April 19, 2025, 02:50:05 02:50
Author Topic: ULINK2 Clone (chinese) & Keil MDK 4.13a  (Read 36795 times)
godblessu
-Given: 133
-Receive: 297
« on: December 24, 2010, 02:58:30 14:58 »
I upgraded Keil MDK 4.12 to 4.13a and ULINK2 no longer work because it needs a firmware update. Sad
The Chinese ULINK2 Clone not support firmware upgrade.
I found a temporary solution. Replace the 4.13a ULINK2 DLL by the 4.12. Cheesy
C:/keil/ARM/BIN
UL2ARM.DLL
UL2CM3.DLL
ULINK2 DLL 4.12
http://www.4shared.com/file/snc3H3LX/ULINK2DLL.html
« Last Edit: December 24, 2010, 05:36:06 17:36 by godblessu » Logged
thavali
-Given: 44
-Receive: 145
« Reply #1 on: December 25, 2010, 03:16:09 15:16 »
haha, let try Jlink
godblessu
-Given: 133
-Receive: 297
« Reply #2 on: December 26, 2010, 09:57:24 21:57 »
haha, let try Jlink
Yes, I have a JLINK SEGGER too and working fine.
Where did you buy the clone ULINK2?
I bought into Mercado Libre website but I think that can be bought on ebay
« Last Edit: December 26, 2010, 10:18:24 22:18 by godblessu » Logged
nooknikz
-Given: 8
-Receive: 121
« Reply #3 on: January 01, 2011, 01:45:06 01:45 »
Fix with new ULINK2 firmware
nooknikz
-Given: 8
-Receive: 121
« Reply #4 on: February 20, 2011, 01:59:58 01:59 »
update firmware V1.42 for MDK4.14 up
zaalzaalak
-Given: 12
-Receive: 47
« Reply #5 on: July 02, 2011, 12:09:54 12:09 »
how to upgrade ulink2 firmware? with what software ?please help.
godblessu
-Given: 133
-Receive: 297
« Reply #6 on: July 02, 2011, 12:54:03 12:54 »
If your ULINK have a bootloader is automatically updated if connected in KEIL MDK.
But if not have bootloader you must do it manually.
- on the ULink there is a NXP LPC2148. This device has a serial bootloader in ROM.
- download & install Flash Magic from http://www.flashmagictool.com/
- to activate the bootloader in the LPC you must short "P0.14/DCD1/EINT1/SDA1 (PIN 41)" to GROUND and power up.
  LOW on this pin while RESET is LOW forces on-chip boot loader to take over control of the part after reset.
  It may be has a two-pin jumper (J3) in the lower right under µC and USB Port.
- at "J2" is the serial update port available, from left to right: RxD in, TxD out, GND. Connect to PC RS232.
  ***don't forget use a level converter RS232 to 3.3V. Like as MAX3232
- connect this port through a level shifter to RS232 Levels or a TTL-USB Converter to the PC
- run the Flashmagic Software, select COM-Port, Controller and Target File and run the Update (sometimes the autobaudings hangs, cycle power and give him another try)
Flash Magic Config
Select Device = LPC2148
Com Port = COM x
Baud Rate = 9600
Interface = ISP
Oscillator (MHz) = 12
kukumar
-Given: 35
-Receive: 28
« Reply #7 on: July 04, 2011, 03:44:56 15:44 »
Fine , you have explain all but not MAIN problem : Target File
Where we can find Target File Huh
tonko
-Receive: 64
« Reply #8 on: September 18, 2011, 08:43:10 08:43 »
Can somebody reupload "Fix ULINK2.rar" - file is corrupted.
indy
-Receive: 484
« Reply #9 on: September 18, 2011, 01:16:15 13:16 »
http://ifile.it/gyjl7me/Fix ULINK2.rar
https://rapidshare.com/files/2359793069/Fix_ULINK2.rar
« Last Edit: September 18, 2011, 01:21:48 13:21 by indy » Logged
suiram
« Reply #10 on: January 27, 2012, 10:06:42 10:06 »
Can you post an update for 4.23?
Zaphod Beeblebrox
-Given: 27
-Receive: 105
« Reply #11 on: October 02, 2012, 11:24:21 11:24 »
FYI, I just bought a chinese uLink2 clone on eBay and it works just fine with Keil MDK 4.54 including firmware update. Exact name of the device on eBay is: "Ulink 2 USB JTAG Adapter Emulator ARM9 Cortex Keil Ulink II GH2" (www.ebay.com/itm/280957120348).
« Last Edit: October 02, 2012, 12:00:35 12:00 by Zaphod Beeblebrox » Logged
Black holes are where the God divided by zero...
Don't panic!
indy
-Receive: 484
« Reply #12 on: May 24, 2013, 03:41:23 15:41 »
Ulink2 2.01 firmware update
zab
-Receive: 58
« Reply #13 on: May 25, 2013, 06:53:30 06:53 »
For PCB of ulink this site be helpful .http://www.sistemasembebidos.com.ar/cms/index.php?option=com_content&view=article&id=55:clon-ulink&catid=41:programadores-debuggers&Itemid=41
PaulC
-Given: 3935
« Reply #14 on: May 25, 2013, 09:58:28 09:58 »
hi zab
this is an excellent find..
like the idea to make it for yourself..
be interesting to see if it's updateable..
-Given: 841
-Receive: 4367
« Reply #15 on: May 25, 2013, 10:54:21 10:54 »
Over two years ago I priced this up, the cost was about the same as buying the offical Ulink, The time to build and making/buying a case/box in not included.
I bought one on e-bay, saving 75% of the full cost.
localcrack
-Receive: 21
« Reply #16 on: November 25, 2013, 05:37:27 17:37 »
I upgraded the firmware now Ulink2 is not recognized in keil.
I tried to flesh LPC2148 with flashmagic but it unable to program the chip.
is anybody has a solution for this problem ?
is anybody has a UL2_EraseFW.exe
I need this one for downgrading the firmware.
Kroko
« Reply #17 on: February 02, 2014, 10:41:48 10:41 »
There are different ULink2 clones available. I have 4 different ones. 3 of them were successfully updated to version 2, one is stuck on version 1.42.
Before you get one make sure it is updatable version with bootloader.
localcrack
-Receive: 21
« Reply #18 on: February 06, 2014, 01:47:09 13:47 »
I purchased new one and it works fine
No problem in upgrading a firmware at all.
Kombinator
-Given: 39
-Receive: 32
« Reply #19 on: March 23, 2025, 10:05:38 22:05 »
I have an old version of ULINK2 with LPC2148. I read and copied the flash to version 1.42  .   The board is orange with the inscription www.PowerMCU.com
Is there any firmware available that will work with a new version of KEIL5.38 and above? Best regards.
