February 23, 2025, 02:32:16 02:32
Pages: 1 2 3 [4] 5 6 7
Author Topic: Which Pic C compiler do you like?  (Read 41798 times)
strolch
« Reply #75 on: January 29, 2008, 03:26:02 15:26 »
I like for the 16 and 18 the PICC.
For the dsPIC the C30, because of the dsp-functions
Michael
dreamwithin
« Reply #76 on: February 05, 2008, 02:22:17 02:22 »
I was using PIC C16 18 before,but now i'm using CCS,it is good.
jay0124
« Reply #77 on: February 05, 2008, 02:44:07 02:44 »
i have purchased ccs c several years ago, i have done many small projects, i am happy with it.
inkwaterman
« Reply #78 on: February 05, 2008, 08:40:14 08:40 »
Hi !
I used and compiler for many projects ( Recently I used the CCS at work ), and I love this compiler.
The only bad point is that this compiler is full of bug.
I remember that when my company bought the version 4 after few days I returned to the version 3.249 to complete the project , because the 4 version was full of bug !
For you what's the less "bugged" version of CCS 4 compiler ?
eka586
« Reply #79 on: February 05, 2008, 09:54:02 09:54 »
If PIC24 OR PIC33, I prefer Microchip C30 Compiler.
Because It has TCP Stack library.
RsX
-Given: 16
« Reply #80 on: February 05, 2008, 11:06:57 11:06 »
I'm use CCS C Compiler. This is best choice for me.
mee too because there are a lot of function Smiley
i tryed to switch to mikroc but i didn't make it Sad
tuvoj
« Reply #81 on: February 16, 2008, 11:33:28 11:33 »
 Wink
CCS works just fine for most projects--Since Hitech wnt to Hi-Tide hosted--I won't use...
Tuvo
The Puma
-Given: 75
-Receive: 75
« Reply #82 on: February 16, 2008, 11:21:51 23:21 »
Use CCS-C, for my little projects enough... but it has many bugs  Embarrassed
oinan
« Reply #83 on: February 17, 2008, 06:51:36 18:51 »
Does anyone use CC5X C? I think it's more easy for past users
johanb_85
« Reply #84 on: February 18, 2008, 02:55:26 14:55 »
I like HT-PICC as it is ANSI C. I can use C-code from my AVR-GCC projects without much modification.
Nata39
« Reply #85 on: February 18, 2008, 07:30:38 19:30 »
I'm use CCS C Compiler. This is best choice for mos all,and very easy
mrpicing
-Given: 133
-Receive: 33
« Reply #86 on: February 19, 2008, 06:17:47 06:17 »
I use CCS C Compiler because it supports good delay functions and printf and has lot of libs.
It also restores Regs when servicing interrupts.
I know it has lot of bugs but tricking with these bugs is the solution. Keep Old version as "Gold"
because newer version may have more bugs than old one. Hum!
adamhorden
« Reply #87 on: February 20, 2008, 04:36:34 04:36 »
I use Microchip C18 student version at the moment with an ICD2 and MPLAB for all my personal projects with a home made development board. The ICD2 makes debugging really easy. You also have good debugging in MPLAB.
At uni we use IAR compiler with the eblocks system as a development board and programmer (http://matrixmultimedia.com/eblocks/index.php). Personally I don't like the IAR compiler and prefer to use Microchip C18 student version. I tend to do all my uni work at home and just demonstrate it at uni with my own home made development board. There is no debugging tools its just a case of compile burn and try again.
Adam
gargolan
« Reply #88 on: February 20, 2008, 01:49:31 13:49 »
I'm use mikroC Compiler. This is best choice for begin. Smiley
ChH
« Reply #89 on: February 20, 2008, 04:56:32 16:56 »
I've used CCS on 16FXX. Easy to use compiler. I'm also using the ICD40-U probe.
Now I'm switching to some 18FXXX so will use C18 from Microchip.
TigerX
« Reply #90 on: February 22, 2008, 09:09:07 09:09 »
I use ccs C compiler. I am new in PIC and tested some compilers. ccs C is very simple and effective. Also have drivers ready to use.
But, I didn't test the compiled hex code lenght is small or larger than other compilers. If anyone know the answer, I will be happy if explains...
jack12345
-Given: 57
-Receive: 134
Happy diy
« Reply #91 on: February 22, 2008, 08:59:25 20:59 »
hi.
I'm use HT-PICC Compiler. This is best choice for me.!
gandilf
« Reply #92 on: February 23, 2008, 12:31:31 00:31 »
I'm using Microchip C compiler, Hitech one and also CCS.  They all have their advantages and drawbacks.
jay0124
« Reply #93 on: February 23, 2008, 12:39:31 00:39 »
ccs c is the one i am using, i have done several projects, it's very nice compiler.
sonicm
« Reply #94 on: February 23, 2008, 06:43:32 06:43 »
mikro c
fastlink30
-Given: 15
« Reply #95 on: February 23, 2008, 09:41:20 09:41 »
ccs 4.xx is simple & quick to use, not like integrated editor
tcmnight
« Reply #96 on: February 24, 2008, 09:54:21 09:54 »
I use CCS 4. Simple and  good documentation.
leandrohuff
« Reply #97 on: February 27, 2008, 11:55:33 23:55 »
I try use SDCC to learn C but the compiler still in development for PIC Microcontroler and is hard to use, now I use MikroC to dev my circuits.
endSly
« Reply #98 on: February 28, 2008, 01:52:03 13:52 »
I'm using CCS Pic c compiler
jasonix
-Given: 48
« Reply #99 on: February 29, 2008, 03:09:03 15:09 »
hi, omni i try MikroC with pic16f877 and pic12f675 with good results
