November 24, 2024, 08:41:40 08:41
Author Topic: REQ : USB to floppy driver ?  (Read 7490 times)
smainj
-Given: 70
-Receive: 75
« on: October 23, 2010, 02:16:07 14:16 »
i like to repalce the old floppy driver in the machine by USB flash memory
i try some ready production but don't work with my needed machine
(the machine is ZSK MSCD broderie machine)
 driver like this:
i like add to   old driver circuit will emult   disk
  Head motor will select address and Head set send the logical level
how i can make this and pls if anyone know somthing about that shar it
thank you
« Last Edit: October 23, 2010, 02:21:03 14:21 by smainj » Logged
-Given: 231
-Receive: 983
« Reply #1 on: October 23, 2010, 03:46:36 15:46 »
What kind of OS does the ZSK MSCD broderie machine use? I do not know if it will help. But I have a DOS USB memory stick driver somplace. Used it then I was working on windows CE
-Given: 834
-Receive: 4321
« Reply #2 on: October 23, 2010, 10:33:11 22:33 »
thank you
http://creating-industrial-solutions.com/2009/07/price-reduction-usb-floppy-emulator/
At a cost of 249.00 EUR or $345.17 US I would buy a standard floppy, but then if you have a usb port on your machine,
try a usb-pen drive or even a true usb floppy, at a  cost of less than £10..
smainj
-Given: 70
-Receive: 75
« Reply #3 on: October 24, 2010, 12:12:24 12:12 »
OS  is MS-DOS 3.11
Posted on: October 24, 2010, 01:07:50 13:07 - Automerged
the standart floppy driver don't work with machine only TEAC FD-235HF (100$) work
and floppy disk is hard to find and is expensive
-Given: 231
-Receive: 983
« Reply #4 on: October 24, 2010, 08:28:02 20:28 »
What do you need floppy for by the way?
technovm
-Given: 70
-Receive: 111
« Reply #5 on: October 26, 2010, 08:48:21 08:48 »
Check out this website: http://torlus.com/floppy/
may be useful.
DreamCat
-Given: 223
-Receive: 116
« Reply #6 on: November 27, 2010, 06:48:39 06:48 »
why not use software to arrive this?
could you tell us what kind usage must use hardware emulator?
there is many way can help you . (to resolve your problem?)
technovm
-Given: 70
-Receive: 111
« Reply #7 on: November 27, 2010, 07:50:48 07:50 »
I have seen old cnc machines(excellon automation co.) used for pcb drilling have a floppy drive to firmware and nc files. they offer floppy emulator but it is too expensive.
