
« Reply #100 on: May 31, 2015, 09:03:31 09:03 » |
Hi all I just both 2 Jlink clone (less then 10 USD each) They looks OK at first ,but when I left one connected all night to computer It was stop functioning - it looks like the firmware was erased - I measured voltage inside - all looks ok At first I though to trow it away , but then I saw the info published above and I will folow it to see whether I can fix it This J-link came with a serial number and it works with Ver 4.92
All the best
Bobi
gusenkovs
« Reply #101 on: June 02, 2015, 07:15:24 19:15 » |
I flash this firmware to Jlink v9.1. Bootloader not work USB work Jtag I test. Results send
Jtag work
bobcat1
-Given: 4378
-Receive: 96
« Reply #102 on: June 14, 2015, 11:26:57 11:26 » |
Hi All
Dose any one use the J-LINK V9 clone?
I saw it for sell on Aliexpress for 23~24 USD
I though of ordering it ....
it say the clone work very fast 1M/Sec?
Dose it works with IAR v6 or v7?
Bobi
« Last Edit: June 14, 2015, 11:29:45 11:29 by bobcat1 »
Avalynn
-Given: 17
-Receive: 27
« Reply #103 on: December 05, 2015, 11:57:36 23:57 » |
So I wanted to share my experience, I recently got two V8 clones from ebay for a friend, and to use along with my edu version. Looking at the boards, and wow!, I was surprised how much effort was put into cloning them, down to the little pcb trace logo. Although there are some glaring differences, like ROSH instead of RoHS unless that was intended, and a handful different passive / active components, e.g. the regulator, LED, and a couple other things. Anyways.. about the firmware on it.
At first I used an older version of the software to try and copy the flash out of edu and clone for backup, never could get it to read using Jflash, Jlink commander, Atmel Sam-ba (not in bootloader mode but using the other J-link), OpenOCD, and eventually gave up trying to read either. The firmware date on the clones were 2009. So out of curiosity I downloaded the latest software (V5.10c at time of posting) and plugged my clone in. It asked to update so I said no initially and it still worked happily.
So finally I decided to update one of them fun of it, keeping all the recovery by crackn handy (thank you so much!) and it updated without a problem. Started up J-Link and was with,
DLL version V5.10c, compiled Dec 4 2015 17:25:20 Connecting to J-Link via USB...O.K. Firmware: J-Link ARM V8 compiled Nov 28 2014 13:44:46 Hardware version: V8.00 S/N: 99999939 License(s): RDI,FlashDL,FlashBP,JFlash,GDBFull Emulator has Trace capability
So I donno if the firmware was supposed to get erased (maybe if I leave it plugged in for a day), or are they making clones better, or Segger doesn't care with the new V9 rolled out?
Anyways that's my experience, after I decided to erase the flash, burn the firmware from crackn using atmel sam-ba, update and change the serial to something more reasonable. Everything seems to be in working order!
« Last Edit: December 06, 2015, 12:13:55 00:13 by Avalynn »
Crackn
-Given: 123
-Receive: 565
« Reply #104 on: December 06, 2015, 09:01:51 09:01 » |
Yes, if you follow the steps to recover it, it will update and work fine. after you set the serial, if you update again, the jlink firmware will be corrupted. this is where the recovery comes handy. so for the record: everytime an update is released, you need to recovery before update. cheers, cRACKn
Nutter
« Reply #105 on: January 25, 2016, 10:29:29 22:29 » |
Thanks for this - I got it working with my J-Link clone. I didn't see it mentioned elsewhere in the thread, but the offset for the serial in the original firmware bin is 0x65280 (4 bytes, little endian). Using 5.0h, while I was able to update the firmware with J-Link Configurator, if I didn't change the serial away from -1 (0xFFFFFFFF) I was unable to use JLinkExe ("Connecting to J-Link via USB...FAILED: Can not connect to J-Link via USB.") - after customizing the serial I was back in business however. I did find that some serials didn't work in J-Link Configurator (*possibly* related to the high-bit being set, but I didn't experiment enough to confirm this), so if your device isn't listed after an update, try another serial.
« Last Edit: January 25, 2016, 10:31:36 22:31 by Nutter »
baybay
-Given: 15
-Receive: 34
« Reply #106 on: March 01, 2016, 11:52:08 23:52 » |
JLink hardware changed by SEGGER.. new JLinkARM.dll file includes J-Link V10 firmware.. I think new JLink hardware (v10) uses NXP's LPC series MCU... firmware's initial stack pointer address = 0x10083928 (i think ram block2 used for stack space, base address = 0x10080000) firmware's reset handler address = 0x1A024D3D (i think flash block base address = 0x10000000) for example LPC4357 memory mapping: RAM1 Block base address = 0x10000000 (32K) RAM2 Block base address = 0x10080000 (40K) FlashA Block base address = 0x1a000000 (512K) FlashB Block base address = 0x1b000000 (512K) same with lpc43xx series some lpc18xx series mcu's also used same base addresses; ( http://www.nxp.com/documents/user_manual/UM10430.pdf ) page23: flash bank A base address = 0x1a000000 and page22, table5: ram block2 base address = 0x10080000 Do you have an idea about the new features comes with JLink-v10 hardware?
crahak
-Given: 12
-Receive: 552
« Reply #107 on: November 08, 2016, 09:50:07 21:50 » |
J-Link drivers v6.10l with patch for clones (blacklisted serial, GDBFull...)
Tested working with clones v8 & v9, and with "real" v9 too.
bigtoy
-Given: 340
-Receive: 297
« Reply #108 on: November 26, 2016, 04:11:49 16:11 » |
Is it just me, or are there really no "thank you" buttons in this thread?
« Reply #109 on: November 26, 2016, 04:44:13 16:44 » |
you are not crazy, I don't have them either.
« Reply #110 on: January 28, 2017, 01:21:36 01:21 » |
concerning st jlink, im unable to connect keil to gdb server, it keeps reporting that "GDB closed TCP/IP connection" when trying to connect keil to nucleo's jlink through tcp/ip, here is the gdb server log: SEGGER J-Link GDB Server V6.12g GUI Version
JLinkARM.dll V6.12g (DLL compiled Jan 27 2017 18:18:51)
-----GDB Server start settings----- GDBInit file: none GDB Server Listening port: 2331 SWO raw output listening port: 2332 Terminal I/O port: 2333 Accept remote connection: localhost only Generate logfile: off Verify download: on Init regs on start: off Silent mode: off Single run mode: off Target connection timeout: 5000 ms ------J-Link related settings------ J-Link Host interface: USB J-Link script: none J-Link settings file: none ------Target related settings------ Target device: STM32F072RB (allow opt. bytes) Target interface: SWD Target interface speed: auto Target endian: little
Connecting to J-Link... J-Link is connected. Firmware: J-Link STLink V21 compiled Dec 21 2016 15:10:59 Hardware: V1.00 S/N: 123456789 Checking target voltage... Target voltage: 3.30 V Listening on TCP/IP port 2331 Connecting to target...Connected to target Waiting for GDB connection... Connected to 127.0.0.1 GDB closed TCP/IP connection Also, how can I allow listening to the IP on the interface rather than just the loopback interface?
h0nk
-Given: 247
« Reply #111 on: January 28, 2017, 08:35:09 08:35 » |
Hello metal, concerning st jlink, im unable to connect keil to gdb server, it keeps reporting that "GDB closed TCP/IP connection" when trying to connect keil to nucleo's jlink through tcp/ip, here is the gdb server log:
Second first: Use "JLinkGDBServerCL.exe -LocalhostOnly 0" The documentation to JLinkGDB is simply wrong: 3.6.7 -LocalhostOnly Starts the J-Link GDB Server with the option to listen on localhost only. This means that only TCP/IP connections from localhost are accepted. To allow remote debugging (connecting to GDBServer from another PC), do NOT use this option.
For the GUI-Version "JLinkGDBServer.exe change in the config file "JLinkGDBServer.ini": Localhost = 1 to Localhost = 0. My (clone) J-Link logs: Connecting to J-Link... J-Link is connected. Firmware: J-Link ARM V8 compiled Nov 25 2013 19:20:08 Hardware: V8.00 S/N: XXXXXXXX4 Feature(s): RDI,FlashDL,FlashBP,JFlash,GDBFULL Checking target voltage...
May be the feature GDBFULL is missing? Have You tried a direct use of the J-Link with Keil? Best Regards
« Reply #112 on: January 28, 2017, 09:25:27 21:25 » |
Thank you for your reply. Mein is a nucleo-072RB, stlink is converted to jlink. In the license manager, RDI,FlashDL,FlashBP,JFlash,GDBFULL are all enabled for this jlink. I can't find JLinkGDBServer.ini any where on my PC  Now, for the cmd method, it did not work either. Can someone try to do the same task to confirm it doesn't work. Unfortunately, I have no jlink at the moment. On the other hand I dunt like too many JTAG connections, SWD is way easier to connect and use for flashing and debugging.
h0nk
-Given: 247
« Reply #113 on: January 28, 2017, 10:19:01 22:19 » |
Hello metal, Thank you for your reply. Mein is a nucleo-072RB, stlink is converted to jlink. In the license manager, RDI,FlashDL,FlashBP,JFlash,GDBFULL are all enabled for this jlink. I can't find JLinkGDBServer.ini any where on my PC  Now, for the cmd method, it did not work either. Can someone try to do the same task to confirm it doesn't work. Unfortunately, I have no jlink at the moment. On the other hand I dunt like too many JTAG connections, SWD is way easier to connect and use for flashing and debugging. JLinkGDBServer.ini should be in the same directory as Your "SEGGER J-Link GDB Server V6.12g GUI Version". You can use Processexplorer or similiar tools to find the location. There should be open TCP-ports also. X:\>netstat -at
Active Connections Proto Local Address Foreign Address State Offload State ... TCP 0.0.0.0:2332 XYZ:0 LISTENING InHost TCP 0.0.0.0:2333 XYZ:0 LISTENING InHost
X:\>netstat -ao | find "2332" TCP 0.0.0.0:2332 XYZ:0 LISTENING 2960
X:\>tasklist | find "2960" JLinkGDBServer.exe 2960 Console 1 8,356 K
One Port is for JTAG-connections, the other for SWD. The file JLinkGDBServer.ini resides in the installation directory of the Segger J-Link-Tools. I attached it to this post. My running JLinkGDBServer is connected via USB to the J-Link. You may also use a "JLinkSettings.ini" file in Your Keil-project. See the examples dir of Keil. If Your computer is missing this file, perhaps You have not installed Seggers J-Link-Tools? Is there any special reason why You configure Keil to use a connection via TCP/IP and not USB? Best Regards and Good Luck
« Reply #114 on: January 29, 2017, 08:54:47 20:54 » |
Do you mean that SWD port is 2332, to which keil should connect?
h0nk
-Given: 247
« Reply #115 on: January 29, 2017, 10:43:58 22:43 » |
Hello metal,
no, the first port 2332 is for JTAG. For SWD it should be 2333.
Best Regards
« Reply #116 on: January 29, 2017, 11:05:34 23:05 » |
2333 is closed.. doesn't respond to telnet on localhost.
h0nk
-Given: 247
« Reply #117 on: January 30, 2017, 11:19:26 23:19 » |
dont use "JLinkGDBServer.exe" if You want to use a network connection to Keil. Instead use "JLinkRemoteServer.exe". Tested and working.
Best Regards
« Reply #118 on: January 31, 2017, 11:53:25 11:53 » |
thanks!
it connects OK, but when I program the chip... look at the image :- ) I also keep receiving the "max number of connections exceeded" message..
« Last Edit: January 31, 2017, 11:58:16 11:58 by metal »
h0nk
-Given: 247
« Reply #119 on: January 31, 2017, 04:50:34 16:50 » |
i dont remember that a J-Link light can handle JTAG. You should switch over to SWD.
Best Regards
« Reply #120 on: January 31, 2017, 11:05:40 23:05 » |
it works, previously, I was unable to choose SWD! very strange, now that it has connected, I keep receiving "max number of connections exceeded" message.. Posted on: February 01, 2017, 01:34:40 01:34 - Automerged
okay, I am fed up with this nonsense.. I patched the remote server, the annoying thing is that it works flawlessly...! watch this quick video to see what happens... h0nk, thanks a lot for your help, I appreciate it :- )
eguevara
« Reply #121 on: April 06, 2017, 07:18:42 07:18 » |
I was able to fix a bricked V8 clone and install the latest V6.14c software including the latest 2014 J-Link firmware. Before following the the procedure described by Crackn, the no serial firmware must be patched to change "GDBFull" to "GDB" A simple hex editor is sufficient to make the change. Step by step: 1- patch the no serial firmware 2- short ERASE jumper, wait 1 minute and power cycle 3- short TST jumper, wait 1 minute and power cycle 4- upload the patched firmware using sam-ba 5- set the serial number using j-link commander, power cycle 6- download 6.14c from segger and update here are the instructions and firmware file to recovery, unbrick and update to the latest firmware and 490 drivers as well. one special advice to check the 2 needed jumpers inside your CLONE before proceed. you need to have the ERASE / ERS and TEST / TST. https://www.sendspace.com/file/kq4szfpassword: sonsivri.to ps. Please mirror it.
dotm
-Given: 81
-Receive: 75
« Reply #122 on: July 22, 2017, 11:25:19 11:25 » |
Could anyone re-upload this?
mars01
-Given: 700
-Receive: 1775
« Reply #123 on: July 23, 2017, 07:26:39 19:26 » |
Here it is: Zippyshare and Filedropper links.
dotm
-Given: 81
-Receive: 75
« Reply #124 on: August 22, 2017, 12:27:33 12:27 » |
Since there is no "Thank You" Button here i will do it manually: Thank you.
