April 22, 2025, 08:24:22 08:24
Pages: 1 2 [3]  All
Author Topic: REQ: PCWH 4.030  (Read 24032 times)
Dembo
« Reply #50 on: April 16, 2007, 03:10:12 15:10 »
If YOU love it so much and you appreciate so much CCS works, why do you not buy it? this will give them more money to enhance their compiler !
Piracy is not a good thing! If it let you appreciate and test correctly a product without limitations, why you do not buy it if it gives you so satisfaction?
Why do You think that I don't buy it? I have 3 different LEGAL versions of CCSC that I bought, one PCM and 2 PCW. And for commercial projects I use only legal versions. I download new versions from here because CCS demo is limited to specific micro, but I want to "try before buy" how it works on my preferred micro. This lets me to buy it exact when I it really need.
I don't use PICbasic, I don't love it, but if someone found it useful - I'll never attack him. You want to prove us that CCSC is bad? For what do You need it? We all are friends here, and if Your friend found girlfriend and love her, You will say him "Your girl is ugly, I recommend You someone better" ?
int i;
for (i =110; i<0; i++) doSomething()
Do You really need such action in You program? What should it do? Or You want to see: what will this stupid compiler do in this case?
But if You ask compiler to do something not rational, why do You expect for rational answer?
« Last Edit: April 16, 2007, 03:35:37 15:35 by Dembo » Logged
bluex
-Receive: 39
« Reply #51 on: April 16, 2007, 03:46:40 15:46 »
I do not think anything. Everybody is free to do what he wants.
I also do not use it.
Glad to know that  Kiss
Of course I'll do !!! what happen if he "use" it to produce a baby? it will be bugged ... and when he will become a man, may be he will become a developper at CCS and produces a more buggy compiler version CCS v8.249 . We must preserve the environment from pollution !!!  Grin Grin Grin Grin Grin
« Last Edit: April 16, 2007, 03:48:32 15:48 by bluex » Logged
Dembo
« Reply #52 on: April 16, 2007, 03:54:29 15:54 »
 Grin Grin Grin Grin Grin Grin Grin but if his baby will like my code compiled with CCSC, You havn't reason to worry   Wink
bluex
-Receive: 39
« Reply #53 on: April 16, 2007, 03:58:17 15:58 »
and may be YOU ARE THE BABY we are speaking about  Tongue Tongue Tongue Tongue
hate
-Given: 156
-Receive: 355
« Reply #54 on: April 16, 2007, 04:48:47 16:48 »
int i;
First of all there is lack of C knowledge here! You didn't complete the for statement with a ';' so this code will give an error of "missing ';' " with CCS. I don't know if other compilers will generate any code but if they do then that's a shame for the compiler!
I have more than 19 years experience with C language. My code do not leak anything since it's not a fully working example, it's just a chunck of code. What I means is that CCS compiler will generate asm code that will never be executed because of max and min conditions in loops. you can try it your self.  This is ugly.
And WE HAVE HAD bugs with floating point and ugly printf function that return a string representation that has nothing to do with the number passed as parameter.
Allright I won't go any deeper in this useless discussion but be sure about that the code below doesn't compile to any code if it is in a 'main()' function or not! Because first there is a missing ';' & I guess you have forgotten to type it(according to your 19 year C experience) and second the compiler defaults 'int' to 'UNSIGNED 8-BIT INTEGER' so the expression 'i<0' is NEVER TRUE!!?! Below is a test program check for yourself:
void main()
int i;
for (i =110; i<0; i++) delay_cycles(1);
   setup_adc_ports(NO_ANALOGS|VSS_VDD);
   setup_adc(ADC_OFF);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
   setup_timer_1(T1_DISABLED);
   setup_comparator(NC_NC);
   setup_vref(FALSE);
   // TODO: USER CODE!!
And the list file:
.................... int i;
.................... for (i =110; i<0; i++) delay_cycles(1);
0015:  MOVLW  6E
0016:  MOVWF  26
0017:  GOTO   01B                   //it never checks 'i' jumps directly to init part as 'i' is never negative!
0018:  NOP                             //and this should be the normal compiler behaviour!
0019:  INCF   26,F
001A:  GOTO   017
I always use the printf function and it always supplied my needs without any format problem maybe yours had a special bug for the version you used.
Now when you said to never had problems with it, I do not speak about compiling programs that are on robots or on hardware that is rebooted 10000 times a day, I'm speaking about firmware that controls harware that will and must stay working for months without any reboot, on programs that do not do only loops and simple tests with 1000 lines of code, but on programs that have more than 400000 lines ... that have to work on devices like 18F8722 ... try doing such projects with CCS and you will see what I mean.
I didn't say I never had problems, in fact I had lots of problems with CCS but I didn't understand where you got the idea that I used it with systems rebooted 1000 times a day? No I haven't used that for human security but I used it for home security with lots of peripherals used in the PIC & the system never goes offline even the main power fails! In theory the code still runs without reboot without a single software related problem so far!
I really don't know 400000 lines of code compiles into how many assembly commands but my rough guess is above 400000 if there isn't any definitions in the code and I don't know of a 18 series PIC with memory more than 400kb to try 400000 lines of code you mentioned!
Please don't get me wrong 'bluex' your jokes are funny indeed Wink but I can also make jokes about programs that you and others like and that won't make me feel good if that program doesn't deserve this!
Regards...
Regards...
bluex
-Receive: 39
« Reply #55 on: April 16, 2007, 06:48:44 18:48 »
What about my last Joke ? you'll find it funny : Grin
wow ... very scientific aproach ...  Roll Eyes  Grin  Grin  Grin
1- When you have an optimizing compiler, lines are not converted using a template search/replace mechanism (like CCS seems to do  Grin )!
2- When you write four lines like   Sprintf(....); Sprintf(....); Sprintf(....); Sprintf(....); the code of SprintF is only integrated once (unless you force inlining of intrinsic functions) the lines are replaced by only push of params and call to functions.
3- when I say compiling 400000 that does not mean that ALL the content of the 400000 will be in the final hex !!! lot of libs and functions (not used) will not be integrated, they will be compiled in first stage of compilation and removed in linking/optimizing stage (at least in a good compiler+linker  Grin ).
Try to have a look at a book on compilation techniques and you'll be less ridiculous in your posts  Tongue
Regards!
hate
-Given: 156
-Receive: 355
« Reply #56 on: April 16, 2007, 08:11:19 20:11 »
I'm not very into compiler writing and don't have any idea about it. I just said "rough guess" as every line of code at least adds a "call subroutine" command if using intrinsic functions as you said. So my rough guess was 400000+ lines of assembly without any "definition,enumaration vs..." in the code. But in case you are adding "libraries, unused functions" in your "400000+ lines of code" then we can consider we are all working with 50000+ lines of code in a simple project! Then that makes not of a big difference 400k with 50k, 1/8 ratio! Wink
Regards...
Regards...
Dembo
« Reply #57 on: April 16, 2007, 08:45:29 20:45 »
I just opened my current project with all possible stuff: "definitions,enumerations,typedefs,libraries, unused functions  etc."...
.lst file is 8000 lines, ROM usage is 9kB, code is optimized enough (to my look about less than 15% wasted comparing if I was writing it in assembler)
assuming each assembly line is 2bytes of the ROM, it is 4.5k lines, and source is about 3,5k
so hate's calculation is more or less accurate
« Last Edit: April 16, 2007, 08:48:20 20:48 by Dembo » Logged
micropar
-Given: 44
« Reply #58 on: April 16, 2007, 09:10:35 21:10 »
Hi all,
I agree with Bluex.
I have 20 years of experience with C/C++ using it for embedded as well as PC side programming.
My most projects are very complecated with lots of features, added and derived from
my earlier programming. I normally do prototype software with Turbo C, make it compile without error
and then I port the same to embedded.
Hitech is the best I found among PIC series besides defacto Keil C51 for 8051. The semantic analysis
of Hitech is so good that many times, bugs that are un-noticed with TurboC are noticed by Hitech and it
suggest its remedial action, too, very nicely.
I too consider CCS compiler as Hobbyiest or beginners one. Till as of version 4.032, it still doesn't
support pointer to function, which is must if you want to write RTOS and complex state machines.
If you ever had written even small compiler, you can realise that most difficult part of it are Pointer
and Reference managment, as CCSinfo people have not able to offer.
Best part of Hitech Compiler are (1) support Pointer to function, (2) Strict adherence to ANSI I/O
library and (3) Very compact code when you use data structures.
Bad part of Hitech is it dosen't provide accurate delay functions inbuilt in Library. Although when you use
RTOS you don't requires that much too accurate delay functions as using delay fuctions in RTOS
are supposed as blocking functions and bad programing practice.
Strong part of CCSinfo is their execellant library of most commonly Embedded peripherals, which makes using
Compiler in C like writing programs in Basic. I too use it many times for quick prototyping on estimation of cost
on bigger projects.
There is another reason why I reccommand Hitech, if you are taking up Embedded Programming as Careers
full time profession seriosly. With in next few years, 32 bit ARM architecture will predominent the current 8/16 bit
microcontrollers just like microcontrollers has predominated currently that of earlier microprocessor
embedded boards of 8085, Z80, 68000 etc. Now to program in 32 bit ARM, you requires good ANSI adherence,
good programming habbits of using data structures etc. all that Hitech offers and caters today.
I regret for inconvenience caused or feeling hurt to anyone, as I was expressing my opinion, from my experince.
--micropar--
hate
-Given: 156
-Receive: 355
« Reply #59 on: April 17, 2007, 10:15:41 10:15 »
ANSI may be good for 32-bit ARM architecture but IMO it is not for an 8-bit architecture. Because ANSI standart defaults even the "short int" type to a "16-bit" value minimum! A 16-bit variable in an 8-bit system is slower than an 8-bit variable in an 8-bit system! Of course there is the "char" type but it is mainly for "characters" right? So I stay away from ANSI for low-end MCU's!
32-bit ARM architecture is something I also try to get familiar with but in my country where even PIC18 is not very common, ARM stays as a very special and expensive option. And I don't think 32-bit MCU's will dominate 8-bit or 16-bit parts, if 32-bit costs lower ok but even if they both the same price I prefer the low-end part for low-end systems.
Regards...
Regards...
bluex
-Receive: 39
« Reply #60 on: April 17, 2007, 10:42:31 10:42 »
Regards...
32 bit ARM devices are becoming very close to most 16bits devices ... some Philips LPCxxxx are just about 16 euros and have by far more ROM/RAM and internal hardware. The only problem with such devices FOR HOBBIST is perhaps the fact that they do not exists in DIL packages because of their numerous IO pins.
But they are the PRESENT and not the FUTURE !!!! They are the most used processors in embedded hardware actually!
hate
-Given: 156
-Receive: 355
« Reply #61 on: April 17, 2007, 08:32:03 20:32 »
Actually we live the PAST here Wink  Grin
Regards...
Regards...
micropar
-Given: 44
« Reply #62 on: April 18, 2007, 08:51:21 08:51 »
Hi all and Hate,
Embedded future belong to 32 bit architecture, even though we hate using it, including myself.
There are several reasons for it but most important are:
1) 32 bit offer almost full range of number (int) (4GB) that the human can encounters in our everyday life.
For this reason once you start programming in 32 bit, you mostly don't have to think of  out of range quantity
or scalling the numbers obtained from A/D or I/O.
2) Timer management in embedded RTOS becomes very easy, as you start incorporating more tasks and
you never have to worry about timer interrupt missing or rollover.
.......If you ever designed any uP IP using FPGA core with VHDL or Verilog, you will realise more:
3) Memory addressing (4GB) becomes simpler
4) Opcode format becomes very easy to program as you have 32 bit to play with
and almost all instructions can be single cycle including Jump with pipe-lining.
I hope, we should start to welcome the bright future of ours in 32 bit world, warmly,
--micropar--
hate
-Given: 156
-Receive: 355
« Reply #63 on: April 18, 2007, 10:00:41 10:00 »
Yes you are right for all the things you say but those are mostly high-end systems requiring 4GB memory. I'm not talking about low-end MCU's for high-end systems, I'm talking about low-end MCU's for low-end systems! At least this will be my choice if the low-end MCU costs less!
Regards...
Regards...
Robi
-Given: 56
« Reply #64 on: April 18, 2007, 02:29:33 14:29 »
hate, you have my sympathy as I pretty agreed with all that you say but you shouldn't wasting your time with those who want not to hear or understand. It sounds to me as a few guys here prefer doing 0.1'' hole with auger instead using mini-drill or does that hide their personal frustration in using low-end products? May or maybe not. What I know is that the tool one may use make not him necessarely professional.
« Last Edit: April 18, 2007, 02:36:55 14:36 by Robi » Logged
chenyi.com
-Receive: 27
« Reply #65 on: April 18, 2007, 07:06:12 19:06 »
CCS C VS HT-PICC
I compiled this file with CCS c and ht-Picc. The list file  in here.
void main(void)
         int i;
         for (i =110; i<0; i++) {
                     i++;
         i = 100;
                                              CCS PCM C Compiler, Version 4.032, 60629               19-四月-07 12:31
               Filename: C:\Documents and Settings\user\My Documents\12.lst
               ROM used: 42 words (1%)
                         Largest free fragment is 2048
               RAM used: 8 (2%) at main() level
                         8 (2%) worst case
               Stack:    0 locations
         0000:  MOVLW  00
         0001:  MOVWF  0A
         0002:  GOTO   004
         0003:  NOP
         .................... #include "C:\Documents and Settings\user\My Documents\12.h"
         .................... #include <16F946.h>
         .................... //////// Standard Header file for the PIC16F946 device ////////////////
         .................... #device PIC16F946
         .................... #list
         .................... #device adc=8
         .................... #FUSES NOWDT                    //No Watch Dog Timer
         .................... #FUSES LP                       //Low power osc < 200 khz
         .................... #FUSES NOPUT                    //No Power Up Timer
         .................... #FUSES PROTECT                  //Code protected from reads
         .................... #use delay(clock=20000000)
         .................... void main()
         0004:  CLRF   04
         0005:  BCF    03.7
         0006:  MOVLW  1F
         0007:  ANDWF  03,F
         0008:  BSF    03.6
         0009:  CLRF   1C
         000A:  CLRF   1D
         000B:  CLRF   1E
         000C:  BSF    03.5
         000D:  CLRF   1C
         000E:  CLRF   1D
         000F:  CLRF   1E
         0010:  BCF    03.5
         0011:  BCF    03.6
         0012:  BCF    1F.5
         0013:  BCF    1F.6
         0014:  MOVLW  00
         0015:  BSF    03.5
         0016:  MOVWF  11
         0017:  CLRF   17
         0018:  MOVLW  07
         0019:  MOVWF  1C
         ....................          int16 i;
         ....................          for (i =110; i<0; i++) {
         001A:  BCF    03.5
         001B:  CLRF   22
         001C:  MOVLW  6E
         001D:  MOVWF  21
         001E:  GOTO   026
         ....................                      i++;
         001F:  INCF   21,F
         0020:  BTFSC  03.2
         0021:  INCF   22,F
         0022:  INCF   21,F
         0023:  BTFSC  03.2
         0024:  INCF   22,F
         0025:  GOTO   01E
         ....................          i = 100;
         0026:  CLRF   22
         0027:  MOVLW  64
         0028:  MOVWF  21
         ....................    // TODO: USER CODE!!
0029:  SLEEP
         HI-TECH Software PICC Macro Assembler V9.60
                                                               Thu Apr 19 01:45:36 2007
              1                              processor   16F946
              2                              opt   pw 79
              3                              psect   text0,local,class=CODE,delta=2
              4                              psect   text1,local,class=CODE,delta=2
              5  0000
              6  0000
              7  0000
              8  0000
              9  0000
             10  0000
             11  0000
             12  0000
             13  0000
             14  0000
             15
             16                              psect   text0
             17  07EB                     _main
             18                           ;   _i assigned to ?a_main+0
             19  0000                     _main$i   set   ?a_main
             20                           ;11.c: 4: void main()
             21  07EB  306E                  movlw   110
             22  07EC  1283                  bcf   3,5
             23  07ED  1303                  bcf   3,6   ;carry unused
             24  07EE  00A0                  movwf   ?a_main
             25  07EF  01A1                  clrf   ?a_main+1
             26  07F0  2FF9                  goto   l3
             27  07F1                     l2
             28                           ;11.c: 13: i++;
             29  07F1  0AA0                  incf   ?a_main
             30  07F2  1903                  btfsc   3,2
             31  07F3  0AA1                  incf   ?a_main+1
             32  07F4  0AA0                  incf   ?a_main
             33  07F5  1903                  btfsc   3,2
             34  07F6  0AA1                  incf   ?a_main+1
             35  07F7  1BA1                  btfsc   ?a_main+1,7
             36  07F8  2FF1                  goto   l2
             37  07F9                     l3
             38                           ;11.c: 14: }
             39  07F9  3064                  movlw   100
             40  07FA  00A0                  movwf   ?a_main
             41  07FB  01A1                  clrf   ?a_main+1
             42                           ;11.c: 16: }
             43  07FC  0183                  clrf   3
             44  07FD  120A  118A  2800      ljmp   start
         Symbol Table                                          Thu Apr 19 01:45:36 2007
         ?a_main 0020       l2 07F1       l3 07F9    _main 07EB    start 0000
          status 0003
« Last Edit: April 19, 2007, 05:33:22 05:33 by chenyi.com » Logged
chenyi.com
-Receive: 27
« Reply #66 on: April 18, 2007, 07:10:48 19:10 »
http://www.ccsinfo.com/content.php?page=newcompilercomp
chenyi.com
-Receive: 27
« Reply #67 on: April 18, 2007, 07:17:20 19:17 »
about pointers to funtions
The compiler does not permit pointers to functions so that the compiler can know at compile time the complete call tree.  This is used to allocate memory for full RAM re-use.  Functions that could not be in execution at the same time will use the same RAM locations.  In addition since there is no data stack in the PICĀ®, function parameters are passed in a special way that requires knowledge at compile time of what function is being called.  Calling a function via a pointer will prevent knowing both of these things at compile time.  Users sometimes will want function pointers to create a state machine.  The following is an example of how to do this without pointers:
enum tasks {taskA, taskB, taskC};
run_task(tasks task_to_run) {
    switch(task_to_run) {
    case taskA : taskA_main();  break;
    case taskB : taskB_main();  break;
    case taskC : taskC_main();  break;
Use this and pointers to funtions in Ht-picc, pls look the .lst file, Vs them!!!
hate
-Given: 156
-Receive: 355
« Reply #68 on: April 18, 2007, 09:24:18 21:24 »
Thnx Robi! We all share something here, either idea, either stuff, either opinion & I was just sharing my opinion Wink
Regards...
Pages: 1 2 [3]  All
