November 21, 2024, 09:52:42 09:52
Author Topic: mixing RTOS with conventional programming  (Read 10646 times)
odsk
-Receive: 12
« on: June 06, 2011, 06:51:08 18:51 »
I am trying to use RTOS for my future desing and do have a newbie question to the experts:
Can I mix convetional programing (using interrupts...etc) with RTOS processes?
I am trying to receive data through UART and was hoping to use interrupt driven events to receive the data compared to running a process at determined intervals (RTOS) for fetching the data.
ODSK
-Given: 833
-Receive: 4320
« Reply #1 on: June 10, 2011, 07:28:28 19:28 »
simple answer is yes.
http://www.scribd.com/doc/46919105/RTOS
RTOS Scheduling Algorithms Polled Loop System w/interrupts
• Polling system goodfit; however, several time sensitive critical tasks exists
• Example: transistor amplifier overheat
– employ interrupts
RTOS Scheduling Algorithms Interrupt Driven System
• Main program consists of systeminitialization activities
• System then placed in continuous loop towait for interrupt driven events
• System prioritizes multiple interrupts andhandles highest priority tasks first
• Example: Wall-following Robot
« Last Edit: June 10, 2011, 08:04:48 20:04 by pickit2 » Logged
sam_des
-Given: 128
-Receive: 151
« Reply #2 on: June 11, 2011, 03:45:00 03:45 »
Yes, you can. In fact that's how the systems with OS works. Most of the time your tasks are blocked, waiting for something to happen. Like timer expire, button press or serial rx/tx etc.. And when it happens OS wakes/unblocks the corresponding task which takes the necessary action and returns to blocked state.
That's how you can determine the loading of your processor. Just measure how much time it spends in idle task within OS  Wink
Only requirement in case of interrupts is that you must inform OS about it. OS requires this information for handling interrupt nesting and context switching(in case an interrupt makes higher priority task ready). Since in RTOSs, Application handles the interrupts instead of OS, it's the duty of application to inform OS about it
There is no need to wake the task on each received byte or some predetermined interval. All you have to do is to agree upon the FRAME which will be used to both transmit and receive. After that your interrupt will continue receiving data until complete frame has been received and wake the task only then. That way none of processor time is wasted and task executes only when required.
Note that you require BYTE FIFO queues and many RTOSs does not provide them. Instead they provide message queues which are usually used for intertask comm. You can use them, but that will waste the RAM as message queue element is usually (void*) pointer. In that case you may require to write down your own BYTE queue function using other OS services.
hope that helps
sam_des
pak
« Reply #3 on: December 08, 2011, 05:57:34 05:57 »
Just need to take care of global variables by using two methods,
1) Stop/Restart interrupt and os scheduler
2) message from ISR to Task
pak
  Smiley Happy Microcontroller Programming  Smiley
