April 26, 2025, 06:34:30 06:34
Author Topic: [req]Adobe flash CS3 or cs 5  (Read 4502 times)
janakfun
« on: May 08, 2011, 07:10:56 19:10 »
hi all,
 I need adobe flash sc3 or sc 5 software.. I have searched here but all the links are dead.. gives message like "File not found"..
Can anyone share a fresh and working link??
Janak
nidhisahu
-Given: 8
-Receive: 5231
Because Knowledge Should Be Free for ALL
« Reply #1 on: May 08, 2011, 08:21:46 20:21 »
Adobe Flash Professional CS5.5 v11.5.0.325 Portable | 506 MB
Adobe® Flash® Professional CS5.5 software is the industry-leading authoring environment for producing expressive interactive content. Create immersive experiences that present consistently to audiences across desktops, smartphones, tablets, and televisions.
Expanded platform and device support
Reach audiences on the latest Adobe Flash Player and Adobe AIR® runtimes and on Android™ and iOS devices.
Efficient workflows for mobile development
Manage FLA project files that target multiple devices. Share code and assets across documents and device targets to efficiently create, test, package, and deploy content for a wide range of screens and devices.
Content scaling when resizing stage
Save time when sharing symbols and motion paths across documents that are optimized for different screen sizes.
Enhanced layer control
Preserve important document structure when copying layers across multiple files and projects.
Symbol rasterization and better performance
Use new tooling options, on-stage symbol rasterization, and the Property Inspector to improve CPU, battery, and rendering performance on mobile devices.
Enhanced code snippets handling
Use the new pick whip to preview and visually add more than 20 new code snippets, including ones for creating mobile and AIR applications, use of the accelerometer, and multitouch gestures.
Streamlined Publish Settings dialog box
Publish content quickly and more efficiently with a redesigned Publish Settings dialog box.
Inverse kinematics pinning support
Lock inverse kinematics bones to the stage and set stage level movement restrictions to selected bones. Create multiple spans per layer, and define more complex movement of armatures, such as walk cycles.
Auto-save and file recovery
Ensure consistency and integrity of your files, even after computer crashes or power outages.
Incremental compilation
Use asset caching to reduce the compile time of documents that use embedded fonts and sound files, and deploy rich content faster.
Customer-inspired enhancements
Benefit from numerous user-requested improvements, including improved controls for the Text Layout Framework.
Seamless mobile testing
Perform source-level debugging on Adobe AIR enabled devices that are connected with a USB cable, running content directly on the device.
Homepage: http://www.adobe.com/products/flash.html
Links
http://www.filesonic.com/folder/4585881
(Links are working but Software is not tested by me but reported as working on WinXp Sp3 and Windows 7)
Vlsi@IIT
