bliviudaniel
« Reply #25 on: December 24, 2007, 12:13:32 12:13 » |
I work with Hi-Tech PICC for PIC16 and PIC18. This is mainly because I prefer to have one single platform for PIC16 and PIC18. Another reason is that I don't like CCS because it's not ANSI. I like to make my own peripheral drivers.
BLD
pak
« Reply #26 on: December 24, 2007, 03:50:02 15:50 » |
For beginner, Not much knowledge of microcontroller, I suggest to use CCS compiler because it is easier to understand about microcontroller and a lot of example for more understanding of compiler as well. But you must have C prog skill. Version 4 and above, driver files can be used such as keybd.c, lcd.c. The most I like CCS best is its built-in functions like delayms(500); it's really great for managing time frames. I find HiTech for adv user. the complier dose not come with useful examples and it assume that the user has knowledge of microcontroller.
sabri2008
« Reply #27 on: December 24, 2007, 04:05:51 16:05 » |
MikroC is more usefull for biginner thinks to its library.
schlen
« Reply #28 on: December 25, 2007, 12:19:15 12:19 » |
hi, i use proton, but i want to use micro c. I ll use it after take it.
siwat2
« Reply #29 on: December 25, 2007, 03:07:05 15:07 » |
I use HI-Tech PICC ,but now I'm testing CCS. I can't see the difference.
WatT
emulento
« Reply #30 on: December 25, 2007, 11:47:33 23:47 » |
PICC from CCS.
future
-Given: 11
« Reply #31 on: December 25, 2007, 11:56:20 23:56 » |
C30 from microchip
softjad
-Given: 12
-Receive: 95
« Reply #32 on: December 26, 2007, 11:14:48 11:14 » |
PICC from CCS!
faraz101
-Given: 189
-Receive: 1745
« Reply #33 on: December 26, 2007, 02:56:36 14:56 » |
i use mikro c and ccs both and found ccs is more power full and also easy to learn.specially its project wizard is very attractive for me
etm503
« Reply #34 on: December 27, 2007, 04:11:56 16:11 » |
I use CCS compiler. I had little knwoledge of embeded programming and had to learn a little standard c at first, but after that, I can do almost anything with CCS. I havent found the need to change yet
narc60
-Given: 12
« Reply #35 on: December 28, 2007, 06:09:03 06:09 » |
Still trying to learn CCS and so far as the other posters says its easy to use. Great for a beginners like me.
8K51
-Given: 86
-Receive: 40
« Reply #36 on: December 28, 2007, 08:13:04 08:13 » |
No unique choice for me !
When my work is mainly 'redesign' of ready made applications I use the original C compiler : USB 18F2550 (hid, cdc, mass storage) with Microchip C18 CAN, Nokia3110 LCD... with CCS 3.49 sometimes MikroC.... -When I build from 'white page' I prefer now BoostC: +Flowcode3 Demo as front end + Boost C libraries +Source level debugging with Mplab or Proteus +Programming/debugging with ICD2 Coming from 8051 world I appreciate near Ansi compilers and coding for easiest porting to others chips (AVR, PIC24)
kelvar
« Reply #37 on: December 30, 2007, 10:04:24 10:04 » |
For PIC16, i prefer Hi-Tech Pic-c. For PIC18, PIC24, DSPIC, etc i prefer Microchip's C18 and C30.
spkt
« Reply #38 on: December 30, 2007, 10:53:54 10:53 » |
How about MikroC?
Posted on: December 30, 2007, 11:48:59 11:48 - Automerged
I think that MikroC is very easy for beginner but I do not like it
arvind
« Reply #39 on: December 30, 2007, 03:46:42 15:46 » |
I like MikroC..being a beginner it seems to be really easy..
toni999
-Given: 51
« Reply #40 on: December 31, 2007, 12:55:06 12:55 » |
hello, I am using MIKRO C compiler too... it is work fine
rosebif
« Reply #41 on: December 31, 2007, 01:17:39 13:17 » |
I like hi-tech , it has an option of optimisation
lrom
« Reply #42 on: December 31, 2007, 02:50:45 14:50 » |
Microchip C18 has everything you need to code in C for PIC, and in microchip own forum you may find solutions to any problem you may have
trigo
« Reply #43 on: December 31, 2007, 04:58:58 16:58 » |
Microchip C18,c30
surachai
« Reply #44 on: January 01, 2008, 07:31:56 19:31 » |
My projects used 16Fxxx and use CCS C Compiler. The IDE have project wizard i like it.
tenir
« Reply #45 on: January 06, 2008, 12:12:18 12:12 » |
CCS c is easy to use but not usable with all microcontrollers. I also use CCS but I will migrate to IAR.
suresh kumar
« Reply #46 on: January 07, 2008, 12:38:44 12:38 » |
i use mikro-electronica's Mikroc. it has a lot of useful library functions. a free version of the software is downloadable from mikroelectronica's website. the free version is limited to program sizes of 2kb(600 lines of codes approximately)
huat
« Reply #47 on: January 07, 2008, 07:23:33 19:23 » |
softjad
-Given: 12
-Receive: 95
« Reply #48 on: January 07, 2008, 08:20:20 20:20 » |
lionking
« Reply #49 on: January 07, 2008, 09:02:05 21:02 » |
hi. i have just start interest pic but i dont know which compiler is good for me and i want to start it any program which can start beginer continue up to professionel programming by the way i know c. thank you !
