January 04, 2025, 06:29:29 06:29
Author Topic: opinions about CCS Compiler  (Read 4503 times)
inkwaterman
« on: June 15, 2007, 06:56:59 18:56 »
Hi !
I'm writing to you for ask some questions about the CCS Compiler.
I use the CCS for work, and recently  I passed to the Version 4.038.
Unfortunately I have found many and many bugs , and I am thinking seriously to change the compiler, or at least change the version...
For you experience, What's the most reliable version of CCS compiler ?
Is the Hitec C compiler more reliable than the CCS compiler ?
Have you some advices to give about the compiler ?
Best regards
planet69
« Reply #1 on: June 16, 2007, 01:50:54 01:50 »
I compiling my project using PCWH 4.038 via MPLAB 7.50
The problem is after a few sessions of compiling, the MPLAB window closes automatically.
Does anyone here face the same problem? More importantly does anyone here knows what's wrong?
cerebronico
-Given: 264
-Receive: 27
« Reply #2 on: June 16, 2007, 02:02:30 02:02 »
yeah! CCS is like a wild horse, you must tame it before you ride, but i think it's only the IDE, that's why i prefer to use ultraedit32 as the IDE since it is totally customizable and has a very useful autocomplete feature
Anyway I'm wondering if there is a better compiler (somebody has used Source Boost C compiler?)
Greetings
inkwaterman
« Reply #3 on: June 16, 2007, 08:53:03 08:53 »
I used the CCS 4.038 for a PIC 18F2523 based project, and I had many problem with memory pointer.
But if I compile the code for the PICF2680 the same code works right !
I have search in to the CCS forum and in to the CCS documentation about this behavior  but I didn't found anything...
micropar
-Given: 44
« Reply #4 on: June 16, 2007, 01:35:24 13:35 »
Hi inkwaterman and Cerebronico,
Please refer to my all reply here in this topic:
http://www.sonsivri.com/forum/index.php?topic=2926.0
I hope you may find correct answer to your questions.
--micropar--
hate
-Given: 156
-Receive: 355
« Reply #5 on: June 16, 2007, 09:39:53 21:39 »
You can also refer to my replies in the topic 'micropar' referred. Wink
Regards...
Regards...
FriskyFerret
-Given: 513
-Receive: 360
Put it in, take it out.
« Reply #6 on: June 17, 2007, 03:34:34 03:34 »
Use CCS v3.249. I've used it extensively and can say it is a very stable, useful compiler. The one I prefer above the rest.
I have the hardware debugger from CCS as well and it works nicely with the v3.249 compiler. The hardware debugger is a real bargan at $80 US.
I was expecting the v4 product to be more stable by now. Perhaps we'll have to wait until '08.
prosoft
« Reply #7 on: June 30, 2007, 11:26:37 11:26 »
I think, that now for work with PIC16+MPLAB7.50 version PCWH 4.013 is the best choice.
Best regards
hate
-Given: 156
-Receive: 355
« Reply #8 on: June 30, 2007, 12:33:56 12:33 »
Use the latest version 4.038 I think not 4.013!
Regards...
Regards...
