You think I am funny guy huh?
April 19, 2025, 11:25:31 11:25
This thread is now for CCS C v4.xxx
Pages: 1 2 [3] 4  All
Author Topic: CCS C 4.xxx  (Read 164543 times)
jaikumar
-Given: 50
« Reply #50 on: April 02, 2012, 07:44:29 07:44 »
Hi all,
Even as we are downloading the 4.130 version, CCS has done it again:
CURRENT SOFTWARE VERSIONS
 Version 4.131
RECENT CHANGES
 4.131  A problem with cerrors on calls to some overloaded functions is fixed
 4.131  The PCD #ASM CLR and SETM instructions now work again
 4.131  #HEXCOMMENT now works with multiple compilation units
 4.131  A bug whrn #FILL_ROM and #ROM are both used is now fixed
Jai.
TheOwlar
« Reply #51 on: April 06, 2012, 04:08:03 16:08 »
Believe it or not... CCS has a new version
RECENT CHANGES
 4.132  A problem with FIXED_IO on port C for some chips is fixed
 4.132  A problem with function arguments with multi-dimention arrays is fixed
 4.132  Some fuse names have been corrected
BTW: Can someone reupload 4.130
Best regards,
Saludos...
joshua1
« Reply #52 on: April 06, 2012, 04:44:05 16:44 »
http://www.4shared.com/zip/6i9w_nzm/PCWHDv4130.html
deleted file please upload it again
gan_canny
-Given: 101
-Receive: 26
« Reply #53 on: April 06, 2012, 04:58:30 16:58 »
Some compiler vendors update every 6 months leaving customers long periods in which workarounds are the only solution. Others like CCS have a compiler that can have several versions installed simultaneously on a single PC. CCS has a stable version and the latest version with the weekly or daily fixes. If there is an issue that the latest version fixes then there is no need for a workaround if there is no issue then the stable version suffices.
If the issue isn't fixed in the latest version then the next version may address it. Some never having experienced the necessity of using workarounds for months on end aren't understanding the value of a rapid versioning approach. If rapid versioning is a problem then only using the CCS stable version and waiting several months for the next one is always available as a choice.
juliozv
-Given: 34
-Receive: 169
« Reply #54 on: April 06, 2012, 05:06:25 17:06 »
CCS 4.130
open with NoteBlock, the archive is .rtf of MAC OSX
« Last Edit: April 26, 2012, 04:40:02 16:40 by metal » Logged
lovefool
« Reply #55 on: April 26, 2012, 01:43:17 13:43 »
4.130 Windows
For those use torrent to download files.
mesex69
« Reply #56 on: May 09, 2012, 02:02:58 14:02 »
http://www.4shared.com/get/8ZApZ1wj/PCWHDv4130.html
engvidal
« Reply #57 on: July 20, 2012, 04:52:12 16:52 »
CCS 4.120 is out of bugs
ulderico
-Given: 158
-Receive: 819
« Reply #58 on: July 20, 2012, 07:47:19 19:47 »
http://www.4shared.com/rar/pRavQFII/pcwhdv4134.html
Enjoy!
MGLSOFT
-Given: 32
-Receive: 73
« Reply #59 on: October 14, 2012, 01:21:19 01:21 »
Here !!  Grin Grin Grin
v4.137
Edit: Use text files to upload links into posts.
« Last Edit: October 14, 2012, 06:10:05 06:10 by metal » Logged
gamegurus
-Receive: 64
Oh what a wonderful morning!!!
« Reply #60 on: November 19, 2012, 11:42:44 11:42 »
They have release 4.138 with new ICs support. Anyone able to provide it for download?
Indian Gaming Guru
Armageddon
-Given: 58
-Receive: 56
« Reply #61 on: November 19, 2012, 04:18:50 16:18 »
I hope that the relase 4.138 completely support the PIC32, to test it. Greetings for all.
Problems that appear small are large problems that are not fully understood.
TA5CT
-Given: 42
-Receive: 49
« Reply #62 on: November 19, 2012, 07:16:32 19:16 »
http://s2.dosya.tc/server21/grFBuC/pcwhd_4.138.zip.html
Enjoy!
« Last Edit: November 19, 2012, 07:25:20 19:25 by TA5CT » Logged
kreutz
-Given: 1004
-Receive: 127
« Reply #63 on: December 01, 2012, 05:43:44 17:43 »
Upgrade to version 4.140 is already out...
Improvements:
 4.140  An access violation when using bit_ functions is fixed
 4.139  A problem relocating the int vector to high memory on the ENH16 parts is fixed
 4.139  A compiler error when using a variable pin for some ENH16 ports is fixed
 4.139  A syntax error with void functions as pointers is fixed
 4.139  Some packed structure problems have been fixed
Xyloid
« Reply #64 on: December 28, 2012, 03:12:10 15:12 »
Hello, it looks like there is a pretty nasty bug in 4.138 with respect to making pointers to functions.  Previously the code always compiled, now it does not.
Does anyone have the 4.140 version?
Happy New Years!
ulderico
-Given: 158
-Receive: 819
« Reply #65 on: December 30, 2012, 07:31:42 19:31 »
OK!
Happy new year!
Enjoy!
Xyloid
« Reply #66 on: January 01, 2013, 05:16:41 05:16 »
Thank you for the upgrade to 4.140!!!  My home automation code now compiles as it should with pointers to functions  Grin  What a great way to start the new year!!!
aliveli
« Reply #67 on: January 29, 2013, 01:41:31 01:41 »
i am taking "Exception EAccessViolation in module" error with this v4.140
anyone elsetaking this?
and do you know any solution?
mayler
Roger that!
« Reply #68 on: February 02, 2013, 11:19:20 11:19 »
I compiled several projects with 4.140 and they are ok. Try uninstalling and making a clean install.
I'm using Windows 7 x64 home premium.
Computer Engineer.
Brosske
-Given: 75
-Receive: 292
« Reply #69 on: February 08, 2013, 08:23:38 20:23 »
Hi all,
rar unavailable... can someone re-upload please ?
thanks & greetz :-)
Do or do not - there is no try
ehnonymouse
-Given: 15
« Reply #70 on: February 09, 2013, 03:42:21 15:42 »
Re-upload of 4.140. I've not tried this before, so I hope it works.
alichan
-Given: 28
-Receive: 88
« Reply #71 on: February 16, 2013, 05:20:22 17:20 »
CCS 4.140 (keygen included)
Updated link: 16-02-2013
http://depositfiles.com/files/006sqktjl
password: sonsivri
mitsos
-Given: 3163
-Receive: 4783
« Reply #72 on: June 27, 2013, 01:00:12 13:00 »
hi
the last update of version 4, is the 140?
mitsos
tomywong
-Given: 103
-Receive: 213
« Reply #73 on: June 27, 2013, 01:58:39 13:58 »
No, it is v4.141. You can see someone ask question about v4.141 here : http://www.ccsinfo.com/forum/viewtopic.php?p=172815
« Last Edit: June 27, 2013, 02:01:17 14:01 by tomywong » Logged
Rute
-Given: 102
-Receive: 179
« Reply #74 on: June 27, 2013, 10:21:13 22:21 »
nop,
the  latest version is 5.005d!
Best,
