April 30, 2025, 05:48:18 05:48
Author Topic: [REQ] Need DIY PIC18F4550 PROGRAMMER  (Read 7555 times)
aamir
-Given: 37
-Receive: 229
« on: June 29, 2010, 08:28:39 08:28 »
I NEED WORKING DIY PROGRAMMER FOR PIC18F4550 with sch and software
Online Online
-Given: 232
-Receive: 991
« Reply #1 on: June 29, 2010, 08:44:59 08:44 »
Can you say something about which type of IO you plan to use (USB,Serial, LPT)? I will strongly recommend a USB variant. But in order to build that you need a programmer to program the MCU used in the project. So it is some sort of a chicken and egg paradox Cheesy
aamir
-Given: 37
-Receive: 229
« Reply #2 on: June 29, 2010, 10:27:14 10:27 »
If i need USB which components are required .
-Given: 841
-Receive: 4367
« Reply #3 on: June 29, 2010, 11:17:48 11:17 »
Did you ever think to use search, with so many projects both to be found here(sonsivri), and with the help of google (outside of sonsivri), you start a new topic Huh
link to one of many, I would not want to take the fun out of your searching Tongue http://www.sonsivri.com/forum/index.php?topic=2073.0
Online Online
-Given: 232
-Receive: 991
« Reply #4 on: June 29, 2010, 11:52:43 11:52 »
Many people struggle with RS232 programmers, they do not work well with many USB to RS232 converters, or modern PCs. Try Google and PICKIT 2 clone, or PIKCIT clone
aamir
-Given: 37
-Receive: 229
« Reply #5 on: June 29, 2010, 12:11:25 12:11 »
HI,
          I have lot of search on google and this forum but here i mean working programmer at this forum .so i can made without trouble. so next time i start old topic as u advice.
Online Online
-Given: 232
-Receive: 991
« Reply #6 on: June 29, 2010, 03:15:25 15:15 »
You should also look at Bootloaders. This can be implemented quite easy using RS232 or a USB interface on PIC18F series. You will still need a programmer to load the Bootloader code into the chip. But then first programmed you can use the Bootloader to program your chip
pushycat
-Given: 230
-Receive: 1448
« Reply #7 on: June 30, 2010, 07:01:55 07:01 »
HI, I have lot of search on google and this forum but here i mean working programmer at this forum .so i can made without trouble. so next time i start old topic as u advice.
Do not expect cooked food with spoon feeding. Every cicruits has its on properties and will be working as per the author who had designed or re-designed it or as per the hobbyist who has constructed it. It all depend on ones own knowledge to make things work. Select a Pickit2 clone design from where ever you get it and start constructing. Post your problems so that members may try to help you out. Good luck
blue_17
-Receive: 41
« Reply #8 on: August 28, 2010, 12:02:19 00:02 »
I have this programmer (potyo2), programing everyone PIC
http://www.icd2clone.com/wiki/Main_Page
