zuisti
-Given: 242
-Receive: 780
« Reply #25 on: April 21, 2007, 05:00:38 17:00 » |
Sorry, There were some errors in some files so I have deleted it. Will upload on correction.
Please upload it! This is worthly to look: http://rapidshare.com/files/27172374/SkyEye___ProVer_DSN.zip.htmlTested with Proteus 6.9 sp5. Thanks for the files from you! zuisti
sureshsharma2032
« Reply #26 on: April 22, 2007, 07:54:39 07:54 » |
Great zuisti. Thanks. Please upload some more.
Thankyou.
sohel
-Given: 167
-Receive: 149
« Reply #27 on: April 22, 2007, 02:00:07 14:00 » |
nice topics.
can anybody share model for AT89S8252 . thanks
zuisti
-Given: 242
-Receive: 780
« Reply #28 on: April 25, 2007, 01:49:34 13:49 » |
Hi Suresh! Please look at this post from me on thema SDK: http://www.sonsivri.com/forum/index.php?topic=3342.msg16705;topicseen#msg16705I think it is useful for you too... Or do you have a newer? Please upload it! Again: please upload the models2.rar repaired if you are ready! zuisti
« Last Edit: April 25, 2007, 01:56:24 13:56 by zuisti »
spasbyspas
-Given: 735
-Receive: 366
« Reply #29 on: May 07, 2007, 07:25:21 07:25 » |
zuisti
-Given: 242
-Receive: 780
« Reply #31 on: May 07, 2007, 04:23:32 16:23 » |
sureshsharma2032
« Reply #32 on: May 07, 2007, 08:10:50 20:10 » |
Hi zuisti
I have already looked at your post & downloaded the file. Thanks for it. Keep Going.
sureshsharma2032
« Reply #34 on: May 08, 2007, 12:22:35 12:22 » |
There is no difference I have seperated all the models from proteus & also added new models which doesn't come with proteus. Means old + new models in a single package. As per your requirement you can select a single model(*.Mdf) or a group of models(*.Mdf) & place in your Models directory as per requirement for your schematic. If someone needs only a single model he/she can select it & place in the Models directory OR if you want all the models then just place All.LML in the Models directory.
« Last Edit: May 08, 2007, 12:31:36 12:31 by sureshsharma2032 »
sureshsharma2032
« Reply #35 on: May 08, 2007, 12:37:13 12:37 » |
sureshsharma2032
« Reply #36 on: June 05, 2007, 01:02:28 13:02 » |
A Count-Down Timer Design File: Count_Down_Timer.rar DownloadLink: http://rapidshare.com/files/35357843/Count_Down_Timer.rarFile-Size: 0.02 Mb ----------------------------------------------------------------------------------------------
micropar
-Given: 44
« Reply #37 on: June 10, 2007, 12:48:31 12:48 » |
Hi Sureshsharma2032 or any Gentleman, Can any one upload the same once again? Links above are all dead. Website says "Files removed by uploader". Thanks in advance, Regards, --micropar--
ppa88
-Given: 49
-Receive: 131
« Reply #38 on: June 13, 2007, 08:22:35 08:22 » |
Here is an example which shows the PWM capability of PIC16F877. I have included the full MPLAB project along with the CCS C source code. The RS232 terminal allows you to select among 3 frequencies. The value of the A to D conversion depending on setting of the pot is also displayed and the change in PWM duty cycle can be clearly seen on the scope. I have also supplied a file defs16F877.h which will help you all to write programs in CCS C for 16F877. The source code file has comments which explain how the PWM section of 16F877 is configured. http://rapidshare.com/files/36890829/pwm.rar.htmlGood wishes to all
abbas
« Reply #40 on: September 12, 2007, 09:31:33 21:31 » |
anyone have model for AT89s51/52?
sohel
-Given: 167
-Receive: 149
« Reply #41 on: September 13, 2007, 07:13:09 07:13 » |
i am looking model for at89s8252.
Kova
-Given: 172
-Receive: 24
« Reply #42 on: September 13, 2007, 08:12:28 08:12 » |
HI all, I'm looking for a LM567/NE567 model....please help me Thanks a lot Bye
« Last Edit: September 13, 2007, 10:11:25 10:11 by Kova »
user112
-Receive: 139
Salut tuturor(hello to all)
« Reply #44 on: September 13, 2007, 10:18:45 10:18 » |
ppa88
-Given: 49
-Receive: 131
« Reply #45 on: September 13, 2007, 07:02:07 19:02 » |
Can anybody post a successful simulation example for this model of LM567? I have not been able to make it work as per the datasheet.
« Last Edit: September 13, 2007, 07:04:34 19:04 by ppa88 »
Kova
-Given: 172
-Receive: 24
« Reply #46 on: September 14, 2007, 06:08:03 06:08 » |
Quote!!!!I have tried all configuration and all examples found on the net, for example: http://www.reconnsworld.com/audio_tonedecode.html(With C1= 0.022uF and R1= 100K to capture a tone of 413Hz) OR http://members.cox.net/rbirac3/Snuffy/tone_detect.htmOutput at pin 8 is always at 5V! I have posted also in the forum where the file is situated....here: http://tinyurl.com/ywx6pu(See page 5 and 6) Bye
« Last Edit: September 14, 2007, 06:13:12 06:13 by Kova »
user112
-Receive: 139
« Reply #47 on: September 14, 2007, 07:26:21 07:26 » |
I tried to simulate and d' ont work sorry I will search more informations for LM567
ppa88
-Given: 49
-Receive: 131
« Reply #48 on: September 14, 2007, 08:05:49 08:05 » |
I have almost given up on this model. I think the dll is buggy as it takes a lot of processor resource with no appreciable results.
Kova
-Given: 172
-Receive: 24
« Reply #49 on: September 14, 2007, 10:01:08 10:01 » |
Damn The LM567/NE567 is necessary for my project
