April 29, 2025, 12:23:00 00:23
Author Topic: CSoft Project Studio CS R5.1.017  (Read 7420 times)
Annu
-Receive: 137
« on: August 24, 2011, 03:18:55 03:18 »
A specialized application for system AutoCAD, Autodesk Architectural Desktop, AutoCAD Architecture, Autodesk Building Systems, AutoCAD MEP, intended to perform sets of working drawings grade AC, AR, QOL and ECC. All modules of the complex developed on the basis of Russian standards and certified.
About CSoft Development
CSoft Development – a leading software developer for the CAD market in mechanical engineering, industrial and civil engineering, architectural design, land use planning and GIS, electronic document processing scanned drawings, vectorization and hybrid editing.
Since its inception the company intends to create their own applications, which in combination with software from the world leaders can solve problems in the field of CAD at the highest level and in the light of Russian realities. Currently CSoft Development is more than 60 developments – ranging from full-featured applications that are sold in over 60 countries around the world, and ending with integrated systems for industrial companies and design organizations.
CSoft Project Studio CS – a specialized application to a system of Autodesk AutoCAD, designed for sets of working drawings grade AC, AR, QOL, and ECC. All modules of the complex developed on the basis of Russian standards and certification.
In the package solution Project StudioCS, for architectural and construction design work in AutoCAD includes the following modules:
- PS-system kernel 5.1.017
The base module, which comes complete with all modules of the program
- PS-Architecture 1.8.017
Special solution for the development of architectural models and working drawings (AR, AI) in strict accordance with national standards.
- PS-Designs 5.1.017
Specialized graphics application designed for designers, developing a set of working drawings and brands QOL and ECC in strict accordance with national norms and standards.
- PS-Foundations 5.1.017
Specialized graphics application designed to prepare layouts and drawings of foundations on piles and natural grounds, including the calculation basis for the deformation of foundations for the columns of industrial and civil buildings, prefabricated and monolithic strip foundations under the brick walls and foundation blocks, the calculation of dolphin on the strength of the carrier the ability of the pile.
New features and changes in CSoft Project Studio CS 5.1.017:
Fixed bugs found during the operation of the previous assembly.
Project StudioCS Kernel 5.1
- Changed the algorithm for downloading the font CS Standard at the start of the program.
- Changes to Standard, inserting format A4/A3 frame size is now below 10 mm.
- Fixed a mechanism for PS-partition table in AutoCAD table are stored assigned when creating the line weight.
- A well-appointed changing the line weight and use the settings to existing tables.
- The algorithm of text editing within a cell.
Project StudioCS Architecture 1.8
- Fixed statements forming section (sheet flooring, trim, etc.).
- Fix all errors related to the lack of illustrations in the dialogs module.
Construction Project StudioCS 01.05
- The algorithm of forming sheet steel consumption. Excluded from the calculation of the entities for which the reset apparatus includes a specification.
- Fixed data used in calculating the length of embedment, size, and bypass valves bend radii A500SP class.
- Fixed command-processing algorithm for metal mirror that is pasted with a nonzero angle.
- At the start of the dialog box commands stored previous value of the angle of rotation.
- Changed the format specification of concrete structures.
- Supplemented by a database product mix for production of reinforcement cages. In appointing the longitudinal rods Class A500S previously zeroed lists of valid values ??for the transverse rods.
Foundations Project StudioCS 01.05
- Fixed display of size of the tip immersion in the pile-carrying layer of soil.
- Changed the algorithm for calculating the bases in the presence of a basement.
- Fixed an error in the calculation of the bases in the newly created and not saved the drawing in Windows 7.
Platform:
- Autodesk AutoCAD 2005/2006/2007/2008/2009/2010/2011/2012
- Autodesk Architectural Desktop 2005/2006/2007 or AutoCAD Architecture 2008/2009/2010/2011/2012
- Autodesk Building Systems 2005/2006/2007 or AutoCAD MEP 2008/2009/2010/2011/2012
Version: 5.1.010 32bit
Developer: www.csoft.ru
Language: Russian
Operating system: Windows XP / Vista / Seven
File size: 165.6 mb
http://www.filesonic.in/file/1737102784/cspsr51017.rar
http://www.wupload.com/file/117339460/cspsr51017.rar
http://www.fileserve.com/file/zgaGjX9/cspsr51017.rar
http://www.uploadstation.com/file/xsM5pbz/cspsr51017.rar
