You think I am funny guy huh?
November 24, 2024, 10:46:05 22:46
Author Topic: pwm complimentary output  (Read 3503 times)
max
-Given: 1659
-Receive: 52
« on: December 03, 2010, 05:35:58 05:35 »
hi friends,
how to convert a pic16f870 single ended pwm output to complimentary
output (push-pull type) using discrete logic?
medik
-Given: 75
« Reply #1 on: December 04, 2010, 04:03:07 04:03 »
Hi, to get complimentary output, use two op amp, connect in a way that the pwm output will be connected to the + and - of the 2 op amp while 2.5v goes to the other ends of the op amp. I will upload a picture when i get home.
borberk
-Given: 309
-Receive: 598
« Reply #2 on: December 04, 2010, 08:22:10 08:22 »
Change code to have output on two pins in oposite phase or use inverter.
« Reply #3 on: December 04, 2010, 10:44:53 10:44 »
You need to consider adding dead band control to prevent cross conduction. If you are going to drive mosfets then a mosfet driver like IR2104/84 is a good choice, or change the PIC which have Enhanced PWM feature.
tAhm1D
-Given: 103
-Receive: 180
« Reply #4 on: January 01, 2011, 03:50:28 15:50 »
Hi max,
You can't have push-pull output with discrete logic from PWM output of PIC16F870. You have to use the compare module in CCP and use interrupt to obtain push-pull output. Or you could implement the whole thing on software using only the timer.
