mick the mend
-Given: 109
-Receive: 101
« on: April 11, 2011, 07:03:13 19:03 » |
A friend has asked me if I can build a timer to control a door lock/opener to operate twice a day - open just after dawn and close just after dusk. I was going to use a simple Pic and LCD. I would like to use Flow Code but at my age I can't get my head round the logic so any guidance would be welcome. I don't mind building the lookup table for the calender timing as that part is just boring (365 open 365 close) bugger the leap year.
sphinx
-Given: 683
-Receive: 387
« Reply #1 on: April 11, 2011, 07:26:19 19:26 » |
use a photo resistor that you use for sensing light/dark then just a relay for it to open as soon set lightness is ok then when it gets dark close circuit no need for either pic or lcd
/regards
-Given: 582
« Reply #2 on: April 11, 2011, 09:34:47 21:34 » |
That takes all the fun out in building one and our hobby :-)
« Reply #3 on: April 12, 2011, 06:30:46 06:30 » |
 Yes..and you can wave your hand over the light sensor and it's "dusk" any time of day....with a flashlight, the "sun" can rise all night. There may be a RTC chip or app note for a micro, arduino, or whatever, that'll get you there with a clock. Speaking of which, you can take the minute and seconds hands off a clock movement, use a brass hour hand, and use it as a 12 hour switch pole by drilling a hole in the clear plastic cover...mechanical contact or optical switch from there....if that's too James Bond for you, a simple wall timer running on the mains will do it as well
oldvan
-Receive: 107
If the van is a Rockin'...
« Reply #4 on: April 12, 2011, 09:06:13 09:06 » |
Many PIC24F family have RTC built in, takes care of the clock issue with limited pain.
The MacGyver options add more adventure for sure.
New feature idea: Fox detector that does NOT open the door if a fox is waiting in a dinner jacket & carrying a fork.
« Reply #5 on: April 12, 2011, 05:48:10 17:48 » |
Negative side of RTC is it need battery or capacitor backup, once it missing the timing will be messy. Imagine how to change that little backup battery and / or re-ajdusting the RTC on the top of street lighting pole. Got this kind of problematic once, with a remote sensing device which is located deep in the forest.
oldvan
-Receive: 107
« Reply #6 on: April 12, 2011, 08:33:19 20:33 » |
Ichan: Most people I know don't raise their chickens on top of street light poles, lest all the eggs are scrambled.  Could say phooey on RTC, go GPS like I did on my garage clock 9 years ago. http://oldvan.com/garage/When the stated goal is dawn and dusk, a photo-sensor seems most sensible and least expensive. Maybe the chickens don't want out as early on dreary days anyhow.
mick the mend
-Given: 109
-Receive: 101
« Reply #7 on: April 12, 2011, 08:51:45 20:51 » |
Ok all, this isn't a joke. The clock chip is all very well but dawn and dusk varies by hours during the year so not a lot of use. using a light sensor has been tried without success as hens KNOW when dawn is regardless of the actual light levels which vary a lot depending on weather etc. Cockerels aparently start making a noise BEFORE dawn if they are locked in so 30 mins before dawn is needed. What I had in mind would be to program in actual times based on the date using a lookup table
My mate would like to be able to vary the opening and closing times
Thanks for the silly comments though
« Reply #8 on: April 12, 2011, 09:14:15 21:14 » |
Haha.. you are right Oldvan, chicken will not like that. The Solar powered lighting pole is in my mind right now, can't decide it yet how to control the on/off time, it should be a cheap solution. GPS is the best if the cost is not a problem and the location is good for receiving the satellite signal. Mick, if you haven't then reading the thread below might be useful. Me still don't understand it. http://www.sonsivri.com/forum/index.php?topic=32632.0Edit: see Microchip AN1303A-Software Real-Time Clock and Calendar Using PIC16F1827, cheap enough US$1.82 a piece at digikey. -ichan
« Last Edit: April 12, 2011, 09:31:49 21:31 by Ichan »
-Receive: 4459
« Reply #9 on: April 12, 2011, 10:22:36 22:22 » |
could you not adapt an egg timer? Mick, if you haven't then reading the thread below might be useful. Me still don't understand it. http://www.sonsivri.com/forum/index.php?topic=32632.0Edit: see Microchip AN1303A-Software Real-Time Clock and Calendar Using PIC16F1827, cheap enough US$1.82 a piece at digikey. -ichan
« Reply #10 on: April 13, 2011, 07:15:39 07:15 » |
Ok all, this isn't a joke. The clock chip is all very well but dawn and dusk varies by hours during the year so not a lot of use. using a light sensor has been tried without success as hens KNOW when dawn is regardless of the actual light levels which vary a lot depending on weather etc. Cockerels aparently start making a noise BEFORE dawn if they are locked in........
Therein lies your answer, grasshopper
DarkClover
-Given: 37
-Receive: 60
Still alive...
« Reply #11 on: April 13, 2011, 10:06:13 22:06 » |
How is it if you use a simple timer switch for common power outlet? Then there are two ways. Either you catch the signal from the internal timer or just switch a Thyristor controlled relay or something. Or use a photoelectric sensor like the others said and connect id with the ADC of your PIC. This would be a good learning lesson
Not thinking means to believe what others say! TRY & ERROR... the fundamental principle our existence is based on
