jim_17
« Reply #100 on: February 29, 2008, 03:29:56 15:29 » |
I use ccs, I think is the best one, because most people use it, and there are many information on the net.
mrwinch
« Reply #101 on: March 02, 2008, 11:48:24 11:48 » |
I love mikroC for pic and dspic: in my opinion it's a perfect and fast delivery solution, in particular with mikroe development board
mobeb
« Reply #102 on: March 05, 2008, 07:32:31 07:32 » |
I am using ccs C compiler, becase of very simple and effective. Also code optimization is better than other compilers
startt
« Reply #103 on: March 05, 2008, 03:09:33 15:09 » |
Hitech PIC C,I like it
leo777
« Reply #104 on: March 06, 2008, 09:15:04 21:15 » |
I'm using CCS PicC compiler
petarp
-Receive: 51
« Reply #105 on: March 10, 2008, 03:03:13 15:03 » |
I like CCS compiler, it's very easy to use.
wATAw
« Reply #106 on: March 11, 2008, 09:45:36 21:45 » |
I use ccs, because is easy. But i think you dont learn much with it....
pak
« Reply #107 on: March 13, 2008, 09:50:09 09:50 » |
Hi friends, I used Hi Tech, CCS and PICBasic compilers in my hobby projects. I find that all compilers have adv and disadv. In Basic compilers, you have to use their pre-defined codes, such as LCDIN, HSERIN and you have to familiar with codes before using them. In C compiler, you can change their pre-defined code such as lcd.c. If you use CCS, it is easier to understand and use. It has great built-in functions like delayms, printf, especially delay function is always use in any microcontroller source code. CCS made delay function accurated over any crystal frequency. Unfortunately, Hi Tech does not have very good delay function. CCS made a lot of build-in function to attract customers like students and hobbists. In my opinion, try not to use built-in fucntions of CCS unless you tested the function and understand very well. You can check the function with asm file that is generated by CCS compiler.
Hope it will help,
pak
nvicchi
« Reply #108 on: March 30, 2008, 09:44:50 09:44 » |
I use C18 for 18F, CCS for 16F (simply because C18 cant be used for those uC). I recommend you not to use the built-in functions from any compiler. They usually are very generic (thus, making bigger ans slower code), and compromise portability. For ex, if you need to set up a timer, dont use a "set_up_timer" function, just set it up!!! Also, to keep compatibility to it's top, use headers with definition for each compiler. For ex, in C18 you use PORTBbit.RB0 to access RB0, and in CCS you use #byte PORTB = 0x006 and #bit PORTB0 = PORTB.0 If you keep 2 headers, one for each compiler, where you define (for C18) #define RB0 PORTBbits.RB0 and (for CCS) #byte PORTB = 0x006, #bit PORTB0 = PORTB.0, #define RB0 PORTB.0, and use through all the code "RB0", all you have to do to move from one compiler to another is to change the header you use.
Regards, Beto
ninjammx
« Reply #109 on: March 30, 2008, 10:44:32 22:44 » |
Hi, I'am use CCS for 16FXXX. It quite simple. anyone, Can share about HT-PICC ? What is it strong point?
mcnscott
« Reply #110 on: March 31, 2008, 03:03:12 03:03 » |
I learned with CCS doing a project from rentron talking time and temp clock. However, for ease of use I've found C18 the easiest to experiment with. I'm just starting with C30 though, Hi-Tech claims to be fully ANSI compliant, so I may drift over there.
mikepic
« Reply #111 on: April 02, 2008, 08:18:42 08:18 » |
Althoug is true that it has excessive version rotation, I prefer the CCS because the amount of information in the internet and the ease of use. The best of this compiler is the great driver library included for I.C.'s like PIC's, EEPROMS, sensors and so on
lead_inovation
-Given: 85
« Reply #112 on: April 02, 2008, 02:34:53 14:34 » |
i'm using C30,C32. because: 1)it's full library for peripheral dspic and Pic32. 2) it's ANSI C. 3) it's (free with student edition). and free IDE (MPLAB IDE)
cooperharris
-Given: 72
-Receive: 22
« Reply #113 on: April 02, 2008, 03:09:27 15:09 » |
I think that one of the best ones is ccs,because is very complete, and there is a lot of information in the web in case you get lost
m3ni4k
« Reply #114 on: April 04, 2008, 04:45:49 04:45 » |
Microchip PIC C compiler.. it is very useful
mirkatmir
 Warned
-Receive: 28
« Reply #115 on: April 04, 2008, 06:50:36 06:50 » |
I'm just starting with PIC now, and I use a MikroC compiler. It is good for me.
Angor
« Reply #116 on: April 09, 2008, 07:57:34 19:57 » |
I'm using CCS C and MPLAB IDE with ICD2
cjq_sh
« Reply #117 on: April 12, 2008, 05:03:57 17:03 » |
I am using HI-TECH compilers
cooperharris
-Given: 72
-Receive: 22
« Reply #118 on: April 12, 2008, 05:23:25 17:23 » |
I am using ccs compiler and is pretty cool!
eemkutay
-Given: 21
-Receive: 220
Knowledge is Power
« Reply #119 on: April 12, 2008, 11:10:35 23:10 » |
Hi-tech is the best.
Kloswiski
« Reply #120 on: April 13, 2008, 04:28:28 04:28 » |
I prefer CCS c compiler. it's simpler and has good rich source of library of functions. try it.
engaddar
« Reply #121 on: April 13, 2008, 09:37:50 21:37 » |
picc compiler is the one.
ferbusi
« Reply #122 on: April 17, 2008, 10:14:23 22:14 » |
the ccs have the best libraries, but c18 is of microchip and this is important
fire_rayo
« Reply #123 on: April 17, 2008, 10:15:32 22:15 » |
CCS C
nullos
-Given: 24
« Reply #124 on: April 17, 2008, 10:41:11 22:41 » |
i want to test Hitech but i see it's harder than CCS
