April 01, 2025, 11:02:18 23:02
Author Topic: OSA RTOS and MikroC Pro 4.60  (Read 16682 times)
PCROBOTICS
-Given: 977
-Receive: 178
Smile souling my love, weŽll always be together...
« on: May 19, 2011, 07:32:26 07:32 »
Smiley Hi I'm starting to work with OSA RTOS and am trying to make it work using the compiler MikroC PRO 4.60 and pic12f675 microcontroller, I have not made ​​it to work and need help from someone who has made ​​or more experience in this of the RTOS to please help.
"We are made of stardust."
Carl Sagan
sughoi
-Given: 221
-Receive: 53
know thyself because what else is there to know
« Reply #1 on: May 19, 2011, 08:08:47 08:08 »
Dear PCROBOTICS
I'm also a newbie in RTOS applications. It is not easy to find right documents and right libraries, even finding a "hello world" project. All the example program neither can be complied nor can be changed by the user in a simple way. But anyway I hope we will do it one day!
The main problems are adding a lot of header & source code and making a couple of configuration. Till now the simplest RTOS I have ever seen is CCS compiler's RTOS. Easy to use and no need to make a huge amount of configuration.
best regards, sughoi
pelctronics
« Reply #2 on: May 19, 2011, 09:41:48 09:41 »
include osa.h;
void Task1 (void)
 for (;;)
    TRISB=0;
     PORTB=255;            //create task
     Delay_ms(150);
     PORTB=0;
     Delay_ms(150);
     OS_Yield();
void Task2 (void)
 for (;;)
    TRISB=0;
     Delay_ms(150);
     PORTB=0;
     Delay_ms(150);
     OS_Yield();
#pragma funcall main Task1  //this is important to MikroC
#pragma funcall main Task2
void main()
 OS_Init();
 OS_Task_Create(7, Task1); // 7 is priority , name of task is pointer to function where is your task in memory.
 OS_Task_Create(7, Task2);
 OS_Run();
cheers
sughoi
-Given: 221
-Receive: 53
« Reply #3 on: May 21, 2011, 11:27:12 11:27 »
Dear friends I have a question I want to manage three different tasks via OSA and mikroc source code, even though I configured the system for 3 different tasks the system only manages 2 different tasks. If some helps me, I will be appreciate. My two source codes (main and OSAcfg) is below;
#include "osa.h"
#define T2CON_CONST     0x25        // post = 8, period = 250*4*5* 0.2 us = 1 ms
#define PR2_CONST       (250-1)
void Init (void)
    TRISB = 0x00;
    PORTB = 0x00;
    T2CON = T2CON_CONST;
    PR2 = 250-1;
    INTCON = 0;
    PEIE_bit = 1;
    TMR2IE_bit = 1;
void interrupt (void)
    if (TMR2IF_bit)
        OS_Timer();
        TMR2IF_bit = 0;
void Task_1 (void)
    for(;;)
        OS_Delay(65);
        PORTB.F0 = ~ PORTB.F0;
void Task_2 (void)
    for(;;)
        OS_Delay(230);
        PORTB.F1 = ~ PORTB.F1;
void Task_3 (void)
    for(;;)
        OS_Delay(250);
        PORTB.F2 = ~ PORTB.F2;
#pragma funcall main Task_1
#pragma funcall main Task_2
#pragma funcall main Task_3
void main (void)
    Init();                             // Init periphery
    OS_Init();                          // Init OS
    OS_Task_Create(0, Task_1);    // Create tasks.
    OS_Task_Create(0, Task_2);   //
    OS_Task_Create(0, Task_3);     //
    OS_EI();                            // Enable interrupts
    OS_Run();                           // Running scheduler
-------------------------------------OSAcfg is below;
// This file was generated by OSAcfg_Tool utility.
// Do not modify it to prevent data loss on next editing.
// PROJECT NAME: Running lights
// PLATFORM:     mikroC for PIC16
#ifndef _OSACFG_H
#define _OSACFG_H
// SYSTEM
#define OS_TASKS                3   // Number of tasks that can be active at one time
#define OS_DISABLE_PRIORITY         //
// ENABLE CONSTANTS
#define OS_ENABLE_TTIMERS           // Enable task timers (OS_Delay and OS_xxx_Wait_TO)
#endif
Edit: Use Code posting samples of code.. Make it easy for others to read and no Wink;
« Last Edit: May 21, 2011, 11:42:53 11:42 by pickit2 » Logged
odsk
-Receive: 12
« Reply #4 on: July 28, 2011, 04:16:59 04:16 »
I did test your code and works good for me,
3 processes running.
vantusaonho
-Given: 22
-Receive: 21
« Reply #5 on: September 15, 2012, 05:20:50 05:20 »
Hi, I also use MIkroC for Pic in several year. I would like to program RTOS for Pic by mikroC. You can see this link for instruction:
http://wiki.pic24.ru/doku.php/en/osa/ref/description/project
