April 05, 2025, 09:24:58 21:24
Author Topic: Soldering Nokia 6100 LCD Connector  (Read 7626 times)
« on: April 25, 2010, 09:30:21 21:30 »
A friend asking me if i have ever use Nokia 6100 Graphic LCD.
No I said, I have the LCD for some time but still can not find the connector in the local market.
His question challenge me to try to soldering small wires directly to the connector, here is the result.
Not bad huh? It can be done at least!  Grin Cool Cheesy
DreamCat
-Given: 223
-Receive: 116
« Reply #1 on: April 26, 2010, 09:27:16 09:27 »
I think it is better to use some of enameled wire.
-Given: 405
-Receive: 545
« Reply #2 on: April 26, 2010, 02:51:04 14:51 »
It would be a good idea to take a glue gun and glue those wire's down around the connection because any movement of the wire there will tear  them off and then you will have a problem for sure,so try and keep the wire around the connections from moving everytime you handle it.
« Reply #3 on: April 26, 2010, 06:23:42 18:23 »
Yup, I'll glue it later - can't glue it before taking the picture.
I take the picture by scanning it on a flat bed scanner, ordinary camera (without macro lens) can not get a clear picture of this tiny connector.
DarthPic
-Given: 728
-Receive: 75
« Reply #4 on: April 27, 2010, 09:32:23 09:32 »
Hi ,
Some years ago i tried to do same as you but it as sometimes work , sometimes not ...
It's why i finally get that :
http://www.sparkfun.com/commerce/product_info.php?products_id=8600
Everything have work fine with that breakout board ..
cya.
Theory is when we know everything but nothing work ...
Practice is when everything work but no one know why Wink ...
-Given: 405
-Receive: 545
« Reply #5 on: April 27, 2010, 03:12:21 15:12 »
If your going to do alot of work with something then a breakout board like that is well worth the exspense as are alot of their other product's but if your only doing a one of a kind project than that's not worth it.
They have so much neat stuff there it's incredible ,if only we were rich enough  Wink
oldboy
« Reply #6 on: September 25, 2010, 04:50:05 04:50 »
This is surely prettier than what I do.
On a related note, soldering SMDs is still out of my league - I've burnt my share of SMDs.
