January 01, 2025, 01:11:09 13:11
Author Topic: Probleme "echo" when i send data  (Read 3627 times)
racattac13
« on: June 30, 2007, 05:40:57 17:40 »
in first sorry for my english....
I have a problem with my smart card 16f877 when I send data , it repeat the same data   :
example :
when i send AAAAAAA with my card reader to my card , he must to response only BB  , but it response AAAAAAABB
Here is the sendbyte function   (i use PCWH compiler )
main()
sendByte("0xBB");
void sendByte(int iSendData)
int iParity;
int iCtr;
int iPauseCtr;
#asm
movlw 0x32 ; Pause for 170 ?s
call Pause ; call Pause
bcf PORTB,7 ; Send start bit in RB7
movlw 0x7F
tris PORTB ; TRIS PORB with 01111111 (0x7F)
clrf iParity ; Initialize Parity to 0
movlw 0x08
movwf iCtr ; Initialize 8 to counter to send 8 data bits
send_loop:
call Std_pause ; Pause for 93 ?s (at 9600 bps)
rrf iSendData,f
rrf iSendData,W
andlw 0x80
xorwf iParity,f ; Calculate Parity
xorwf PORTB,W
xorwf PORTB,f
decfsz iCtr,f ; Decrement Data Bit counter
goto send_loop ; Loop
movf iParity,W ; Send Parity
xorwf PORTB,W
xorwf PORTB,f
call Std_pause
movlw 0xFF
tris PORTB
movlw 0x3E
goto Pause ; Pause 0x3E
return
Std_pause:
movlw 0x1A ; Standard Pause Value
Pause:
movwf iPauseCtr ; Initialize iPauseCounter with value of W Register
Pause_loop:
decfsz iPauseCtr,f ; Decrement Pause Counter
goto Pause_loop
#endasm
I have read many topic but I found nothing.
Please help me , how can i flush input data register before response Huh?
Many thanks in advance.
robban
-Given: 34
-Receive: 38
Warrior
« Reply #1 on: June 30, 2007, 11:36:30 23:36 »
Tricky, that one...
To start with, does the "tris" command comply with the 16F877? Have a look in the dataheet.
Microchip recommend not to use it for upward compatibility.Use "movwf PORTB" instead. And why do You say it responds with "AAAAAAABB" when You only send "BB" as Byte, not Char? You must suppy more of the code. Otherwise, in assembler You can always flush(zero out) a register with "xor reg,reg". (or in MPASM .asm CLRF or CLRW.)
Well...?
« Last Edit: July 02, 2007, 05:22:37 17:22 by robban » Logged
Code Warrior
