November 21, 2024, 03:33:07 15:33
Author Topic: WYSIWYG Web Builder 7.1 + Serial  (Read 21859 times)
« on: September 01, 2010, 02:07:21 14:07 »
Web Builder is a WYSIWYG (What-You-See-Is-What-You-Get) program used to create web pages. WYSIWYG means that the finished page will display exactly the way it was designed. The program generates HTML (HyperText Markup Language) tags while you point and click on desired functions; you can create a web page without learning HTML. Just drag and drop objects to the page position them 'anywhere' you want and when you're finished publish it to your web server (using the built in Publish tool). Web Builder gives you full control over the content and layout of your web page.
Link: http://www.4shared.com/file/xUWf0rSx/WYSIWYG_Web_Builder_71.html
« Reply #1 on: September 02, 2010, 04:26:55 04:26 »
This is what the software opens:
http://www.wwb-support.com/wwb7/[email protected]&id=Q8443C3P6C44EP7PQP&sn=WB700-2C2C-7V53-57P9-XX6A-55Y9
Put it in your browser, you will get the activation.. nothing serious thu... After that it will write the device installer folder in the registry:
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Device Installer]
"{Q8443C3P-6C44-EP7P-QP}"="13baf852cf18aad40cf590a8fe8851bf"
"{Q8443C3P-6C44-EP7P-QP}" is the resulting activation key name which is also derived from the serial, while the difference between different machines is the name of that key, and the activation doesn't send your info over the internet. I hope it sends your info Frisky and they come to your place, here we dun care about this stuff! Any way, it doesn't send any info, it just opens that link above and waits for the reply... That's all...
Which means take it as is or just leave it and seek somewhere else for the cracked copy, nothing serious about this serial...
« Last Edit: September 02, 2010, 10:11:57 10:11 by metal » Logged
« Reply #2 on: September 02, 2010, 04:03:44 16:03 »
Okay Frisky, I will crack it for you so that it sends your info, wait for me Grin
Prisim
-Given: 28
-Receive: 57
« Reply #3 on: September 18, 2010, 04:32:23 16:32 »
here are 7.2 Released and Cracked by team LZ0 Finally Tongue
tested by me on WIN 7
screen shot is here Smiley
and is uploaded link Smiley (packed personally with recovery record Wink)
DL link:
http://www.fileserve.com/file/BDQGU5n
Mirror:
http://hotfile.com/dl/70296278/1891c18/WYSIWYG.Web.Builder.v7.2-Lz0.rar.html
pushycat
-Given: 213
-Receive: 1448
« Reply #4 on: October 05, 2010, 03:54:34 15:54 »
Yes...the software 7.2 Released and Cracked by team LZ0 opens ok and works ok. But when i tried to convert the page in to HTML / preview in default browser, it loaded with a RED background and the heading read "This page is created with an illegal copy of WYSIWYG web builder7". Any one has faced the same or has a solution for it?
« Last Edit: October 05, 2010, 03:58:27 15:58 by pushycat » Logged
-Given: 405
-Receive: 545
« Reply #5 on: October 05, 2010, 06:13:48 18:13 »
Don't remember where I found this or if it even works but it's worth a try
It is easy to undo the red background on the dreaded 48 hour trap
1. You remove <body bgcolor="#FF0000" text="#000000"> on each html page
Which you find about a quarter down the page.
2. Then edit and remove the http://www.wysiwygwebbuilder.com and replace with your own web address. This is found near top of page.
<meta name="generator" content="WYSIWYG Web Builder - http://www.wysiwygwebbuilder.com">
3.Last of all change title and add your own.
Change <title>this web page is stolen ect</title>
To <title>Welcome to my page ect</title>
pushycat
-Given: 213
-Receive: 1448
« Reply #6 on: October 06, 2010, 06:32:10 06:32 »
I have a copy of WYSIWYG 5 which works fine right from design to upload. But i was finding difficult to have a feedback form, which is easier in 7 version which has a PHP support. Thus had a try. Thanks "bbarney" for the sugession.
-Given: 833
-Receive: 4320
« Reply #7 on: March 13, 2011, 11:42:24 23:42 »
Hi I spent some time trying to sort out a copy from 7.2 but it's so hard to keep it from being blacklisted.
so I tried a single file thinstall of 7.5.2 and it's been ok, over a week now, still behaving. Smiley
http://www.megaupload.com/?d=AUI7DBWV
EDIT: Reverted to Trial software this was at 15 days. bummer.
« Last Edit: March 15, 2011, 04:58:47 16:58 by pickit2 » Logged
