November 29, 2024, 03:46:44 15:46
Author Topic: Analog KeyPad  (Read 4120 times)
kalpakchiev
-Given: 34
-Receive: 68
« on: April 19, 2010, 07:49:53 19:49 »
One pin analog keypad.
Any comments or proposals are welcomed.
Proteus design included Cool
Best regards
« Last Edit: April 19, 2010, 08:14:19 20:14 by kalpakchiev » Logged
ipek
-Given: 60
-Receive: 79
« Reply #1 on: April 20, 2010, 02:02:04 02:02 »
dear kalpakchiev
not find 4bit bcd or binary output port  Roll Eyes
best reagards..
yahoo
-Given: 56
-Receive: 111
« Reply #2 on: April 20, 2010, 02:45:02 02:45 »
This solution is good but you have to keep in mind that you cannot use it for 2 or more simultaneously pressed keys and in battery operated units with floating power supply.
kalpakchiev
-Given: 34
-Receive: 68
« Reply #3 on: April 20, 2010, 04:18:34 04:18 »
Your note is very appropriate. 2 or more simultaneously pressed keys can not be recognized. For battery operation can be added a routine like this:
if sample > 900 and sample < 1015 then
        LCDOUT $FE, $80,"   Low battery  "
        KeyPressed=255
endif
dear kalpakchiev
best reagards..
Having KeyPressed value it is easy to add an lookup table and set 4 I/O to corresponding BCD code.
Best regards
jenniferkim
« Reply #4 on: December 22, 2010, 04:42:20 04:42 »
I like it. It looks pretty good but let me remind you, it can't be used at the same time for more than one keys . you have to consider the battery operated units with floating power supply.
