April 05, 2025, 03:05:44 03:05
Pages: 1 2 [3]  All
Author Topic: PicBasic Pro v3.1.0  (Read 170024 times)
HackAndCrack
-Given: 175
-Receive: 804
« Reply #50 on: March 02, 2019, 04:21:55 16:21 »
Mod. although this post is over 150 and my post is not a reply per se, it is related.
Installed latest, 3.1.2.1 ontop of previous patched version. Although titlebar shows trial and Buy PicBasic appears on toolbar, activation manager continues to show activated and everthing seems to run ok. Will advise if 15 day trial kicks in.
Why patch ? Keygen works fine. I just tested it. All devices are enabled.
towlerg
-Given: 474
-Receive: 104
What is this for?
« Reply #51 on: March 02, 2019, 11:28:12 23:28 »
Sorry, figure of speech, all I meant to say was that I installed on top of an existing activated version, using the reg/patch/serial whatever.
Win 7 Ult x64 SP1 on HP2570p
mississippi1
« Reply #52 on: May 05, 2020, 10:57:54 10:57 »
Hi, I yust installed PBP 3.1.2 and I could generate a serial number. But when I filled it in the reg. window together with my name and email adres The regwindow remarked that the number was not correct. What did I wrong??
Regards M
pigtail
-Receive: 20
« Reply #53 on: May 27, 2020, 09:14:08 21:14 »
Hello HackAndCrack,
I am trying to use KeyGen but I am not having success; the application does not open. I've tried it on Win 10 and Win 7, both x64.
HackAndCrack
-Given: 175
-Receive: 804
« Reply #54 on: May 28, 2020, 05:24:00 05:24 »
Hello HackAndCrack,
You need to install 1Way to use the keygen.
mitsos
-Given: 3158
-Receive: 4778
« Reply #55 on: June 28, 2022, 09:36:28 21:36 »
hi
the last version 3.1.6 is released
http://www.pbp3.com/downloads/PBP3_Setup.exe
it is working with HackandCrack keygen
http://www.sonsivri.to/forum/index.php?topic=64940.0
mitsos
Pages: 1 2 [3]  All
