mazoul72
« on: October 28, 2011, 10:01:05 22:01 » |
my project :
FIS control like VAG (home display , VAG-COM like , Soft coding change on the fly ...)
problem : software---> program modification with already based Version 1.0 frame to decode with K-LINE (control bytes sequence already have but have to improve) or BUSCAN (but very hard to decode)
hardware : ---> 1) problem with outputs RESET/DOWN/UP steering wheel commands 2) to conceive some more functions..
The system is on the "table" but need to modify 3 wires on Green connector (23 / 24 / 25 ) :
a PIC16F877A that is in serial with steering wheel command (RESET / UP / DOWN on B5,B6 et B7) I am programing to put ground on outputs (RC3 ,RC4 ,RC5 ) but for valid UP/DW/RESET i need transistion from +12V to ground .
Also i need absolutely 12V like FIS send to input (normally) and PIC has only +5V to 3 wires . How have +12V on RC3 ,RC4 and RC5 outputs command by my program ? (pull-up resistors ??)
Opto-isolator but how plug to RCx 3 wires ??
+12V is normaly on 23/24/25 input ("on the air" wires) --> not lie to external Ground(perhaps internal FIS tachometer...) . If the soft PIC put +12V (output RCx) on +12V FIS , hardware failure.... so no +12V force but only Ground with external input command buttons .
« Last Edit: October 28, 2011, 10:09:10 22:09 by mazoul72 »
TomJackson69
-Receive: 63
« Reply #1 on: October 29, 2011, 12:18:16 00:18 » |
Not really understand what you want. Do you want to convert +12V to +5V signal to input to the PIC (pin B5, B6 and B7)?
Be clearer for us to understand what you want.
Tom
Con Rong Chau Tien
gan_canny
-Given: 101
-Receive: 26
« Reply #2 on: October 29, 2011, 01:03:05 13:03 » |
The issue is that a PIC is 5v and the input output levels are 12v. If the circuit doesn't need isolated grounds. On the input side a resistor divider could split the voltage eg 5k 7k. The output needs a level shifter. Here a 74xx hex non-inverting or inverting ( do the inversion in the MCU) open collector would likely work. If the circuit needs isolated grounds. If isolation is needed then the opto isolator would work.
zokij
-Given: 272
-Receive: 700
Nice time :)
« Reply #3 on: November 02, 2011, 02:40:11 02:40 » |
not expensive but will reliable to use TLP504A on both side (portb and portc)
mazoul72
« Reply #4 on: November 05, 2011, 03:16:35 15:16 » |
Hi, thanks for aswers . i put option_reg.7 for pull-up RB5 to RB7 (input steering wheel) and RB0 to RB2 (radio display on FIS tacho) . I have for it an ASM prog but i've just seen that i didn't put TRISB %11100111 for input RB. Is it for this mistake i have +6.7V(RB7,RB6) and 4.98V(RB5) : VERY Strange ... My input PIC Voltage is stable at 4.98V .
Start:
ASM
loop BTFSS PORTB.5 ; jump next instruction if B.5 = "1" BCF PORTC.3 ; put C.3 à "0" (B5 input and C3 output) BTFSC PORTB.5 ; jump next instruction if B.5 = "0" BSF PORTC.3 ; put C.3 à "1"
BTFSS PORTB.6 ; jump next instruction if B.6 = "1" BCF PORTC.4 ; put C.4 to "0" (B6 input and C4 ouput) BTFSC PORTB.6 ; jump next instruction if B.6 = "0" BSF PORTC.4 ; put C.4 to "1"
;Si aucunes commandes validées alors on continu dans le programme complet BTFSC PORTB.7 ; jump next instruction if B.7 = 0 (validation) GoTo loop
ENDASM
mainprog: action for each command.....on Fis display if portb.7 = "0" then goto validmenu.... if portb.6 = "0" then menu=menu+1;goto fisdisplay if portb.5 = "0" then menu=menu-1;goto fisdisplay goto Start fisdisplay: .... ... lineK access ... validmenu:... ... ... return END
mazoul72
« Reply #5 on: November 06, 2011, 04:45:34 16:45 » |
PORTB.6 is at 3.5V , not 5V , i don't understand why  PORTB.5 and PORTB.7 is at 5V , very strange ... Regards Mazoul72
-Receive: 4460
« Reply #6 on: November 06, 2011, 07:03:16 19:03 » |
A schematic might help. How are you getting >> "i have +6.7V(RB7,RB6) and 4.98V(RB5) : VERY Strange ..." that is not so strange if your feeding 12v into output ports.
if your just driving 12v from the pic, why not use a fet as logic driver.
mazoul72
« Reply #7 on: November 06, 2011, 11:54:29 23:54 » |
It is strange because all should be at 6.7V with 12V driving . Without 12V from tachometer, in fact i have 5V on RB7 ,RB5 and on RB6 : 3.5V .ld all should be at 5V .
-Receive: 4460
« Reply #8 on: November 07, 2011, 12:43:16 00:43 » |
if you have any pin higher than the vcc, then you have a problem, your 12V is leaking into ciruit, thats why request for schematic. having a pin between > 0 to 5V is what you would see if static, having 3.5V means that pin is pulsing. High longer than the Low, a pin at 2.5V would be 50%.
16f877 has an operating voltage range (2.0V to 5.5V) 6.7 is a killer for pics.
« Last Edit: November 07, 2011, 12:47:15 00:47 by pickit2 »
mazoul72
« Reply #9 on: November 10, 2011, 10:54:27 22:54 » |
Hello, my second approach is the K-line protocol dato = data of tachometer ena = enable " " " " " clk = clock " " " " " suma=0 dat=126 ShiftOut dato, clk, 5,[dat] suma=suma ^ dat rem High dato dat=237 ShiftOut dato, clk, 5,[dat] suma=suma ^ dat rem Low dato dat=15 ShiftOut dato, clk, 5,[dat] suma=suma ^ dat rem High dato For cont=0 TO 15 (DATA caracters in PIC EPROM ) tmp=msg[cont] rem dat=255 - tmp dat= ~ tmp suma=suma ^ dat ShiftOut dato, clk, 5,[dat] rem Low dato Next cont dat=suma + 1 ShiftOut dato, clk, 5,[dat] rem Low dato High ena The problem is the data logging . i have a log file but i don't know what is the difference between each value .
« Last Edit: November 10, 2011, 10:56:55 22:56 by mazoul72 »
