November 24, 2024, 07:21:49 07:21
Author Topic: have you info about SPI PROTOCOL?  (Read 7889 times)
hamid9543
-Given: 80
« on: May 11, 2007, 06:46:02 18:46 »
hi.  can you help me about spi protocol in pic basicpro  or  mikrobasic.
(please explain with example)
thanks
tavioman
« Reply #1 on: May 11, 2007, 10:13:26 22:13 »
Would'nt you prefer C Language?
I can help you with examples in C.
Hardware SPI it's the best.
- Brain juice -
iphone
-Given: 115
« Reply #2 on: May 12, 2007, 02:00:44 14:00 »
tavioman,
Please go ahead for the C tutorial on SPI..  Grin
hamid9543
-Given: 80
« Reply #3 on: May 12, 2007, 05:34:53 17:34 »
thanks for replay.but i need for pic basic or mikrobasic.
best regard
robban
-Given: 34
-Receive: 38
Warrior
« Reply #4 on: May 14, 2007, 07:21:12 07:21 »
What kind of device do You wish to talk to via the SPI protocol?
In MikroBasic (found elsewhere in this forum) You have a number of SPI libraries. Go ahead and look in the help file there...
« Last Edit: May 14, 2007, 07:22:54 07:22 by robban » Logged
Code Warrior
hamid9543
-Given: 80
« Reply #5 on: May 14, 2007, 03:49:59 15:49 »
hi robban.
i want to conect RFM01(rf moudole) to pic16f877.
rfm01  conec with spi protocol
can you help me?
robban
-Given: 34
-Receive: 38
Warrior
« Reply #6 on: May 15, 2007, 02:15:35 14:15 »
Here's come the link, including datasheet and programming example
http://rapidshare.com/files/31487929/RF01.rar.html
« Last Edit: May 15, 2007, 07:35:00 19:35 by robban » Logged
Code Warrior
hamid9543
-Given: 80
« Reply #7 on: May 16, 2007, 05:14:37 05:14 »
thanks robban.
it is a c compailer (i donot know )i need to mikribasic or picbaisc pro code.
can you help me or guide me for programing in mikrobasic or picbaisc pro?
thanks
zeus
-Given: 46
-Receive: 35
« Reply #8 on: May 16, 2007, 05:36:17 05:36 »
You must use SPI in MODE1 and with 16 bit trasfer.
http://www.hoperf.com/pdf/RF01_code.pdf
also inc, you need to implement it to basic language.
I have used RF12. Problem with this RF modul is the tuning of our registers, and a well maked IT routin.
I don't used microbasic, but I think, that first U must init the port, then for write chip -select it, the spi_write first byte, then spi_write second byte then deselect chip.
mombasa
-Given: 8
-Receive: 15
« Reply #9 on: May 16, 2007, 09:42:54 09:42 »
For my rf module 2.4 Ghz. type  XTR-CYP-2.4 AUREL that has a SPI protocol, I used Pic Basic Pro Shiftin and Shiftout statements and it works fine. You can try.
mombasa
Lazio
Italy
hamid9543
-Given: 80
« Reply #10 on: May 16, 2007, 04:07:05 16:07 »
hi mombaso.can you explain what do you do?
thanks
best regard
hamed
-Receive: 15
« Reply #11 on: January 12, 2008, 03:43:24 15:43 »
I'm using a pic 16F876A to send data via SPI protocol and rfm 01 and 02 with PIC Basic PRo , but can't work with this modules ,
please ...
 Smiley
« Last Edit: January 13, 2008, 06:08:46 06:08 by hamed » Logged
Cynetron
-Receive: 31
« Reply #12 on: February 01, 2008, 11:12:31 23:12 »
you can use included spi or you can write a spi protocol as this address but if you need speed you should use included spi
http://www.picbasic.org/forum/showthread.php?t=5368
mcb58
-Receive: 44
« Reply #13 on: February 09, 2008, 06:52:38 18:52 »
hi ;
Here is the sample picbasic code for using SPI eeproms
Write To the first 11 locations of a MICROCHIP 25LC640 SPI serial eeprom
' Then Read the 11 locations back and display them on a serial LCD
' The configuration is 8192 words x 8-bits
' To WRITE to the eeprom:-
' The 16-bit address is loaded into the variable "ADDR"
' The byte to write is loaded into the variable "E_BYTEOUT"
' And a call is made to the subroutine "EWRITE"
' To READ from the eeprom:-
' And a call is made to the subroutine "EREAD"
' The byte at the specified address is returned in the variable "E_BYTEIN"
   Include "Modedefs.Bas"
' ** Setup the Crystal Frequency, in Mhz **
   Define    OSC      4      ' Set Xtal Frequency
' ** Set Debug Defines **
   Define   DEBUG_REG   PORTA      ' Debug PORT ?
   Define   DEBUG_BIT   0      ' *** Debug pin Bit ? ***
   Define   DEBUG_BAUD   9600      ' *** Debug Baud Rate ***
   Define   DEBUG_MODE   1      ' Set Serial Mode 1=Inverted
   Define   DEBUG_PACING   300      ' Delay 'in uS' between characters sent
' ** Define LCD Constants **
   I      Con   254      ' Control Byte
   Clr      Con   1      ' Clear the display
   Line1      Con   128      ' Point to beginning of line 1
   Line2      Con   192      ' Point to beginning of line 2
   Line3      Con   148      ' Point to beginning of line 3
   Line4      Con   212      ' Point to beginning of line 4
' ** Define the Pin assignments **
   CS         Var     PORTB.0         ' Chip select pin
   SCK        Var     PORTB.1         ' Clock pin
   SI         Var     PORTB.2         ' Data in pin
   SO         Var     PORTB.2         ' Data out pin
' ** Declare the Variables **
   Addr       var     Word            ' Memory address within the eeprom (0-511)
   E_Byteout   Var   Byte      ' Byte to be placed into the eeprom
   E_Bytein   Var   Byte      ' Byte read from the eeprom
' ** Define the eeprom's op-codes **
   WRSR      Con   1      ' Write to STATUS REGISTER op-code
   EWR      Con   2      ' WRITE op-code
   ERD      Con   3      ' READ op-code
   WRDI      Con   4      ' DISABLE WRITES op-code
   RDSR      Con   5      ' Read the STATUS REGISTER op-code
   EWEN      Con   6      ' ENABLE WRITES op-code
' ** THE MAIN PROGRAM STARTS HERE **
' Write the string, "HELLO WORLD" into the first 11 address's of the Eeprom
        For Addr=0 To 10                   ' Create a loop of 11
   LookUp Addr,["H","E","L","L","O"," ","W","O","R","L","D"],E_ByteOut' Build up the string
   GoSub EWrite            ' Write the byte to the Eeprom
        Next               ' Close the Loop
' Read the first 11 address's within the Eeprom and display them on the LCD
Again:  Debug I,Clr:Pause 30         ' Clear the LCD
   Pause 500            ' Pause for drama
   GoSub ERead            ' Read the byte from the Eeprom
        Debug E_ByteIn           ' Display the characters read in from the eeprom
   Pause 300            ' Pause between characters being displayed
        Next               ' Close the loop
        GoTo Again            ' Do it forever
' Read a single byte from the Eeprom
' The address is held in the variable "ADDR"
' The byte read is returned in the variable "E_BYTEIN"
ERead:    Low CS                             ' Enable the eeprom
        Shiftout SI,SCK,msbfirst,[ERD,Addr.HighByte,Addr.LowByte]' Send READ COMMAND and address
        Shiftin SO,SCK,msbpre,[E_Bytein]      ' Read data
        High CS                             ' Disable the eeprom
        Return
' Write a single byte to the Eeprom
' The byte to be written is held in the variable "E_BYTEOUT"
EWrite: Low CS                               ' Enable the eeprom
        Shiftout SI,SCK,msbfirst,[EWEN]          ' Send WRITE ENABLE command
        High CS                             ' Disable the eeprom, to execute the command
        Low CS                             ' Re-enable the eeprom
        Shiftout SI,SCK,msbfirst,[EWR,Addr.HighByte,Addr.LowByte,E_Byteout]' Send address and data
   Pause 5                         ' Allow the eeprom to allocate the byte
        Return
