February 22, 2025, 10:23:28 10:23
Author Topic: Req: Circuit Help for use of SLA battery in Security Alarm Project  (Read 3364 times)
charudatt
-Given: 53
-Receive: 70
« on: April 06, 2010, 07:57:44 19:57 »
Hello Friends,
I want help / circuit ideas on how I can use a 12V SLA battery in a (security alarm) project in which , when the main power supply fails , the Battery takes over and the main supply , trickle charges the SLA battery.
oldvan
-Receive: 107
If the van is a Rockin'...
« Reply #1 on: April 06, 2010, 10:04:18 22:04 »
I've used this circuit in the past, works nicely.
http://shdesigns.org/gcellchg.html
bobcat1
-Given: 4358
-Receive: 96
« Reply #2 on: April 10, 2010, 11:45:20 11:45 »
You can use 2 diode connected back to back (cathode to cathode) and connect anode of each to power source (one anode to battery and one anode to PSU)
In order to charge the battery you will need to bypass the battery diode with a charging resistor (probably 10% of the battery current capacity)
another more efficient method id to use the LTC4412 from LTC you can find application schematic in data sheet
All the best
Bobi
DreamCat
-Given: 223
-Receive: 116
« Reply #3 on: April 10, 2010, 02:51:21 14:51 »
this can use p-channel mosfet as power switch.
