November 29, 2024, 03:47:50 03:47
Author Topic: Protues and INA122  (Read 5288 times)
odsk
-Receive: 12
« on: December 10, 2010, 03:22:03 03:22 »
Anyone tried to simulate with INA122? I am having trouble doing that.
What I want to achieve is to simulate the INA with a differential output from a sensor (wheatstone bridge).
I have Rg=1K with power supply of 10V for the INA.
ODSK
-Given: 834
-Receive: 4322
« Reply #1 on: December 10, 2010, 06:54:04 18:54 »
hint:
the INA122 has a data sheet
it has a model in Proteus
so where is your testMe.dns posted ?
odsk
-Receive: 12
« Reply #2 on: December 11, 2010, 04:48:37 04:48 »
OK,
Made this test circuit but there is always some offset. example the input is 0.05mv but output 0.38V instead of being 0.01. Is that normal? (Gain is 205 (RG=1K), and ref is tied to ground).
I am trying to be as precise as possible. I am trying to use it with 24PCBFA6 pressure sensor for water level indication.
Thanks,
ODSK
« Last Edit: December 11, 2010, 05:00:21 05:00 by odsk » Logged
-Given: 231
-Receive: 983
« Reply #3 on: December 11, 2010, 10:59:11 10:59 »
OK,
Set RV1 to 100 ohm. Your circuit works fine, but with RV1=1K your amplifier saturate quite easy.
zuisti
-Given: 242
-Receive: 780
« Reply #4 on: December 11, 2010, 12:11:02 12:11 »
... there is always some offset. example the input is 0.05mv but output 0.38V instead of being 0.01. Is that normal? (Gain is 205 (RG=1K), and ref is tied to ground).
Hi;
You are right, this Proteus model seems has an offset error.
With shortened  input pins (Uin=0) and w/o (opened) R1 (G=5) the
output is 302 mV instead of the expected max. 1.25 mV (250 uV x 5).
Try out the offset compensation via the ref pin (datasheet, fig. 2)
or ... do not use it in Proteus (sorry :-). There are a lot of good OPAs ...
odsk
-Receive: 12
« Reply #5 on: December 12, 2010, 01:31:27 01:31 »
Yes I was setting the diffrence of portential only to 114ma max (this is the output of the pressure transducer).
