titi
-Given: 3802
-Receive: 834
« on: October 31, 2011, 09:42:42 09:42 » |
Hi, here is a medicine for v3.1.0 This is based on trial version (which correspond as Gold Edition). So download and install trial version and add medicine. Download Software (trial) : http://www.pbp3.com/downloads/PBP3_Setup.exeFor Information: PicBasic Pro v3 site : http://www.pbp3.com Download PBP : http://www.pbp3.com/download.html Download Ref Manual : http://www.pbp3.com/downloads/PBP_Reference_Manual.pdf History Versions of PBP : http://support.melabs.com/content/29-PicBasic-Pro-Version-HistoryWhat's new :PBP 3.1 as a major upgrade due to additional assembly-libraries necessary to support Microchip's changes in memory map on their latest devices. The new libraries allow us to continue adding support for the latest 8-bit microcontrollers as they are released. •Added support for devices: 10(L)F320, 10(L)F322, 16(L)F15313, 16(L)F15323, 16(L)F15324, 16(L)F15325, 16(L)F15344, 16(L)F15355, 16(L)F15356, 16(L)F15375, 16(L)F15376, 16(L)F15385, 16(L)F15386, 16(L)F1773, 16(L)F1776, 16(L)F1777, 16(L)F1778, 16(L)F1779, 16(L)F18324, 16(L)F18344, 16(L)F18854, 16(L)F18855, 16(L)F18856, 16(L)F18857, 16(L)F18875, 16(L)F18876, 16(L)F18877, 18(L)F24K40, 18(L)F25K40, 18(L)F26K40, 18(L)F27K40, 18(L)F45K40, 18(L)F46K40, 18(L)F47K40, 18(L)F65K40, 18(L)F66K40, 18(L)F67K40 •Added Peripheral Pin Select (PPS) initialization for HPWM, HSERIN, HSEROUT, HSERIN2 and HSEROUT2 commands on devices equipped with modern-format PPS. Best regards.
« Last Edit: August 13, 2017, 11:00:51 11:00 by titi »
alwaan
-Receive: 22
« Reply #1 on: October 31, 2011, 08:08:03 20:08 » |
Hi Titi,
After successfully compiling & closing PBP3, then setting the clock forward 2 months, running a compile of the same program generates the following message:
WARNING: Failed executable integrity check for C:\PBP3\pbpx.exe The file may be corrupt. Please reinstall the software to repair any problems.
... a reboot clears this message and follows with a successful compile.
Returning the clock to current time then starting PBP3 and trying a compile locks up the program.
... once again a reboot clears this and follows with a successful compile.
Are others experiencing this?
-Given: 833
-Receive: 4320
« Reply #2 on: October 31, 2011, 11:41:08 23:41 » |
Why would you want to mess with the clock?
The program may monitor the file build, and if so, is reporting a posible problem.
alwaan
-Receive: 22
« Reply #3 on: November 01, 2011, 05:01:37 05:01 » |
To test if the file bypasses the 15 day limit. The program may monitor the file build, and if so, is reporting a posible problem.
True. But just setting it forward caused the original compiler to generate: ERROR: Trial version expired. This was a comparison which ended up with an "integrity check" of the compiler
« Reply #4 on: November 01, 2011, 05:43:23 05:43 » |
Then there might be a check on CRC. But I tried what you said, and nothing happened..
« Last Edit: November 01, 2011, 07:16:24 07:16 by metal »
tomywong
-Given: 101
-Receive: 213
« Reply #5 on: December 18, 2011, 02:36:28 02:36 » |
Just want to try it. But it already update to v3.0.4, titi do you have medicine again ?
titi
-Given: 3802
-Receive: 834
« Reply #6 on: December 19, 2011, 01:59:45 13:59 » |
this is new medicine for v3.0.4 (Only for sonsivri users)
Password : sonsivri
link is update on my first post too.
Best regards.
gzorzi
« Reply #7 on: December 21, 2011, 06:58:23 18:58 » |
The medicine is good, thanks for a good job. I'd like to use the signed variable (myvariable var long) but I should use PBPL. How can I use it with pbp3? Thanks
titi
-Given: 3802
-Receive: 834
« Reply #8 on: December 22, 2011, 09:47:32 09:47 » |
The documentation is not really up to date.
To use long variable in pbp do this: - Open Microcode Studio 5 - Click "view", then click on "Compile and Program Option" - in the field "User Command Line Options" put -n - the "-n" option add the support for long variable
When you compile with -n option for the first time a message informs you that the integrity of the executable is not good, it is just a warning and if you compile again the message disappear.
Remark: All PIC don't support long variables.
Best regards.
« Last Edit: April 27, 2012, 10:36:38 10:36 by titi »
gzorzi
« Reply #9 on: December 22, 2011, 06:56:54 18:56 » |
Wonderful, with option -n seems I can use long variable with 18F4680. Now, another big question. I tried to use the ICD compile, but microcode studio isn't the plus version, so it can't run. Sure, with version is enough, but plus version will be the best.
-Given: 833
-Receive: 4320
« Reply #10 on: December 22, 2011, 07:50:51 19:50 » |
The standed version of microcode studio only suports : 16F887 - 16F877A - 18F25K20 - 18F452 - 18F4520 The plus version also has a limited list of devices too. ****** thanks tim box ******
-Given: 405
-Receive: 545
« Reply #11 on: December 23, 2011, 12:03:06 00:03 » |
forter
-Given: 1048
-Receive: 28
« Reply #12 on: December 25, 2011, 01:39:14 13:39 » |
Hi, bbarney! FineLineIDE is a good program, but I cant select any PIC - no falling menu. If I change PBP3 to PBP Pro, the selection of PIC works fine. Can you explain how make it in FineLineIDE?
-Given: 405
-Receive: 545
« Reply #13 on: December 25, 2011, 02:07:35 14:07 » |
No I can't as I don't use it, I just seen the program and thought it might help
Redhouse
-Given: 90
« Reply #14 on: January 10, 2012, 12:18:33 00:18 » |
Not following, on the PBP3 webpage it says "if you have PBP3 then you have the IDE" what point am I missing?
-Given: 833
-Receive: 4320
« Reply #15 on: January 10, 2012, 01:46:11 01:46 » |
Pre PBP3 the IDE was a seprate program (from our good friend Tim Box), so from PBP3 the IDE is part of Picbasic pro.
lm317
-Given: 123
-Receive: 29
« Reply #16 on: January 10, 2012, 07:28:39 07:28 » |
Hmm. Same time, Tim Box good friend of Les(Proton author). I know, Tim very popular person at Proton basic forum. I thing Tim won't like his name written here. He may different nickname and may already here
« Last Edit: January 10, 2012, 07:32:38 07:32 by lm317 »
enzine
-Given: 676
-Receive: 57
« Reply #17 on: January 29, 2012, 10:26:46 22:26 » |
Hello friends, links for medicine are dead. Can you please re-upload? Thank you in advance
hosmis
-Given: 334
-Receive: 243
« Reply #18 on: January 29, 2012, 10:29:21 22:29 » |
shh91
-Given: 493
-Receive: 21
« Reply #19 on: March 28, 2012, 06:53:18 18:53 » |
hi I can't use from fileserve please re-upload on mediafire or ifile
thank you
FriendOfGhost
-Receive: 55
« Reply #20 on: March 28, 2012, 09:19:26 21:19 » |
titi
-Given: 3802
-Receive: 834
« Reply #21 on: March 30, 2012, 01:07:48 13:07 » |
The new version of PicBasic Pro v3.0.5 is now available and fully fonctionnal. To download, see my first post, it is up to date.
Best regards.
lou
« Reply #23 on: August 12, 2012, 07:53:32 19:53 » |
Help....
I've downloaded v3.0.6, installed and ran PBPX.EXE. I open PicBasic it is showing Trial Edition (blink. pbp) at the top of the screen. I then compile the example blink.pbp, it compiles. in the "results" at the bottom of the page, the count down continues "trial version. 14 days left". What have I done Wrong ??
Thanks, Lou
titi
-Given: 3802
-Receive: 834
« Reply #24 on: August 12, 2012, 09:10:30 21:10 » |
You only have to replace C:\PBP3\PBPX.EXE by this is in the rar file and replace "c:\Program Files\Mecanique\MCSX\CodeStudio.exe" or " c:\Program Files (x86)\Mecanique\MCSX\CodeStudio.exe" by this is in the rar file.
In fact it is a real trial version, so it is normal that the count down continues, but at the end, it never expires. Something that I don't understand is why do you ran PBPX.EXE ? It is more interesting to install MCSX that is the IDE (editor) for PICBasic and compile from the IDE.
Best regards.
