November 21, 2024, 09:55:00 09:55
Pages: 1 [2] 3  All
Author Topic: PicBasic Pro v3.1.0  (Read 161985 times)
lou
« Reply #25 on: August 13, 2012, 12:50:50 00:50 »
Thanks titi,
I had replaced PBPX.EXE, but I did not do the CodeStudio.exe replacement.  Why did I run the PBPX.EXE ? and why did I not replace the CodeStudio.exe ?  My only excuse is "old age brain fart".
I will try to  install MCSX later on.... thanks again, Lou
Bubu62
-Given: 169
« Reply #26 on: September 25, 2012, 01:54:29 13:54 »
Hi Gentlemans
I have to have a medicine to the PBP3.0.6.
If possible, please send me the PBPX.exe zip link...
I'm sorry, my English is poor...
titi
-Given: 3802
-Receive: 834
« Reply #27 on: September 25, 2012, 05:25:26 17:25 »
Hi Bubu62,
Just go on my first post:
http://www.sonsivri.to/forum/index.php?topic=41263.msg123679#msg123679
At the bottom of the message, you have a file "link.txt" in attachment, just click on the link and click on open (or down the file and
open it with notepad or double click on it) and follow instructions.
Best regards.
« Last Edit: September 26, 2012, 04:25:35 16:25 by titi » Logged
titi
-Given: 3802
-Receive: 834
« Reply #28 on: May 04, 2013, 01:54:37 13:54 »
The new version of PicBasic Pro v3.0.7.1 is now available and fully fonctionnal.
To download, see my first post, it is up to date.
Best regards.
9thwonder
« Reply #29 on: May 08, 2013, 04:23:47 04:23 »
Hi titi,
pbp3 works well but after few minutes microcode studio gives error massage and shuts down.showing send error to microsoft. what to do?
titi
-Given: 3802
-Receive: 834
« Reply #30 on: May 08, 2013, 07:58:55 07:58 »
Hi 9thwonder,
I have not seen this problem on my PC (Windows 7 64 bit).
You can try to use the original CodeStudio.exe (it has only the icone "Buy PICBasic" removed).
You need to have MPLAB 8.90 installed.
If the problem don't disappears, try a fresh install (remove all previous version).
Be carefull in the new version, PBP3 is not yet in c:\PBP3 but in c:\Program Files\PBP3 or c:\Program Files (x86)\PBP3.
Is someboby has the same problem ?
Best regards.
gzorzi
« Reply #31 on: May 20, 2013, 01:26:28 13:26 »
I tried to use original microcodestudio plus with cracked PICBASIC PRO, but I see "Buy PicBasic".
PicBasic Pro activation is OK, it give me status activated.
Any idea?
titi
-Given: 3802
-Receive: 834
« Reply #32 on: May 20, 2013, 10:48:31 22:48 »
Hi Gzorzi,
if you have no problem of windows crash, use the modified microcode studio exe, and you will not have the icone "Buy PicBasic".
9thwonder seams have a problem and I ask him to test with the original microcode studio exe, but "Buy PicBasic" is not pretty, but all works well.
Best regards.
gzorzi
« Reply #33 on: May 21, 2013, 07:20:21 07:20 »
I bought the original microcode studio plus because I need to use ICD with PIC18F4620. But The original one didn't recognise as verificated your meLabsReg modification. If I use your CodeStudio it will work but it doesn't have ICD for PIC18F4620.
-Receive: 904
« Reply #34 on: May 22, 2013, 02:34:51 02:34 »
Thanks for sharing what you have, and we don't, gzorzi.
titi
-Given: 3802
-Receive: 834
« Reply #35 on: May 22, 2013, 07:28:44 19:28 »
Hi Gzorzi,
PicBasic 3.0 comes with a special edition of Microcode v5.
The ICD for MicroCode Studio supports the following PIC microcontroller devices:
  16F887
  16F877A
  18F25K20
  18F452
  18F4520
With a full Microcode Studio v5, it is possible to adapt PicBasic 3.0 to work with this version.
But I haven't, so I can't do anything.
Best regards.
-Given: 833
-Receive: 4320
« Reply #36 on: May 22, 2013, 09:46:13 21:46 »
so your bought MSPlus supports the Pic18F4620? yes or no..
If I remember even the full version had a very limited list of device support. same list as titi
http://www.sonsivri.to/forum/index.php?topic=41263.msg125381#msg125381
Nicolina1988
-Given: 28
-Receive: 85
« Reply #37 on: August 25, 2014, 12:58:37 12:58 »
Does anybody know where we can find a full list of supported PIC chips in 3.0.7.1?
Checksum8
-Given: 124
-Receive: 102
« Reply #38 on: August 25, 2014, 03:30:29 15:30 »
Try this
http://pbp3.com/devicelist.html
titi
-Given: 3802
-Receive: 834
« Reply #39 on: June 07, 2016, 05:40:35 17:40 »
The new version of PicBasic Pro v3.0.9 is now available and fully fonctional.
Best regards.
« Last Edit: April 02, 2017, 06:46:53 18:46 by titi » Logged
titi
-Given: 3802
-Receive: 834
« Reply #40 on: April 02, 2017, 06:46:43 18:46 »
The new version of PicBasic Pro v3.0.10 is now available and fully fonctional.
Best regards.
SMW_Electronics
-Given: 22
« Reply #41 on: August 12, 2017, 09:54:05 09:54 »
new ver 3.1.0 released , does this medicine still work ?
SMW_Electronics
-Given: 22
« Reply #42 on: August 13, 2017, 04:08:03 04:08 »
FIX FOR 3.0.8 - 3.0.10 does not appear to work on 3.1.0 ,
the activation window continues to come up after activation / medicine was applied
the compile or program wont continue until the activation window is manually closed , this did not occur previously
when a compile is done it shows trial version , with remaining days in results
New medicine required  ?
titi
-Given: 3802
-Receive: 834
« Reply #43 on: August 13, 2017, 10:54:42 10:54 »
The protection has changed from previous versions.
The new medicine is now available.
The new version of PicBasic Pro v3.1.0 is now available and fully functional.
Best regards.
magician
« Reply #44 on: September 05, 2017, 04:53:22 04:53 »
I want to confirm that version 3.1.0 is ok. Microcode Studio reports in title bar as Trial Edition 2017.4.12.0
towlerg
-Given: 474
-Receive: 104
What is this for?
« Reply #45 on: September 05, 2017, 12:46:40 12:46 »
I'm pretty sure the "Trial Edition" refers to the IDE which is not patched and which has a paid for version with extra features.
Win 7 Ult x64 SP1 on HP2570p
tumbleweed
-Given: 58
-Receive: 41
« Reply #46 on: January 06, 2018, 12:03:55 12:03 »
Has anyone tried this with version 3.1.1?
Does the reg patch from 3.1.0 work with it?
jvcastel
-Given: 21
« Reply #47 on: August 24, 2018, 01:53:54 01:53 »
Hello, Could you please upload the medicine again? Current links are no longer valid. Thanks!
HackAndCrack
-Given: 175
-Receive: 802
« Reply #48 on: August 24, 2018, 10:33:43 10:33 »
Here is keygen.
http://www.sonsivri.to/forum/index.php?topic=64940.25
Here is MicroCode Studio Plus for PBP.
http://www.sonsivri.to/forum/index.php?topic=64985.0
towlerg
-Given: 474
-Receive: 104
What is this for?
« Reply #49 on: March 02, 2019, 02:12:53 14:12 »
Mod. although this post is over 150 and my post is not a reply per se, it is related.
Installed latest, 3.1.2.1 ontop of previous patched version. Although titlebar shows trial and Buy PicBasic appears on toolbar, activation manager continues to show activated and everthing seems to run ok. Will advise if 15 day trial kicks in.
Version history
    Fixed bit-compare and bank-select for banks higher than 15 in K42/K83 families
    Fixed compile error when using arrays with 10F3xx
    Fixed HPWM for 16F18313/23, 16F1769
    Changed default #CONFIG for 16(L)F15xxx family to set SOSC pins to normal I/O
    Changed default #CONFIG for 16(L)F171x family to disable ZCD on power up
    Fixed HPWM CCPTMRSx-selection for 18(L)FxxK42
    Fixed PPS and HPWM for 16F161x family
    Fixed missing SFRs in 18LFxxK42 devices
« Last Edit: March 02, 2019, 02:17:36 14:17 by towlerg » Logged
Pages: 1 [2] 3  All
