oldvan
-Receive: 107
If the van is a Rockin'...
« Reply #1 on: April 07, 2010, 06:37:26 18:37 » |
I'd have a look at Mouser, Digikey and maybe Newark, see what they offer, otherwise Google the heck outa it.
-Given: 405
-Receive: 545
« Reply #2 on: April 07, 2010, 06:46:59 18:46 » |
diamadiss
-Given: 202
« Reply #3 on: April 07, 2010, 07:12:47 19:12 » |
Thanks and two for answers. That keypad from sparkfun is good but i want a keypad with numbers in buttons.
majimbu
« Reply #4 on: April 11, 2010, 02:52:38 14:52 » |
hello, check the keypad at http://e-gizmo.com/, they have one cool 4 x 4 flat keypad, cost only $2 if i not mistaken...
diamadiss
-Given: 202
« Reply #5 on: April 11, 2010, 03:07:36 15:07 » |
I found a keypad in site who told me but that keypad is not luminously. If you know a keypad with light buttons. Thanks! Item Code: 77010624 4x4 Membrane Type Keypad 0-9, A-D,*# arranged in 4x4 matrix http://www.e-gizmo.com/pmaster.php?dpage=PRODUCT/proto/gizmo/proto.htm
majimbu
« Reply #7 on: April 12, 2010, 11:08:27 23:08 » |
hello, the keypad button in this site, http://www.e-gizmo.com/pmaster.php?dpage=PRODUCT/proto/gizmo/proto.htm is a sticker type, and some beneath is transparent, so you can simply modify it into backlighted keypad by adding led by your prefered color below ( sticking it into transparent plastic like acrilyc, can enhanced the backlight ). this one is if your budget cautious, because original lighted one is way too pricey, like bbarney said...
DarkClover
-Given: 37
-Receive: 60
Still alive...
« Reply #8 on: October 27, 2010, 01:15:19 01:15 » |
Hey guys! I'm on a project where I have a pad with 10x10 buttons. Each one should be illuminated by a RG(Y)-LED. At the internet there are lots of projects with caps out of soft rubber or silicone for covering the buttons which gives a very nice effect with LED's. I've searched a long time but I didn't find any tutorial or description how to make those. So if anyone knows anything about this, please tell me. Below is an example picture from a SparkFun project which has similar buttons (i think). I hope anyone can help me and/or has made such things by himself. Thanks to any respond
Not thinking means to believe what others say! TRY & ERROR... the fundamental principle our existence is based on
oldvan
-Receive: 107
« Reply #9 on: October 27, 2010, 03:34:31 03:34 » |
Perhaps this would be a good place for Microchip's Charge Time Measurement Unit CTMU PDF and its ability to easily use capacitive touch buttons. I got to play with the CapTouch technology on a recent job, and it works wonderfully, including through 1/8" thick Lexan or glass. A good discussion of the concepts is HERE.Circuit board could have a RGB LED mounted through a hole from the back side of the PCB, a protective transparent or translucent poly panel could have the "buttons" painted onto it, etc. ... On the fancy side, the pads for the "buttons" could be formed on glass using Indium Tin Oxide, a transparent conductor.
DarkClover
-Given: 37
-Receive: 60
Still alive...
« Reply #11 on: October 27, 2010, 02:42:21 14:42 » |
How do they make those silicone rubber button pads from SparkFun ? Is there any tutorial around here or the net, which describes how to make them and especially which materials are used ?
Any hint would be very useful. Thanks in advance!
oldvan
-Receive: 107
« Reply #12 on: October 27, 2010, 04:05:37 16:05 » |
Silicon like this guy used: http://www.youtube.com/watch?v=bnjeWbvVCCoHobby shop is likely to have it available. Make a mold, pour the silicone, let it harden.
DarkClover
-Given: 37
-Receive: 60
Still alive...
« Reply #13 on: October 27, 2010, 04:30:26 16:30 » |
Thanks for the video link, I found it just half an hour before.
Sounds very easy. I'll have a look at the hardware store tomorrow. Can I make the mold out of some hard plastic or pour it with epoxy resin? Or will the silicone stick on these materials ?
« Last Edit: October 27, 2010, 04:35:29 16:35 by DarkClover »
oldvan
-Receive: 107
« Reply #14 on: October 27, 2010, 07:24:55 19:24 » |
Mold release will be necessary for most materials. http://www.smooth-on.com/index.php?cPath=1123_1169or similar.
DarkClover
-Given: 37
-Receive: 60
Still alive...
« Reply #15 on: October 29, 2010, 01:05:17 01:05 » |
I found some applicable silicon rubber on the hardware store. It's white, has a soft surface and translucent. I made a test mold out of some LEGO and mixed the silicone with the hardener, but with 7% instead of 4% because of the viscosity. With this mixture it will become harder and cure much faster.
Well the first test went well and I'll try to make a first test button tomorrow.
