November 28, 2024, 10:44:36 10:44
Author Topic: HELP: BATTERY CHARGER USING MC33340 IC  (Read 4943 times)
charudatt
-Given: 53
-Receive: 70
« on: April 16, 2011, 09:40:19 09:40 »
I am working on a design of a Ni-MH battery charger using ON- SEMI's IC MC33340.
I am a bit confused in determining the values of R2/R1 the voltage divider circuit on Pin#1.
I am interested in charging 4 (1.2V) @2500mAH Ni-MH cells in series with the proposed charger.
Could anyone help me derive the values of these resistors using the formula mentioned in the DS.
Has anyone successfully built a Smart Charger using this chip ?
titi
-Given: 3807
-Receive: 834
« Reply #1 on: April 16, 2011, 11:29:25 11:29 »
Hi charudatt,
Effectively datasheet explications are not realy clear.
I have understand that Vsen (pin 1) can't exceed 2v, so they say : In order to obtain maximum sensing accuracy, the
R2/R1 voltage divider must be adjusted so that the Vsen input
voltage is slightly less than 2.0 V when the battery pack is
fully charged.
So, if you have 4 elements, as you can see in datasheet Figure 9, the max voltage in 1.55v for full charge so VBatt is 1.55*4.
use 1.8v for Vsen (too have goot sensitivity)
You need to fixe R1
And use formula R2=R1*((VBatt/Vsen)-1)
I have found a application schematic for MC33340 with 4 elements (they used R1=560K and R2=1M) page 2
May be this help you.
Best regards.
charudatt
-Given: 53
-Receive: 70
« Reply #2 on: April 17, 2011, 03:07:45 15:07 »
Thank you Titi. I shall try it and post my finding.
