April 25, 2026, 10:16:52 10:16
Author Topic: [RQD] help with ISIS and MMC card  (Read 11081 times)
-Given: 582
« on: May 14, 2010, 06:33:51 18:33 »
I'm trying to simulte an SD card in ISIS but I don't seem to be getting any where  Cry
 I created an card image ust using notepad (not sure if this is the correct way) but all that happens is, It asks me to insert card so I click to close card then it just says opening file and sits there and does nothing else.
I found a 32mb image file from here tried that and it just reports file exists.
What is the best way to create a card image file. It works in real life but I really want to use ISIS (been lazy and easier  Grin)
sample code:
Device 18F452
Xtal = 4
All_Digital = TRUE
Serial_Baud = 9600
Rsout_Pin = PORTC.6
Rsout_Mode = TRUE
Rsout_Pace = 1
Rsin_Pin = PORTC.7
Rsin_Mode = TRUE
Dim Response As Byte
Dim SD_IO As Byte
Symbol SD_CS = PORTC.2                                      'SPI CS to SD CS (SD pin 1)
Symbol SD_DI = PORTC.5                                      'SPI DO to SD DI (SD Pin 2)
Symbol SD_CLK = PORTC.3                                     'SPI CLK to SD CLK (SD Pin 5)
Symbol SD_DO = PORTC.4                                      'SPI DI to SD DO (SD Pin 7)
Include "SD_File_System_Code_Lib.pbp"                       'Include managed library file
GoTo Over_Sub                                               'Jump over the subroutines
Over_Sub:
    DelayMS 200
Main_Prog:
    RSOut "INSERT SD OR MMC",13
    Repeat
        Response = SD_Init_FS
    Until Response = 0
Open_New_File:
    SD_File_Name = "TESTFILE"                               'File Name, upper case only!
    SD_File_Ext = "TXT"                                     'File Ext, upper case only!
    Response = SD_Check_For_File                            'Check if file already exists
    If Response = 0 Then
        RSOut "FILE EXISTS - STOPPING",13
        Stop
    Else
        RSOut "OPENING FILE",13
        SD_New_File                                         'Open new file
    EndIf
Write_To_File:
    RSOut "WRITING TO FILE",13
    SD_IO_String = "SD/MMC Code by S Wright"
    SD_Write_String_To_File                                 'Write SD_IO_String to file
    SD_Write_Byte_To_File 13
    SD_Write_Byte_To_File 10
Close_File:
    SD_Close_File                                           'Close file
    RSOut "FILE CLOSED",13
    'Stop
    DelayMS 2000
    Repeat
    Until Response = 0
    SD_File_Name = "TEST001"
    SD_File_Ext = "TXT"
    Response = SD_Append_File
    If Response > 0 Then
        RSOut "ERROR - FILE NOT FOUND - STOPPING"
        Stop
    EndIf
    RSOut "APPENDING TO FILE",13
    SD_IO_String = "SD/MMC Code Test" + 13 + 10
    Response = SD_Write_String_To_File                      'Write SD_IO_String to file
    SD_Close_File
Finish:
    RSOut "FINISHED",13
    Stop
Alienbeing
-Given: 68
-Receive: 45
« Reply #1 on: May 14, 2010, 09:23:50 21:23 »
Didn't ISIS have a MMC memory card example? Thought I have seen it in one of their examples. Isn't SD similar to MMC cards? Both can use SPI.
Alienbeing
-Given: 582
« Reply #2 on: May 15, 2010, 10:24:43 10:24 »
Yes they are simular, I did look for the sample but I cant find it, looked in ISIS foleders but can't find it otherwise i would not be asking
Top
-Given: 53
-Receive: 1719
« Reply #3 on: May 15, 2010, 12:34:41 12:34 »
You need to use something like WinImage (http://www.winimage.com/winimage.htm) to make an empty SD card image; just a normal FAT16 image of whatever size you want to simulate. Call it something like 'sdcard.bin' and load it into the model. When you've finished simulating open it in WinImage to extract the files.
sohel
Online Online
-Given: 169
-Receive: 149
« Reply #4 on: May 15, 2010, 07:09:26 19:09 »
here it is-> Program Files\Labcenter Electronics\Proteus 7 Professional\SAMPLES\VSM for USB\PICDEM FS USB\MSD
