mayler
Roger that!
« Reply #50 on: January 08, 2008, 02:59:14 14:59 » |
I am using CCS actually, because i think the implementation of internal functions of PIC are more natural than Hi-Tech... Maybe i will try again Hi-Tech someday  . My only concern about CCS is some bugs that the compiler still have ( 1 for that i used had a wrong asm implementation ).
Computer Engineer. Digital IC Designer - Cadence certified.
Futterama
« Reply #51 on: January 08, 2008, 03:17:33 15:17 » |
I'm using CCS PICC. Actually I don't like the built-in functions, I'd rather read the PIC datasheet. The wizard is great, a good starting point so you get get some simple code running in no time. The old IDE in version 3 was nice. The one in version 4 can be confusing - I had trouble with adding files to my projects until I discovered that including the file in the source code and then compiling it, would automatically include the file in the project window. But hey, I can just read the manual - but sometimes I'm like "Read the manual when everything else fails" ;-)
The CCS user forum is great, I you post all relevant information about your problem. I only use that forum for posting problems and I always write my solution when I find it - so others can benefit from it.
And last, the CCS compiler is often provided in this forum for free. I don't have the money to buy it yet :-(
Halex
« Reply #52 on: January 08, 2008, 05:13:29 17:13 » |
I am using mikroC, mikroElektronika C compiler. Its very useful compiler for beginer C programer.
neteagle
« Reply #53 on: January 08, 2008, 06:52:28 18:52 » |
I use CCS for more than 3 years now. Very efficient compiler, but with some minor bugs (I2C function). Some bugs with PIC12F integrated oscillators too.
spkt
« Reply #54 on: January 09, 2008, 07:25:08 07:25 » |
I think that CCS is very easy for beginner, because I don't need to watch carefully PIC datasheet
ugur
« Reply #55 on: January 09, 2008, 08:59:23 08:59 » |
Hi all. Im use PICC compiler.
phu_thanh
« Reply #56 on: January 09, 2008, 10:16:03 10:16 » |
Hi I like Microchip C compiler since it is a full-featured ANSI compliant C compiler.
lionking
« Reply #57 on: January 09, 2008, 08:45:14 20:45 » |
hi i use CCS C as a beginner but i am not sure about profesional process is CCS C enough for all ? thanks..
leandrohuff
« Reply #58 on: January 10, 2008, 04:14:24 16:14 » |
Hi all, I like to use CC5X by B Knudsen Data on http://www.bknd.com, very easy to intergrate into MPLAB, nice compiler to use with free editors. Thanks.
shibuv
« Reply #59 on: January 14, 2008, 09:30:12 09:30 » |
I am using Microelektronica C , it is very good
omni
-Given: 169
-Receive: 176
« Reply #60 on: January 15, 2008, 03:35:22 03:35 » |
It seems everyone has their own preference.  I have been using CCS C for awhile now and the compiler seems to have some deficiencies but otherwise it is fairly decent. I did read that some people have found problems with CCS and that CCS in general breaks two and fixes one thing with each new release. Perhaps a fully ANSI C compiler like Hi-Tech PIC C might be better in general but I'm yet to give it a real try. I looked at MikroC as well, and seeing its C code it appears to be something between HT-PIC C and CCS C. I wonder about the SDCC being a free multi-platform compiler and how it measures up to the rest...
valefrancy
« Reply #61 on: January 15, 2008, 08:49:49 08:49 » |
I started with PICC but after trying MIKROC was much more easy to write a program has many features that really is crive alone
ulderico
-Receive: 819
« Reply #62 on: January 15, 2008, 06:08:51 18:08 » |
Microchip C18 has everything you need for Pic18. Bye!
human_controller
« Reply #63 on: January 17, 2008, 01:57:58 01:57 » |
I am using PIC C
engvidal
« Reply #64 on: January 20, 2008, 01:26:18 13:26 » |
Ther is no easier than CCS. Look for Brazilian books
wnmaximino
-Given: 47
-Receive: 202
Homer
« Reply #65 on: January 20, 2008, 02:40:38 14:40 » |
I prefer MkroC, it´s very good compiler for PIC.
lutfuakcil
« Reply #66 on: January 22, 2008, 08:05:33 20:05 » |
CCS is very succesfull for code portation one to another PIC , but if you know assembly, you should choose hi-tech or C18
YSK
« Reply #67 on: January 22, 2008, 09:27:33 21:27 » |
Hi! I like to use "hi-tech picc". Because its ANSI support.
saint
-Given: 21
-Receive: 69
!! SAINTRULEZ !!
« Reply #68 on: January 22, 2008, 09:45:59 21:45 » |
Hi, I'm using CCS compiler...Main reason is, you write the code in "C"  (just kidding...) I'm also using the U40 programmer (ICSP) with CCS...Both of them supports almost all PIC series and programmer is really fast...CCS has really nice algorithm while converting the "C" code to the macros and than asm instructions...Therefore, your code does NOT consumes large space in PIC... saint...
« Last Edit: January 22, 2008, 10:05:37 22:05 by saint »
System Design Engineer...
!! You DON'T DIE if you "Thank" someone !!
Visit TURKEY on your next vacation...
yangzy
« Reply #69 on: January 23, 2008, 12:32:44 00:32 » |
I have been using CCS C for 5 years. I like it.
shobits1
-Given: 15
« Reply #70 on: January 24, 2008, 06:51:24 18:51 » |
hi I think PICC Compiler is the most powerfull, in other hand CCS C compiler is easy
but i like PICC
actionstk
« Reply #71 on: January 26, 2008, 05:25:43 17:25 » |
I'm use CCS C Compiler. This is best choice for me.
Posted on: January 26, 2008, 06:21:31 18:21 - Automerged
MikroC for me, pretty easy to use yehhh
vsmGuy
-Given: 11
« Reply #72 on: January 27, 2008, 10:39:26 10:39 » |
CCS !
camel_acml
« Reply #73 on: January 27, 2008, 01:41:40 13:41 » |
I finally can gather info frm u all
Orcino Borges
« Reply #74 on: January 28, 2008, 05:34:54 17:34 » |
CCS is very easy, but have more bugs. I use mickroc.
