AutoDesk AutoCad 2012
Autodesk AutoCAD (2012) 86/64 100% Working
AutoDesk AutoCAD 2012 Multilanguage
Languages: English, French, Italian, German, Spanish, Portuguese
For 32-Bit AutoCAD 2012 Microsoft® Windows® 7 Enterprise, Ultimate, Professional, or Home Premium (compare Windows 7 versions); Microsoft® Windows Vista® Enterprise, Business, Ultimate, or Home Premium (SP2 or later) (compare Windows Vista versions); or Microsoft® Windows® XP Professional or Home edition (SP3 or later)
For Windows Vista or Windows 7: Intel® Pentium® 4 or AMD Athlon® dual-core processor, 3.0 GHz or higher with SSE2 technology; for Windows XP: Intel Pentium 4 or AMD Athlon dual-core processor, 1.6 GHz or higher with SSE2 technology
2 GB RAM
2 GB free disk space for installation
1,024 x 768 display resolution with true color
Microsoft® Internet Explorer® 7.0 or later
For 64-Bit AutoCAD 2012 Microsoft Windows 7 Enterprise, Ultimate, Professional, or Home Premium (compare Windows 7 versions); Microsoft Windows Vista Enterprise, Business, Ultimate, or Home Premium (SP2 or later) (compare Windows Vista versions); or Microsoft Windows XP Professional (SP2 or later)
AMD Athlon 64 with SSE2 technology, AMD Opteron® processor with SSE2 technology, Intel® Xeon® processor with Intel EM64T support and SSE2 technology, or Intel Pentium 4 with Intel EM64T support and SSE2 technology
2 GB RAM
2 GB free space for installation
Internet Explorer 7.0 or later
Additional Requirements for 3D Modeling (All Configurations)Intel Pentium 4 processor or AMD Athlon, 3 GHz or greater; or Intel or AMD dual-core processor, 2 GHz or greater
2 GB RAM or more
2 GB hard disk space available in addition to free space required for installation
1,280 x 1,024 true color video display adapter 128 MB or greater, Pixel Shader 3.0 or greater, Microsoft® Direct3D®-capable workstation-class graphics card
What is AutoCAD 2012 software?
You can design and shape the world around you with the powerful, flexible features
found in AutoCAD software, one of the world’s leading 2D and 3D design software
products. New and expanded workflows for model documentation, reality capture, and
3D conceptual design help increase productivity with AutoCAD 2012. Explore your
design ideas with powerful surface modeling tools. Quickly create documents from a
variety of modeling formats, helping to reduce manual documentation workarounds.
Capture and import as-built information to jumpstart your design process. Plus, you’ll
find a wide range of timesaving enhancements to the features you use most. AutoCAD
2012 delivers the powerful tools you need to participate in smooth 3D design
workflows, helping drive your projects to completion more quickly than ever before.
You can mount or create the bootable ISO.
or extract all the files from the disk into a folder and
run "setup.exe" from there.
My testing was done on a 32-bit OS and a 64-bit OS.
MY SUGGESTION IS FOR PEOPLE TO extract all the files from the disk into the folder.
Use the "setup.exe" from the folder to install the program.
THIS WILL KEEP YOU FROM HAVING TO RESTART THE SETUP AGAIN.
If you get the "insert CD #2" error. Create a folder
somewhere on your pc, extract all the files from the disk into the folder.
Download: Power ISO tool:
https://www.rapidshare.com/files/483787467/Power_ISO.rar1)
Downloaded the files, extract to create your ISO.
Open the ISO and copy/paste the"Pony-Patch"
folder to your desktop.
Minimize the folder as you will use this as you
proceed with your install.
2)
Run Setup.exe and install Autodesk Autocad
Select your Language
3)
Select I have my product information
Use there serial Number provided in the patch
folder named "Pony-Patch"
You should have this minimized at this time.
Enter the serial numbers and product key.
then click "next"
Select your install
-Choose StandAlone
3A)
Finish the installation and close autodesk
4)
Restart Autodesk Product
Before clicking on Activate Disconnect from the internet
5)
Click on Activate
Check I have read the "Autodesk Privacy Policy"
Then Continue.
6)
Pick "I have an activation code from Autodesk"
This will give you a request code, copy and paste(ctrl+c) to notepad. You will need this to get
your activation code
Example none working code.
qgcz z512 jq4d joy6 q95q 4r99 doky gezy
7)
Open the crack folder you have minimized,
start XFORCE Keygen 32bits version if you are installing a 32bits application and
64bits if you are installing a 64bits application.
FAQ ABOUT KEYGENS.
This is a multi keygen. Most keygens are picked up by your AV as a virus.
This file is 100% safe. It doesn't have any infection and just runs,some play music,some just generate the keys you need.
1) You may need to change your UAC.
Control Panel\All Control Panel Items\User Accounts/chnage user account controls
2) Give your user full control of the patch/keygen.
right click on the patch/keygen
Prperties/Security/advance/Administrators/Change Permissions/
Administrators/edit/allow full control/apply all.
3) Some AV programs (AVG for one) need to also be disabled during installation.
Click on "Mem Patch" (you should see successfully patched)
9) Note: Make sure to run the Keygen as administrator and with UAC off in Vista or Windows7
Copy the request code into the keygen and press generate
you can use ctrl+c / ctrl+v for copy/paste
This will give you a group of numbers and digits, 50+ in all
A1B2C3D4E5F6G7H8I9J1K2L3M4N5O6P7Q8R9S1T2U3V4W5X6Y7Z1A2B3
10)
Now copy the activation code, all 50+, into box #1.
This will fill the boxes with the codes.
Then click next..and you are all set.
11)
You know have a working copy of AutoDesk AutoCad 2012...enjoy
MegaUpload - Deleted Files
I will have my own links up as soon as I get 32 & 64 bit ready in case the uploader's go down.
