December 29, 2024, 02:02:06 14:02
Author Topic: CCS PCWH v4.037  (Read 7192 times)
RedAlert
-Given: 168
-Receive: 302
« on: May 16, 2007, 11:40:03 23:40 »
Download link: http://www.uploading.com/files/2F1TFE9A/PCWH_v4.037.rar.html
Thanks to a friend Wink
"Life would be easier if we had its source code"
cyber_drifter
-Given: 167
-Receive: 32
« Reply #1 on: May 17, 2007, 12:20:23 00:20 »
A big thank you to you  RedAlert, and a thank you to your friend also.
Soter
-Given: 24
« Reply #2 on: May 17, 2007, 04:25:45 04:25 »
Thanks boxdog and redalert
chenyi.com
-Receive: 27
« Reply #3 on: May 17, 2007, 05:16:22 05:16 »
Thanks for you share.
fmssp
-Given: 42
-Receive: 109
« Reply #4 on: May 17, 2007, 07:59:17 07:59 »
Thanks RedAlert!
From Russia with love... ;-)))
zeus
-Given: 46
-Receive: 35
« Reply #5 on: May 17, 2007, 10:10:55 10:10 »
SINCE 4.033
 4.034  A problem with EXTERN on 1 bit variables is fixed
 4.034  Some issues with data saved in ROM have been fixed.  See readme.txt for info on ROM data.
 4.035  A problem with some constant strings in PCM is fixed
 4.035  A bug in memcpy for large arrays in PCH is fixed
 4.036  A problem with some PCM switch statements is fixed
 4.037  PJT file is no longer overwritten on each compile
 4.037  IDE updates for PCD beta testing
WARNING !!!
 4.038  An RS232 problem for some configurations (since 4.037) is fixed
CONLUSION:
4.037 have an RS232 bug
nirvana
-Given: 78
-Receive: 15
« Reply #6 on: May 17, 2007, 10:29:49 10:29 »
A big thank you to you  RedAlert.
urg001tmp
« Reply #7 on: May 17, 2007, 12:44:10 12:44 »
Thanks RedAlert
densimitre
« Reply #8 on: May 17, 2007, 03:35:19 15:35 »
Hi...
MMM......it seems to be horrible, with each upgrade, bugs upgrade too, i say new bugs. Last version goes out to fix the previous upgrade....bad things with CCS....
densimitre
« Reply #9 on: May 17, 2007, 07:48:34 19:48 »
SINCE 4.033
WARNING !!!
CONLUSION:
Hi, they never say what´s the specific bug...
Den4o
-Given: 950
« Reply #10 on: May 17, 2007, 09:56:23 21:56 »
Thank you RedAlert!
 Smiley
cerebronico
-Given: 264
-Receive: 27
« Reply #11 on: May 17, 2007, 10:04:15 22:04 »
Thank You Very Much Red Alert
bluex
-Receive: 39
« Reply #12 on: May 18, 2007, 09:14:04 09:14 »
Be carefull before upgrading this ugly compiler. For people who continue using it (and wasting their time waiting new versions), read this, this may save some of your time:
http://www.ccsinfo.com/forum/viewtopic.php?t=27714&start=225
hate
-Given: 156
-Receive: 355
« Reply #13 on: May 18, 2007, 09:43:24 09:43 »
Thnx for the update!
Regards...
Regards...
pic_aporte
« Reply #14 on: May 18, 2007, 06:54:07 18:54 »
Hi All, I applied this upload over ver. 4.033 but tells me the licenses are too old, any help?
Taner
-Given: 299
-Receive: 59
« Reply #15 on: May 19, 2007, 12:45:19 00:45 »
Thank you very much RedAlert
 Smiley
inthai2005
« Reply #16 on: June 03, 2007, 06:21:37 18:21 »
Thank you !!!
ze_tr
« Reply #17 on: August 08, 2007, 01:59:13 13:59 »
I exactly agree with the arguments. I am deeply thinking of switching to assembly language nowadays.
bluex
-Receive: 39
« Reply #18 on: August 08, 2007, 04:23:10 16:23 »
No you can simply switch to a  good compiler  Grin
bojaco
-Given: 17
« Reply #19 on: August 09, 2007, 01:51:04 13:51 »
Witch compiler would you use for PIC16 and 18?
ze_tr
« Reply #20 on: August 11, 2007, 06:16:07 18:16 »
I am currently using 4.038 version and it has several bugs. Sometimes .cof file (during debugging) lists processors header file instead of program source. Optimization generates wrong code (when I call a funtion several times in a subroutine then program executes the function regularly for the first two calling, however, the third one redirects the execution to the middle of the main routine). For the same code default optimization level (5) works fine.
FriskyFerret
-Given: 513
-Receive: 360
Put it in, take it out.
« Reply #21 on: August 14, 2007, 03:58:52 15:58 »
Christ, how many times does this have to be said!
USE CCS v3.249
ze_tr
« Reply #22 on: August 16, 2007, 08:54:03 08:54 »
I think CCS v3.249 is the latest stable version that encouraged the CCS team to switch to a new ide, ansi and multi compilation unit support.
veiledcavalier
« Reply #23 on: August 24, 2007, 10:25:45 22:25 »
THANKS THANKS THANKS
REDALERT
