November 24, 2024, 05:26:29 05:26
Author Topic: Flashmagic Error  (Read 3540 times)
satya
« on: November 03, 2010, 02:22:01 14:22 »
hi
i am new to micro-controllers and i am  using flash magic for 89v51rd2
flash magic not working  the error message is
ppa88
-Given: 49
-Receive: 131
« Reply #1 on: November 04, 2010, 03:09:33 15:09 »
I don't know if this will work for sure but you can give it a try.
Options -> Advanced Options -> Under Hardware Config tab uncheck Use DTR to control RST
Keep the Reset button on your target board pressed. Then ISP -> Read Device Signature and immediately release the Reset button. If Flashmagic reads the device signature properly, then communication is fine.
You can use same procedure for programming.
Good luck.
« Last Edit: November 04, 2010, 03:48:30 15:48 by ppa88 » Logged
ktek
« Reply #2 on: November 05, 2010, 08:09:08 08:09 »
are you sure that the board is in ISP mode  ?
I do not know 89v51rd2, but in the series lpc23xx  it must hold P2.10 to gnd during reset
technovm
-Given: 70
-Receive: 111
« Reply #3 on: November 07, 2010, 07:21:14 07:21 »
What is the frequency of the crystal?
Are you using Auto-ISP?
Can you upload circuit diagram?
